Astro heater/AC control switches
Postby dswaff2478 [OP] » July 23rd 2013, 3:07am
I've been told there is a way to remove those heater /AC control switches without removing the dog house and radio, could someone please tell me how it's done?? Thanks DonS
dswaff2478
Years of Membership: dswaff2478 has been a member for 4 full yearsdswaff2478 has been a member for 4 full yearsdswaff2478 has been a member for 4 full yearsdswaff2478 has been a member for 4 full years
Year: 1999
Extra Info: 4.3 V6 RWD
Re: Astro heater/AC control switches
Postby thegreenmachine » July 23rd 2013, 3:42am
don't think you have to pull the doghouse.
should be able to remove the bezel and unclip the stereo, and undo the screws holding the heater controls.
takes like, 2 mins I could take pictures if you like.
"that looks legit"
95 AWD Safari money pit
thegreenmachine
Firing on 6 Cylinders (L2)
Years of Membership: thegreenmachine has been a member for 7 full yearsthegreenmachine has been a member for 7 full yearsthegreenmachine has been a member for 7 full yearsthegreenmachine has been a member for 7 full yearsthegreenmachine has been a member for 7 full yearsthegreenmachine has been a member for 7 full yearsthegreenmachine has been a member for 7 full years
Topics: 62
Alias (AKA): Shane a lane
Year: 2003
Postby 2002_4L60E » August 11th 2013, 3:01am
Could you show this quick n easy way to detach the heater / AC control switches?
2002_4L60E
Years of Membership: 2002_4L60E has been a member for 3 full years2002_4L60E has been a member for 3 full years2002_4L60E has been a member for 3 full years
Topics: 9
Year: 2002
Postby Drummernaut » August 11th 2013, 3:33am
Check here to start:
viewtopic.php?f=13&t=29258
But in your case continue to pull the rest of the bezel off.
1999 Astro LT AWD
MODS: Electric fan, Transmission cooler/fan, AWD engaged LED
Drummernaut
Years of Membership: Drummernaut has been a member for 6 full yearsDrummernaut has been a member for 6 full yearsDrummernaut has been a member for 6 full yearsDrummernaut has been a member for 6 full yearsDrummernaut has been a member for 6 full yearsDrummernaut has been a member for 6 full years
Topics: 9
Alias (AKA): Drummer From Hell
Year: 1999
Extra Info: LT V6 AWD
Removing HVAC electric switches from bezel
Postby 2002_4L60E » August 11th 2013, 7:52pm
First, the bezel does start snapping off with that prong above the ash tray. Unfortunately, the rest of the bezel seems to want the driver's side lower panel to be removed. Didya know the glovebox / console is held at the bottom with two nuts? I do now...
Here is the smart way to disconnect the electrical plug from the back of the HVAC electrical switches WITHOUT dropping the inner slide contact....
Note that the catch is on the inner side of the switch, making it a little harder to remove the plug than it should be. Inserting a standard screwdriver in from the cutout for the radio will allow you to depress the catch....
2002_4L60E
Topics: 9
Year: 2002
Postby syedshah20 » October 18th 2014, 5:32am
I live in Spain and my air conditioning compressor needs replacing. The garage says that they cannot get a new one for love or money, and to recondition mine will cost 450 €. Any thoughts or suggestions?
syedshah20
Years of Membership: syedshah20 has been a member for 2 full yearssyedshah20 has been a member for 2 full years
Postby Lumpy » October 18th 2014, 7:32am
syedshah20 wrote:I live in Spain and my air conditioning compressor needs replacing. The garage says that they cannot get a new one for love or money, and to recondition mine will cost 450 €. Any thoughts or suggestions?
What year is your van?
Topics: 257
Year: 1989
Return to Climate Control
It is currently January 23rd 2017, 9:34am
Climate Control Forum
Comments: 29
Date: Dec 22 '16
Time: 2:51am
Colorado Tim
in Climate Control
Date: Dec 15 '16
Time: 5:21am
Colorado Tim
in Climate Control
Date: Dec 15 '16
Time: 5:18am
Rookie162
in Climate Control
Comments: 245
Date: Dec 13 '16
Time: 12:41am
Rookie162
in Climate Control
Comments: 245
Date: Dec 11 '16
Time: 5:32am
cron
