93 fan blower motor
93 fan blower motor
Postby maniac mark [OP] » May 27th 2009, 4:36am
Hey all, Im really ticked now :screaming: I got a 93 safari with the typical fan blower motor issue when i got the van the seller put in a used one from a 94 safari, worked for a while ok, now doesnt want to work, took it out to a friends motor rebuild shop he put 12 volts to it and spun fast and smooth no problem, put it back in. Took out the 2 screws from under the selector control panal came out easy, everything looks good and connected ,when you move the lever for heat and cold you can hear the door flaps moving, same for climate control vacume sound good, just the 3 blower speeds dont work!! Saw the picture of the blower motor resistor,took that out ALL RUSTED TO YOU KNOW WHAT!! Got one today identical :dance: ,put it in, easy, put dielectric grease on connections....turn on van still no blower speeds tapped dash, knocked on blower motor when turned on .....nothing .Even checked A/c heater fuse, good, purple wire to motor not rusted out connections fit good. Now Im peeved :banghead:and :confused: PLease help What the heck am :oops: I missing.
maniac mark
Years of Membership: maniac mark has been a member for 4 full yearsmaniac mark has been a member for 4 full yearsmaniac mark has been a member for 4 full yearsmaniac mark has been a member for 4 full years
Alias (AKA): maniac
  • blower motor
    by chris1990 » December 21st 2012, 5:21pm in Climate Control
    Last post by RECox286 View the latest post
    December 21st 2012, 7:23pm
  • Blower issue
    by fede » May 13th 2013, 5:20pm in Climate Control
    Last post by fede View the latest post
    May 19th 2013, 2:01am
    May 24th 2013, 3:58pm
Re: 93 fan blower motor
Postby gtkane » May 28th 2009, 3:01am
Two things to check here.
1-Test for power at the blower connector. The fan motor may have a "dead" spot in it
2- if there is no power, remove the fan switch on the dash. They are famous for burning out/melting. It will be obvious if it is!
User album #4...check it out!
gtkane
Years of Membership: gtkane has been a member for 5 full yearsgtkane has been a member for 5 full yearsgtkane has been a member for 5 full yearsgtkane has been a member for 5 full yearsgtkane has been a member for 5 full years
Alias (AKA): Astruck
Extra Info: nasty 4.3
Postby maniac mark [OP] » May 31st 2009, 4:06am
Hey thanx for responding< i forgot to mention that i did check for power and got 14.5 volts at the purple wire and i did look behind the blower switch lever its still good,my mechanic told me to check the blower motor relay, the small square box at the top of the fire wall above the fan blower motor. it was done . replaced it now blower works great!!! :banana: Thanks for gettin back to me!! :wave:
maniac mark
Alias (AKA): maniac
Return to Climate Control
It is currently May 24th 2013, 3:58pm
Climate Control Forum
Attached by: chevymaher
in Climate Control
Comments: 154
Date: May 09 '13
Time: 2:01am
deleteitall
in Climate Control
Date: May 07 '13
Time: 6:42pm
Drummernaut
in Climate Control
Date: Apr 15 '13
Time: 12:08am
Attached by: tedanderson
tedanderson
in Climate Control
Date: Apr 02 '13
Time: 9:37pm
in Climate Control
Date: Mar 09 '13
Time: 2:19am
