1999 Astro, Blower how to replace
Postby turnipfish [OP] » August 3rd 2009, 2:49am
My blower on my 99 goes out completely. When I tap on the plastic cover with a hard object it blows again. I am thinking I have a weak blower motor that is going out. After reading my Haynes repair manual it appears that the removal of this motor should be a "piece of cake", well my findings are a bit different. The cover seems to be one piece that covers the fan as well as part of the air conditioner condensor. If anyone knows how I should remove this cover please post instructions, lead me to a source of information, or show me some pictures.
On the other hand, if I am missing something that I should be looking at please let me know. I'd like to end this by saying thanks to all that contribute to these forums. In some cases I have helped my mechanic to diagnose problems in other vehicles, or become to feel confident with my mechanic's opinion because of other's experiences.
turnipfish
Years of Membership: turnipfish has been a member for 7 full yearsturnipfish has been a member for 7 full yearsturnipfish has been a member for 7 full yearsturnipfish has been a member for 7 full yearsturnipfish has been a member for 7 full yearsturnipfish has been a member for 7 full yearsturnipfish has been a member for 7 full years
Alias (AKA): JTD
  • Blower motor
    by Kayakfisher » March 6th 2017, 1:15pm in Climate Control
    Last post by Kayakfisher View the latest post
    March 9th 2017, 3:16pm
  • high speed of blower does not work
    by Craig » April 12th 2017, 10:52pm in Climate Control
    Last post by Don1806 View the latest post
    April 26th 2017, 11:29pm
    May 28th 2017, 3:58pm
Re: 1999 Astro, Blower how to replace
Postby 'cudapaul » August 3rd 2009, 3:16am
You can cut the plastic cover that surrounds the fan. If you look at it carefully, I believe that it is marked on the cover.
Overall, it is pretty easy. Obviously, the coolant and windshield tank needs to come out and then cut the cover, disconnect the wire, unbolt the fan and lift it out. You will probably have to swap the squirrel cage over to the new motor, and then reverse the steps.
If you prefer to work on your van, I would recommend that you purchase a factory service manual, typically on ebay or other websites. For example, the plastic cutout shape and method is clearly shown in the service manual.
'cudapaul
Years of Membership: 'cudapaul has been a member for 9 full years'cudapaul has been a member for 9 full years'cudapaul has been a member for 9 full years'cudapaul has been a member for 9 full years'cudapaul has been a member for 9 full years'cudapaul has been a member for 9 full years'cudapaul has been a member for 9 full years'cudapaul has been a member for 9 full years'cudapaul has been a member for 9 full years
Alias (AKA): 'cudapaul
Extra Info: LT AWD
Postby turnipfish [OP] » August 3rd 2009, 4:32am
Ok, Now that I look at it again I do see the outline to follow for cutting. I was looking for a remove and replace option. I will get the motor first then I will cut it as instructed. Thanks for your help.
turnipfish
Alias (AKA): JTD
Postby fungus2k » August 3rd 2009, 12:25pm
before you change all that i'd suggest checking the blower motor resistor, it is installed in the air box, turn on the fan and put a meter between the pin in the connector and the negative battery terminal, i thought my blower motor was going so i replaced it, as well as my control module in the van, when it turns out it was just this dang resistor
fungus2k
Years of Membership: fungus2k has been a member for 8 full yearsfungus2k has been a member for 8 full yearsfungus2k has been a member for 8 full yearsfungus2k has been a member for 8 full yearsfungus2k has been a member for 8 full yearsfungus2k has been a member for 8 full yearsfungus2k has been a member for 8 full yearsfungus2k has been a member for 8 full years
Return to Climate Control
It is currently May 28th 2017, 3:58pm
Climate Control Forum
Jawon
in Climate Control
Comments: 50
Time: 3:02am
Jawon
in Climate Control
Comments: 50
Date: May 26 '17
Time: 4:30am
stanvalp
in Climate Control
Comments: 42
Date: May 25 '17
Time: 11:45pm
Comments: 50
Date: May 24 '17
Time: 9:00am
Comments: 50
Date: May 23 '17
Time: 11:25pm
