No Rear Heat
No Rear Heat
Postby Fingaluna [OP] » January 30th 2008, 7:06am
Hi All,
The rear heat in my 98 Extended is down. The fan blows nice & hard, but there's no heat. There is heat in the front (although the fan is weak, likely a resistor issue) so no worries there!
Any advice?
Thanks,
Matt
1998 Astro 4.3 Extended
1994 Biodiesel Jetta (the Baconcar)
1981 Yamaha Virago 750
1965 Vespa 100
& 2 1972 1/16th Horsepower feet
Fingaluna
Years of Membership: Fingaluna has been a member for 5 full yearsFingaluna has been a member for 5 full yearsFingaluna has been a member for 5 full yearsFingaluna has been a member for 5 full yearsFingaluna has been a member for 5 full years
Re: No Rear Heat
Postby chemist » January 31st 2008, 12:55am
Check your hoses, and check your heater core. The heater core is under the dash. Have you smelled a coolant odor in your cabin ever?
chemist
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: chemist has been a member for 5 full yearschemist has been a member for 5 full yearschemist has been a member for 5 full yearschemist has been a member for 5 full yearschemist has been a member for 5 full years
Topics: 26
Re: No Rear Heat
Postby coolen » January 31st 2008, 12:36pm
there is a valve under your van that regulates the rear heat. this is a common problem.
coolen
Years of Membership: coolen has been a member for 5 full yearscoolen has been a member for 5 full yearscoolen has been a member for 5 full yearscoolen has been a member for 5 full yearscoolen has been a member for 5 full years
Re: No Rear Heat
Postby e7ats » February 5th 2008, 2:53am
Coolen is on the right track. Inspect the 2 vacuum lines that run from the fire wall down to the valve. Lots of times they will rot and cause the valve to stay closed.
e7ats
Years of Membership: e7ats has been a member for 5 full yearse7ats has been a member for 5 full yearse7ats has been a member for 5 full yearse7ats has been a member for 5 full yearse7ats has been a member for 5 full years
Topics: 5
Extra Info: 4.3 X AWD
Re: No Rear Heat
Postby MusicETC » February 6th 2008, 12:52am
Does anyone have pictures of the valve in question??
2000 GMC Safari
MusicETC
Years of Membership: MusicETC has been a member for 5 full yearsMusicETC has been a member for 5 full yearsMusicETC has been a member for 5 full yearsMusicETC has been a member for 5 full yearsMusicETC has been a member for 5 full years
Re: No Rear Heat
Postby nitropyro » February 8th 2008, 3:25am
you have 2 heater cores the second behind driver seat on wall behind plastic panels my friends just went bad. he had no heat wet carpet he said under 1 hour to have it fixed.
Danny
Danny Allen 21 years old
columbus ohio
Ratstro- 402 bbc bagged astro work in progress
nitropyro
Years of Membership: nitropyro has been a member for 5 full yearsnitropyro has been a member for 5 full yearsnitropyro has been a member for 5 full yearsnitropyro has been a member for 5 full yearsnitropyro has been a member for 5 full years
Alias (AKA): nitropyro666
Re: No Rear Heat
Postby coolen » February 8th 2008, 1:35pm
i'll snap a pic of the valve sometime today. then i'll post it for you so u know what you're looking at.
coolen
Re: No Rear Heat
Postby Fingaluna [OP] » February 8th 2008, 8:03pm
Hi Folks,
Thanks for the suggestions so far. I would like to check the vac lines first. Trouble is I don't know what to look for... Any pointers? Do I need to remove the doghouse or any covers? Once I'm in there, what am I looking for? Are they rubber? Anyone have any pics?
Thanks!
1965 Vespa 100
Fingaluna
I've lost mine too.....
Postby andys » February 11th 2008, 7:04pm
99 AWD. 175 kms.
Camping in the winter. Van at idle for 1 hour+. Made a popping noise. Van filled with smoke/electrical fire smell. Turned off. Looked for fire. No fire. Turned on and looked for abnormalities. No hot air coming out the rear heater!!! We need this back asap or we'll be a soggy mess.
Any ideas?
I'll check the switch and vacuum lines once the pics are posted. My confusion is why the burning smell?
I have access to a warm garage Tuesday night. Any parts I should be buying in the meantime? I can't really get under to take a look until after I visit a car wash. My van is covered with snow and mud everywhere!!!
andys
Years of Membership: andys has been a member for 5 full yearsandys has been a member for 5 full yearsandys has been a member for 5 full yearsandys has been a member for 5 full yearsandys has been a member for 5 full years
Re: No Rear Heat
Postby andys » February 13th 2008, 9:01am
*FIXED* sorta
On my 99 awd there is a vacum controlled water valve under the hood. It's just to the left of the alternator pulley.
The water valve also has a small vacum solenoid attached to it. My solenoid burnt up. THe solenoid switches vacuum to the water valve. I removed the solenoid and connected its two small vacuum lines togehter making a full-time vacuum to the valve.
Heat is back!
andys
Re: No Rear Heat
Postby timelessbeing » May 21st 2008, 7:17am
I have the exact same problem. I went to the dealer today and they don't sell the solenoid separately. You have to get the whole aux heater water shut-off valve assembly for $200. I'm hoping something like http://www.clarksol.com/html/prodspecsKSV2Way_Valve.cfm will do the trick.
2000 Astro AWD Passenger
4.3L CSFI V6 • 3.73 G80 • 4" OV lift • 30" AT tires
timelessbeing
Years of Membership: timelessbeing has been a member for 5 full yearstimelessbeing has been a member for 5 full yearstimelessbeing has been a member for 5 full yearstimelessbeing has been a member for 5 full yearstimelessbeing has been a member for 5 full years
Topics: 38
Extra Info: Lifted AWD 4.3
Re: No Rear Heat
Postby timelessbeing » June 22nd 2008, 9:37pm
By the way, here is a photo of the valve in question.
timelessbeing
Topics: 38
Re: No Rear Heat
Postby bkzxclusive » November 4th 2008, 3:12pm
where under the dash is the heater core, I'm having heating and AC prob. my AC would only work rite after i recharged it, im guessing theres a leak here but my heat just went out and i cant seem to find the prob.
2000 ASTRO AWD
bkzxclusive
Years of Membership: bkzxclusive has been a member for 4 full yearsbkzxclusive has been a member for 4 full yearsbkzxclusive has been a member for 4 full yearsbkzxclusive has been a member for 4 full years
Topics: 27
Re: No Rear Heat
Postby bkzxclusive » November 11th 2008, 7:34pm
Hey I also have this prob. but i have additions to this prob. wen i turn on my rear AC only the top vents in the bak go on nice and cold, and wen i turn on my rear heat, only my bottom vent behind the drivers seat starts to blow COLD also, its sounds lik a really confusing prob.
2000 ASTRO AWD
bkzxclusive
Topics: 27
Re: No Rear Heat
Postby speedy266 » July 14th 2009, 1:49am
I connected the two small vacume lines to each other as well. Having full heat all the time going to the rear, with only controling the rear fan speed. Is this ok to do? Would any other problems arise from this setup?
speedy266
Years of Membership: speedy266 has been a member for 4 full yearsspeedy266 has been a member for 4 full yearsspeedy266 has been a member for 4 full yearsspeedy266 has been a member for 4 full years
Extra Info: LS
Return to Climate Control
It is currently June 19th 2013, 9:58am
Climate Control Forum
Sailing_Faith
in Climate Control
Comments: 9
Date: Jun 07 '13
Time: 3:12pm
Lanceosh
in Climate Control
Date: Jun 01 '13
Time: 1:09am
Attached by: chevymaher
in Climate Control
Comments: 160
Date: May 09 '13
Time: 2:01am
deleteitall
in Climate Control
Date: May 07 '13
Time: 6:42pm
Drummernaut
in Climate Control
Date: Apr 15 '13
Time: 12:08am
Users browsing this forum: Google Adsense [Bot] and 2 guests
