Accumulator Freezing Over
Postby Quarterwave [OP] » August 16th 2009, 12:50am
Hi all,
I'm the new owner of a 1996 Astro - 4.3 L auto - and are having a problem with my AC. After having it on for around 30 mins, the AC air coming from the vents decreases rapidly, so I checked all of the air vacuum hoses for a leak, and they seem to be ok.
The abnormal thing that caught my eye, was that the AC accumulator was completely covered in white ice - is this normal ? As I've never noticed it on my other cars in the past.... if so, could this be the source of my AC problem ?
FWEIW, whenever I start the van the next day, the AC is back to working as it should....
One last thing - I've noticed that when set to MAX AC, it takes less time for the problem to occur....
Thanks in advance for any help !
Quarterwave
Years of Membership: Quarterwave has been a member for 3 full yearsQuarterwave has been a member for 3 full yearsQuarterwave has been a member for 3 full years
Topics: 20
Extra Info: 4.3 V6 Auto
Re: Accumulator Freezing Over
Postby Big_kid » August 16th 2009, 8:07pm
Check the charge, you might be low on refrigerant.
Firing on 3 Cylinders (L4)
Years of Membership: Big_kid has been a member for 5 full yearsBig_kid has been a member for 5 full yearsBig_kid has been a member for 5 full yearsBig_kid has been a member for 5 full yearsBig_kid has been a member for 5 full years
Topics: 66
Images: 39
Extra Info: 2WD conversion
Postby gtkane » August 17th 2009, 3:39am
The low pressure cycling switch is stuck closed.
Change it.(and you don't have to suck the refrigerant out to do it.)
User album #4...check it out!
gtkane
Years of Membership: gtkane has been a member for 5 full yearsgtkane has been a member for 5 full yearsgtkane has been a member for 5 full yearsgtkane has been a member for 5 full yearsgtkane has been a member for 5 full years
Alias (AKA): Astruck
Extra Info: nasty 4.3
Postby Big_kid » August 17th 2009, 2:29pm
Makes sense!
Topics: 66
Images: 39
Postby Quarterwave [OP] » August 17th 2009, 3:43pm
Thanks GT Kane - can you pls adv. how I can do that - ie : where is the switch located ? Is it on the compressor ? Is there any pressure in this part of the system that I need to know about ?
Also - do you think that this could be a source of a battery-charge draining problem that I have been having ? (even when the van is turned off ?)
Thanks again for your help.
Quarterwave
Topics: 20
Postby gtkane » August 23rd 2009, 1:51am
It won't cause a battery drain issue-sorry!
It is located on the accumulator(aluminum can-looking thing), and has 2 wires going to it. Just unscrew it with a 9/16 wrench. No refrigerant will escape.
gtkane
Postby Quarterwave [OP] » August 31st 2009, 7:54pm
Just a follow up on this one. After not being able to solve this problem, I took the van to my local auto electrician, where he diagnosed a problem with the AC relay. It seems that I was pulling the correct one that corresponded with the diagram on the inside of the fuse box, but after looking @ the schematic, it was the wrong relay to check.
So.... it seems that the dealer I bought it from had opened the relay and put in a thin, flat piece of wire near the bottom of it, which bypassed it's "turn off" function. As soon as the electrician pulled the piece of metal out, and turned the HVAC control in the cabin to "OFF", the compressor stopped spinning and the ice went with it.
After replacing the relay with a new one, the compressor started cycling as it should. We were unable to diagnose why the dealer would do that to the relay, as again, the AC is working as it should (at least for now), but I will continue to keep an eye on it for a while.
Thanks again for all of the responses to my post.
Quarterwave
Topics: 20
Postby Big_kid » September 1st 2009, 12:44am
Good find!
Thanks for the update.
Topics: 66
Images: 39
Return to Climate Control
It is currently June 18th 2013, 8:04am
Climate Control Forum
Sailing_Faith
in Climate Control
Comments: 9
Date: Jun 07 '13
Time: 3:12pm
Lanceosh
in Climate Control
Date: Jun 01 '13
Time: 1:09am
Attached by: chevymaher
in Climate Control
Comments: 160
Date: May 09 '13
Time: 2:01am
deleteitall
in Climate Control
Date: May 07 '13
Time: 6:42pm
Drummernaut
in Climate Control
Date: Apr 15 '13
Time: 12:08am
