Coolant leak from intake...
Postby dacosta [OP] » October 20th 2009, 4:00am
I recently replaced the radiator, and water pump on my 2000. I check for leaks with a rad pressure tester. I got some leakage from the front corner of the intake. Very small and under about 15lbs of pressure. I dont want to ask how difficult it will be to remove the intake. It is not leaking into the engine - only out the front and down the block. There is a small water stain on the side of theblock - so I dont think it is very bad. However I am going on a trip soon and was wondering if I should run the van with the cap vented or shoudl I switch it to lower pressure cap - maybe 7lb or something like that? Please advise. Thanks Dan
dacosta
Years of Membership: dacosta has been a member for 7 full yearsdacosta has been a member for 7 full yearsdacosta has been a member for 7 full yearsdacosta has been a member for 7 full yearsdacosta has been a member for 7 full yearsdacosta has been a member for 7 full yearsdacosta has been a member for 7 full years
Topics: 5
Alias (AKA): Dan
Extra Info: LT 4.3 2WD
Re: Coolant leak from intake...
Postby astroturf » October 20th 2009, 5:44am
dacosta,
Lowering your caps pressure will only lower your coolants boiling point.
Fix it right, carry plenty of water, enroll in a AAA towing program.
You pick.
Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby astro355 » October 21st 2009, 3:02pm
I would also have to vote on the fix it right idea. Lowering your boiling point would not be a good idea, especially since you have a leak.
You could try a "snake oil" block type sealant that may help. But going on a long road trip, I'd fix it right.
astro355
Firing on 4 Cylinders (L6)
Year: 1989
Extra Info: 355 V8 700R4
Postby rev_les » October 22nd 2009, 1:16am
X3 on the fix it right, if things are half clogged up to start with, the stop leak can gum it up worse.
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 7 full yearsrev_les has been a member for 7 full yearsrev_les has been a member for 7 full yearsrev_les has been a member for 7 full yearsrev_les has been a member for 7 full yearsrev_les has been a member for 7 full yearsrev_les has been a member for 7 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby ZABUCH1 » December 28th 2009, 10:41pm
NEED HELP LOSING COOLANT ,CANT FIND WERE NO DRIPPING ON GROUND JUST GONE MYBE A GALLON EVERY 2 WEEKS 2000 GMC SAFARI AWD :confused:
ZABUCH1
Years of Membership: ZABUCH1 has been a member for 7 full yearsZABUCH1 has been a member for 7 full yearsZABUCH1 has been a member for 7 full yearsZABUCH1 has been a member for 7 full yearsZABUCH1 has been a member for 7 full yearsZABUCH1 has been a member for 7 full yearsZABUCH1 has been a member for 7 full years
Alias (AKA): BOLO
Extra Info: 4.3L AWD
Postby kellowatt » January 6th 2010, 6:36pm
rev_les wrote:X3 on the fix it right, if things are half clogged up to start with, the stop leak can gum it up worse.
X4 on that. The gasket is disintegrating.. soon it will be pouring out.
kellowatt
Years of Membership: kellowatt has been a member for 7 full yearskellowatt has been a member for 7 full yearskellowatt has been a member for 7 full yearskellowatt has been a member for 7 full yearskellowatt has been a member for 7 full yearskellowatt has been a member for 7 full yearskellowatt has been a member for 7 full years
Alias (AKA): kellowatt
Extra Info: SLT4.3L V6 AWD
Postby kellowatt » January 6th 2010, 6:38pm
ZABUCH1 wrote:NEED HELP LOSING COOLANT ,CANT FIND WERE NO DRIPPING ON GROUND JUST GONE MYBE A GALLON EVERY 2 WEEKS 2000 GMC SAFARI AWD :confused:
See my post (#7) here... might help http://www.astrosafari.com/viewtopic.php?f=34&t=5637&p=42440#p42440
kellowatt
Return to Climate Control
It is currently February 23rd 2017, 9:43pm
Climate Control Forum
Rookie162
in Climate Control
Comments: 34
Time: 2:07am
Rinny
in Climate Control
Comments: 28
Date: Jan 23 '17
Time: 2:40pm
Comments: 29
Date: Dec 22 '16
Time: 2:51am
Colorado Tim
in Climate Control
Date: Dec 15 '16
Time: 5:21am
Colorado Tim
in Climate Control
Date: Dec 15 '16
Time: 5:18am
