no vacuum to heater control valve problem on 02
Postby Vinnie6 [OP] » December 10th 2009, 5:43am
Trying to troubleshoot a low-heat situation. Thought I had it licked, but I was still not happy with the amount of heat I am getting on the floor. Tonight I made a major breakthrough. I'll cut to the chase: no vacuum to the heater control valve. Obviously the next step is to find out why. The vacuum line is really thin and goes straight to the firewall, so the problem must be up inside the dash. It's a 2002 Astro. Any ideas as to what I need to do to troubleshoot this? I have absolutely no experience in this area. I am making a really big assumption here - bordering on sounding stupid - but, the heater control valve is supposed to open when the heat is turned up, right?
Vinnie6
Years of Membership: Vinnie6 has been a member for 7 full yearsVinnie6 has been a member for 7 full yearsVinnie6 has been a member for 7 full yearsVinnie6 has been a member for 7 full yearsVinnie6 has been a member for 7 full yearsVinnie6 has been a member for 7 full yearsVinnie6 has been a member for 7 full years
Topics: 13
Extra Info: LS RWD
  • Heater control valve hose
    by gordo999 » March 16th 2017, 2:17am in Climate Control
    Last post by gordo999 View the latest post
    March 16th 2017, 5:04am
  • Heater Control Valve, Hoses, W/Aux Heat
    by speedway73 » April 16th 2017, 6:16am in Climate Control
    Last post by dramey View the latest post
    April 19th 2017, 1:17am
    85
    April 24th 2017, 2:30am
Re: no vacuum to heater control valve problem on 02
Postby Vinnie6 [OP] » December 12th 2009, 7:18am
Well, here is my update: In trying to solve my low-heat situation, I went looking for vacuum line problems - found nothing wrong anywhere. Pulled the doghouse even. THEN I was under the hood again looking at vacuum hoses. That is when I found the hose that goes to the vacuum ball had somehow come off the vacuum ball. It went back on, but is plenty cracked and needs replacing. I also learned that it is the COOL setting that opens the heater control valve - when your temp is set to hot, the valve stays closed. I wish I had learned these things before taking things all apart! I have no vacuum problems. Everything seems to be working as it should. I went for a drive before putting the doghouse back on to see how much heat I would have. Now that was an experience! Reminded me of the motorcycle days. That is one loud engine when under load! Cool! Wish I could always listen to that. I seem to have normal heat now, but won't know for sure until I get her on the road for few miles. The burning question is - can a vacuum hose coming off the vacuum ball cause a reduced heat situation? Anyone know the answer?
Vinnie6
Topics: 13
Extra Info: LS RWD
Postby Vinnie6 [OP] » December 12th 2009, 7:50pm
Still low heat. I'm going to replace the heater core later today. Everything else is working PERFECTLY.
Vinnie6
Topics: 13
Extra Info: LS RWD
Postby Vinnie6 [OP] » December 13th 2009, 7:11am
Wasn't the heater core either. Still not blasting heat like I am accustomed to. Tomorrow I will change out the heater control valve even though it works. Maybe it's plugged. Seems to be a common occurrence from my reading other topics. That's all that's left to try.
Vinnie6
Topics: 13
Extra Info: LS RWD
Postby jeff's93astro » December 13th 2009, 7:18am
where does your temp guage sit your thermostat could be sticking open or opening to soon making the motor run cooler and make you have low heat
88 Silverado 5.7L RWD 284,000 miles (going 383 soon)
93 Astro CS 4.3L RWD 230,000 miles (89 Astro 4.3)
jeff's93astro
Firing on 1 Cylinder (L2)
Years of Membership: jeff's93astro has been a member for 7 full yearsjeff's93astro has been a member for 7 full yearsjeff's93astro has been a member for 7 full yearsjeff's93astro has been a member for 7 full yearsjeff's93astro has been a member for 7 full yearsjeff's93astro has been a member for 7 full yearsjeff's93astro has been a member for 7 full years
Topics: 53
Extra Info: CS 4.3L V6 RWD
Postby Vinnie6 [OP] » December 13th 2009, 4:03pm
Jeff,
Thanks for asking. It's one dash to the left of 210.
Vinnie6
Topics: 13
Extra Info: LS RWD
Postby Vinnie6 [OP] » December 13th 2009, 9:42pm
Well, I put in a new heater control valve. Not an easy task! 90% of the time is spent getting the pliars on the hose clamps and moving them. I previously found some very crumbly old vacuum lines around the rear heat solenoid looking thing and the air canister ball, so those are replaced now. The old heater control valve, however, looked great. It was clean as can be on the inside. After putting things back together, I went for a drive and the heat was fluxuating between warm and cold. Air has to work its way out of the cooling system. I tend to believe it was air in the heater core all along. In the last five days I have removed and inspected the heat controls in the dash, removed the dog house and inspected vacuum lines, replaced the heater core, and replaced the heater control valve. I still do not have heat like I used to, before the dealer replaced my thermostat. What else can it be?
Vinnie6
Topics: 13
Extra Info: LS RWD
Postby jeff's93astro » December 14th 2009, 1:34am
i believe you may just have air in the system get the front end up in the air while its cold take rad cap off and crank it and see if you can get some of the air out
jeff's93astro
Topics: 53
Postby wob1 » March 24th 2013, 2:30pm
I had similar issue ...had to replace all the vaccum pipes even the one that goes to the vac ball near the RHS wheel hub (remove inner wing protector) to get to this as was fully perished when I got to it ...now heater works fine and can now adjust from screen to in car and also foot well directions. Replace all the pipes in the engine bay first.
Cheers Wob1
wob1
Years of Membership: wob1 has been a member for 4 full yearswob1 has been a member for 4 full yearswob1 has been a member for 4 full yearswob1 has been a member for 4 full years
Alias (AKA): wob
Year: 1997
Extra Info: 4.3 GMC Aerotech 4x4
Postby swharris » April 11th 2013, 5:57pm
Check for LOW coolant level in the cooling system. I had that happen once. Had a leak in a heater hose. Most of the coolant had leaked out and I had no idea. The only way I noticed it, was because the heater stopped blowing hot air continuously. It would work briefly when I rounded a corner, and it dawned on me that coolant was only getting to the core intermittently. Haha. Truck was not over heating because it was the middle of winter.
swharris
Years of Membership: swharris has been a member for 7 full yearsswharris has been a member for 7 full yearsswharris has been a member for 7 full yearsswharris has been a member for 7 full yearsswharris has been a member for 7 full yearsswharris has been a member for 7 full yearsswharris has been a member for 7 full years
Topics: 81
Images: 4
Alias (AKA): S4
Extra Info: 4.3 Vortec 2wd
Postby redfury » April 12th 2013, 12:50am
Do you get more heat when the engine RPM's are higher?
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Year: 1998
Extra Info: LT 5.7L 4wd
Postby Don1806 » April 14th 2013, 2:20am
Based on my experiences with a 99, it can be a couple of things. Low coolant / air in system that still needs to be burped out, cracks in a vacuum elbow if the lines are good. The elbows get microscopic cracks in them that you cant see without really manipulating them, but when the temp gets hot under the hood the cracks expand and cause a vacuum leak.
My Astro runs nowhere near that hot. What temp thermostat did they put in and is it opening and closing as it should? Since that's when your problem started, that would be my prime suspect along with air in the system.
99 Astro LT - Orginal Owner.
Don1806
Years of Membership: Don1806 has been a member for 6 full yearsDon1806 has been a member for 6 full yearsDon1806 has been a member for 6 full yearsDon1806 has been a member for 6 full yearsDon1806 has been a member for 6 full yearsDon1806 has been a member for 6 full years
Topics: 12
Images: 2
Alias (AKA): Don
Year: 1999
Extra Info: AWD 170K
Postby Leeann_93Leeann_93 is online! » April 14th 2013, 3:15am
One dash to the left of 210° is correct. They take a 195° t-stat.
'00 Astro LS AWD vin W - WIP
Image Image
Topics: 27
Year: 2002
Extra Info: LS 4.3L AWD
Return to Climate Control
It is currently April 24th 2017, 2:30am
Climate Control Forum
nubetoob
in Climate Control
Time: 8:08pm
Attached by: dramey
dramey
in Climate Control
Comments: 9
Date: Apr 19 '17
Time: 12:58am
Attached by: Nomad
Nomad
in Climate Control
Date: Apr 16 '17
Time: 3:37am
Attached by: MI_Ghost
MI_GhostMI_Ghost is online!
in Climate Control
Comments: 38
Date: Apr 03 '17
Time: 1:44am
Astrodawn
in Climate Control
Comments: 38
Date: Mar 31 '17
Time: 5:27am
