'99 ASTRO AC/HEAT PROBLEMS
Postby dirtydeeogee [OP] » April 16th 2010, 3:47pm
:arrow: OK,HERES MY PROB....MY AC/HEAT ONLY BLOWS OUT FROM THE DEFROST VENT NEAR THE WINDSHIELD,NONE OF THE VENTS ON THE PASSENGER SIDE OR DRIVER SIDE BLOW ANY AIR OUT AND NEITHER DO THE AIR DUCTS BEHIND THE TWO FRONT SEATS((THE ONES BEHIND THE SEATS NEVER BLEW ANY AIR OUT SINCE I BOUGHT THE VAN)) BUT THE OTHERS STOPPED BLOWIN RECENTLY AND WHEN I WANNA USE THE AC/HEAT I HAVE TO PUT IT ON FULL BLAST SO THAT IT I GET PROPER AC/HEAT INSIDE,IM TIRED OF THIS AND WANT TO FIX THIS PROBLEM SOON AS POSSIBLE. :banghead:
dirtydeeogee
Years of Membership: dirtydeeogee has been a member for 6 full yearsdirtydeeogee has been a member for 6 full yearsdirtydeeogee has been a member for 6 full yearsdirtydeeogee has been a member for 6 full yearsdirtydeeogee has been a member for 6 full yearsdirtydeeogee has been a member for 6 full years
Alias (AKA): dirtydog
  • Heat issues 99 astro
    by KennTower » February 12th 2017, 12:06am in Climate Control
    Last post by kennysmoke View the latest post
    February 19th 2017, 1:54am
  • How to Keep Van Cool in the Heat?
    by jacksonsullivan » February 7th 2017, 1:39am in Climate Control
    February 7th 2017, 11:52pm
    9
    55
    February 24th 2017, 4:37am
Re: '99 ASTRO AC/HEAT PROBLEMS
Postby LEVE » April 16th 2010, 3:55pm
I'd be looking at a vacuum control line that's leaking, that controls the blend door. Hopefully someone with a better Vacuum Diagram for your year will chime in and post it. Here's what I've found:
1999 Safari Heater/AC Vacuum Diagram
LEVE
Years of Membership: LEVE has been a member for 6 full yearsLEVE has been a member for 6 full yearsLEVE has been a member for 6 full yearsLEVE has been a member for 6 full yearsLEVE has been a member for 6 full yearsLEVE has been a member for 6 full years
Topics: 18
Extra Info: AWD 4.3L-W
Postby Leeann_93 » April 17th 2010, 12:30am
Since you've been asked politely to stop using caps lock, I will explain why. Online, using all caps is considered shouting and is rude. Besides, it's harder to read. Please, please stop using all caps.
'00 Astro LS AWD vin W - WIP
Image Image
Topics: 27
Year: 2002
Extra Info: LS 4.3L AWD
Postby Astroplane » April 17th 2010, 4:48am
There is a ton of info in this forum, some with pictures! Check out the vacuum lines as LEVE said and X2 on the CAPS. If there is a reason for caps all the time, please let us know.
Astroplane
Blue Status (L2)
Blue Status (L2)
Years of Membership: Astroplane has been a member for 7 full yearsAstroplane has been a member for 7 full yearsAstroplane has been a member for 7 full yearsAstroplane has been a member for 7 full yearsAstroplane has been a member for 7 full yearsAstroplane has been a member for 7 full yearsAstroplane has been a member for 7 full years
Extra Info: LT RWD
Return to Climate Control
It is currently February 24th 2017, 4:37am
Climate Control Forum
Rookie162
in Climate Control
Comments: 34
Date: Feb 22 '17
Time: 2:07am
Rinny
in Climate Control
Comments: 28
Date: Jan 23 '17
Time: 2:40pm
Comments: 29
Date: Dec 22 '16
Time: 2:51am
Colorado Tim
in Climate Control
Date: Dec 15 '16
Time: 5:21am
Colorado Tim
in Climate Control
Date: Dec 15 '16
Time: 5:18am
Users browsing this forum: Bing [Bot] and 1 guest
