by jomarche [OP] » June 11th 2010, 2:20pm
by remark123 » June 11th 2010, 3:47pm
by jomarche [OP] » June 11th 2010, 3:55pm
by GaryZ » June 11th 2010, 5:00pm
by LEVE » June 11th 2010, 5:15pm
by jomarche [OP] » June 11th 2010, 8:10pm
by remark123 » June 11th 2010, 8:50pm
by rev_les » June 12th 2010, 12:13am
by jomarche [OP] » June 12th 2010, 1:35am
by Astroplane » June 12th 2010, 9:04am
jomarche wrote:3 rd time in this van for the compressor.
jomarche wrote:1. Anyway specs say 11 oz of PAG 150 ? How do I introduce the PAG 150 via pressurized freon cans, or pour it into something, how? compressor has 1.5 oz of PAG from factory.
jomarche wrote:2. AND 3lbs of freon, ? Do I count the weight of the PAG freon if I use PAG freon?
jomarche wrote:3. ? In using the 12oz freon cans is that 12oz liquid or weight?
jomarche wrote:but 3 compressor in 4 years i want to be a bit more precise.
jomarche wrote:Any ideas on the PAG 150 which it calls for 11oz.......is that added into the 3lbs weight.....when the PAG is ia freon can?????
by jomarche [OP] » June 12th 2010, 2:43pm
Astroplane wrote:jomarche wrote:3 rd time in this van for the compressor.
What is the history of your van/ A/C system? Have you replaced 2 compressors after the factory compressor failed? Have the failures been catastrophic (plugging the orifice tube), clutch failure, or just leaks from the compressor?
A.... 2 after the factory , thought they were clutch (smoke an all),BUT this time found so much metal frag in orifice screen that i could not get it out.jomarche wrote:1. Anyway specs say 11 oz of PAG 150 ? How do I introduce the PAG 150 via pressurized freon cans, or pour it into something, how? compressor has 1.5 oz of PAG from factory.
Did you replace the accumulator? Did you drain the old accumulator and measure the oil amount? We need a starting point to determine the oil charge. There is oil throughout the system that needs to be accounted for.
A.......replace accumulator, NO oil in it.jomarche wrote:2. AND 3lbs of freon, ? Do I count the weight of the PAG freon if I use PAG freon?
If the system spec is 11 ounces of PAG oil and 48 ounces of R134a, that is what the system requires. It is recommended to measure drained oil amounts from removed components and adjust the replacement oil charge accordingly.
a......NO measurement and blow 5-6 oz out i would guess.....jomarche wrote:3. ? In using the 12oz freon cans is that 12oz liquid or weight?
Weight.jomarche wrote:but 3 compressor in 4 years i want to be a bit more precise.
Over the years, cans have received a bad name. According to the gurus, it is impossible to charge a system spec of 48 ounces with 4 12 ounce cans. I agree with their assessment, but in my experience, the final result is close enough. More important, have you installed a screen in the suction port of the manifold hose set? The manifold hose set has 'mufflers' on both hoses that will trap debris from a failed compressor. Have you ever replaced the condenser?jomarche wrote:Any ideas on the PAG 150 which it calls for 11oz.......is that added into the 3lbs weight.....when the PAG is ia freon can?????
No. What is the net weight according to the labeling? 12 ounces refrigerant with 3 ounces of oil?
by Astroplane » June 13th 2010, 8:10am
by Matrixx » June 13th 2010, 11:51am
by jomarche [OP] » June 13th 2010, 5:50pm
by 94 Van Guy » June 13th 2010, 8:33pm
by Astroplane » June 14th 2010, 9:30am
jomarche wrote:DONE
It is currently May 18th 2013, 6:56pm
| Climate Control Forum |
| Previous topic Next topic |
| Recent Image Attachments | |||
| Sponsors |
