No front heat/air but rear works fine
Postby Wizard16 [OP] » November 3rd 2010, 12:19pm
My front defrost/heat & air will not work but my rear air and heat work fine. I don't think it is my blower since it blowing in the back of the van. Any ideas on what would make this happen?
Wizard16
Years of Membership: Wizard16 has been a member for 6 full yearsWizard16 has been a member for 6 full yearsWizard16 has been a member for 6 full yearsWizard16 has been a member for 6 full yearsWizard16 has been a member for 6 full yearsWizard16 has been a member for 6 full years
  • Everything works but no cold air
    by RadRon14 » May 16th 2017, 6:51pm in Climate Control
    Last post by Astro Pop View the latest post
    May 17th 2017, 7:33pm
  • Rear AC/ REAR heat switch swap
    by Rookie162 » January 28th 2017, 6:47pm in Climate Control
    Last post by 1lowcab1lowcab is online! View the latest post
    March 11th 2017, 2:55am
    87
    May 28th 2017, 4:02am
Re: No front heat/air but rear works fine
Postby mkj54 » November 3rd 2010, 4:08pm
There should be two separate blower motors with two separate switches. If the front one isn't working, you could start by checking the fuses. I think checking with a test lite works best. If the fuses are good, check for power and ground at the blower motor under the hood, with the key on and blower on high. Here's a link to a picture if it helps.
http://www.chiltonlibrary.com/pvt/Conte ... ?ca=Repair
mkj54
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: mkj54 has been a member for 6 full yearsmkj54 has been a member for 6 full yearsmkj54 has been a member for 6 full yearsmkj54 has been a member for 6 full yearsmkj54 has been a member for 6 full yearsmkj54 has been a member for 6 full years
Postby astroturf » November 3rd 2010, 5:08pm
Welcome Aboard.
Hope it works out for you.
Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby Wizard16 [OP] » November 3rd 2010, 10:46pm
mjk54 I could not open the picture of where the ground is on the blower. Can you resend please?
Wizard16
Postby astroturf » November 3rd 2010, 11:06pm
Wizard16,
Have a look at this:
2000 heater wiring diagram.pdf
Hope it helps, Jim
astroturf
Topics: 112
Postby mkj54 » November 3rd 2010, 11:20pm
Try this one. Look under heating, ventilation, and air conditioning. It shows both motors, but the caption is wrong for the one your looking for. It's on the passenger side out under the hood. The picture isn't too good but that's basically what it looks like. IIRC the hot wire is purple and there should be a black ground wire on a spade connector attached to one of the mounting bolts.
mkj54
Fueling (7/8 tank)
Fueling (7/8 tank)
Postby astroturf » November 3rd 2010, 11:27pm
mkj54 wrote:http://www.chiltonlibrary.com/pvt/ContentDelivery.aspx?ca=Repair
This is what comes back from your link:
WELCOME!
To access the ChiltonLibrary database, please contact your local library to determine if ChiltonLibrary is available.
If you are a library looking for more information about offering ChiltonLibrary, click here for more information.
If you are interested in learning more about all the great products that Chilton offers, click here.
astroturf
Topics: 112
Postby mkj54 » November 4th 2010, 2:25pm
Try this one.
http://content.chiltonsonline.com/conte ... 266p02.pdf
It's a picture under the hood on the passenger side, showing the wires to be tested.
mkj54
Fueling (7/8 tank)
Fueling (7/8 tank)
Postby earlman » November 8th 2010, 5:45pm
Sounds like your front blower motor is shot. rockauto.com Remember, cheap equalls noisy motor
earlman
Years of Membership: earlman has been a member for 7 full yearsearlman has been a member for 7 full yearsearlman has been a member for 7 full yearsearlman has been a member for 7 full yearsearlman has been a member for 7 full yearsearlman has been a member for 7 full yearsearlman has been a member for 7 full years
Images: 4
Extra Info: LT 4.3L V6 RWD
Return to Climate Control
It is currently May 28th 2017, 4:02am
Climate Control Forum
Jawon
in Climate Control
Comments: 45
Time: 3:02am
Jawon
in Climate Control
Comments: 45
Date: May 26 '17
Time: 4:30am
stanvalp
in Climate Control
Comments: 42
Date: May 25 '17
Time: 11:45pm
Comments: 45
Date: May 24 '17
Time: 9:00am
Comments: 45
Date: May 23 '17
Time: 11:25pm
