96 Astro Van Heating
Postby Astro-Hunter [OP] » December 5th 2010, 12:36am
My 96 Astro Van heater does not get hot. The air direction controls work fine. As the temp wasn't getting to the normal operating temp I had the thermostat changed. Now it gets to the normal range and I can tell when it opens and closes. So far so good. Here is the problem. Only one of the heater hoses gets hot. I figured it was a clogged heater core so I pulled the hoses and flushed the core. Well the water from the garden hose just zipped right on through the heater core. The only thing that came out was fresh coolant at first then lots of water. I don't know how to tell if the issue is with the diverter valve or the heater temp control on the dash. I would truly appreciate any help that anyone can offer. Thanks.
Astro-Hunter
Years of Membership: Astro-Hunter has been a member for 6 full yearsAstro-Hunter has been a member for 6 full yearsAstro-Hunter has been a member for 6 full yearsAstro-Hunter has been a member for 6 full yearsAstro-Hunter has been a member for 6 full yearsAstro-Hunter has been a member for 6 full years
Extra Info: LT AWD 4.3L
  • How to Keep Van Cool in the Heat?
    by jacksonsullivan » February 7th 2017, 1:39am in Climate Control
    March 26th 2017, 3:26am
  • Electric heat with van turned off?
    by Echo » April 22nd 2017, 12:51am in Climate Control
    Last post by Big_kid View the latest post
    April 22nd 2017, 11:36pm
    9
    49
    May 23rd 2017, 9:51pm
Re: 96 Astro Van Heating
Postby chevymaherchevymaher is online! » December 5th 2010, 1:03am
There is a valve with a vacuum line running to it between the engine and heater core.Replacing it and the heat in these vans is still not worth a nickle. Take it out and splice lines together so it gets unrestricted flow and these things got heat like a 60s car it will run you out. you will be turning the heat down soonas the engine temp up more than five minutes.Mine was located directly in front of air box. On newer models they to the right of box downtoward the bottom.I been taking them off alot of vans once the owners see my heat in mine.
Topics: 83
Year: 1994
Postby Astro-Hunter [OP] » December 5th 2010, 2:42am
Thanks for the reply. I hadn't considered doing that. I'll look into it.
Astro-Hunter
Postby Lumpy » November 28th 2011, 6:14am
chevymaher wrote:There is a valve with a vacuum line running to it between the engine and heater core...
Where is this mythical valve on an 89? I've searched from underhood, from wheel well, from under front,
from under behind wheel. I can visualize (I think) all the hose to the heater core. There doesn't seem
to be any valve anywhere.
Is it made of invisible plastic?
Years of Membership: Lumpy has been a member for 7 full yearsLumpy has been a member for 7 full yearsLumpy has been a member for 7 full yearsLumpy has been a member for 7 full yearsLumpy has been a member for 7 full yearsLumpy has been a member for 7 full yearsLumpy has been a member for 7 full years
Year: 1989
Postby Leeann_93Leeann_93 is online! » November 29th 2011, 2:34am
I'm not sure the valve exists on an '89.
'00 Astro LS AWD vin W - WIP
Image Image
Topics: 27
Year: 2002
Extra Info: LS 4.3L AWD
Postby chevymaherchevymaher is online! » November 29th 2011, 2:41am
Must been removed or as leAnn said never had one.It is listed as being on there,said it was same as mine. :shrug: musta been that invisible stuff.
Topics: 83
Year: 1994
Return to Climate Control
It is currently May 23rd 2017, 9:51pm
Climate Control Forum
JawonJawon is online!
in Climate Control
Comments: 18
Date: Today
Time: 7:45pm
Rinny
in Climate Control
Date: May 19 '17
Time: 6:28pm
Attached by: GreatWhite
GreatWhite
in Climate Control
Date: May 19 '17
Time: 5:49pm
in Climate Control
Comments: 18
Date: May 18 '17
Time: 9:24pm
in Climate Control
Date: May 17 '17
Time: 10:18pm
Users browsing this forum: JawonJawon is online! and 3 guests
