has anybody tried this or at least thought of doing it. thanks
by HOTWHEELS68 [OP] » January 1st 2009, 7:52pm
by AstroAustin » January 2nd 2009, 5:34pm
by HOTWHEELS68 [OP] » January 2nd 2009, 8:53pm
by AstroAustin » January 2nd 2009, 10:29pm
by Astroboy303 » February 1st 2010, 1:39am
by astroturf » February 1st 2010, 3:41am
Astroboy303 wrote:i have done that on about twenty astros and i haven't had any problembs what i did is first drill out the rivits and then cut about an inch out maybe two then slide the eyelet back on center it drill out one hole verry slowly put a grade 8 .5/20/1 bolt with washers through and tighten it then do the second one it takes a little time but it works and i have had one on my van for the past 5 years and no problembs to date http://photos-f.ak.fbcdn.net/photos-ak- ... 436636980_
by Astroboy303 » February 1st 2010, 4:11am
astroturf wrote:Astroboy303 wrote:i have done that on about twenty astros and i haven't had any problembs what i did is first drill out the rivits and then cut about an inch out maybe two then slide the eyelet back on center it drill out one hole verry slowly put a grade 8 .5/20/1 bolt with washers through and tighten it then do the second one it takes a little time but it works and i have had one on my van for the past 5 years and no problembs to date http://photos-f.ak.fbcdn.net/photos-ak- ... 436636980_
Yer LINKY ain't werkin.
by astroturf » February 1st 2010, 2:20pm
Astroboy303 wrote:astroturf wrote:Astroboy303 wrote:i have done that on about twenty astros and i haven't had any problembs what i did is first drill out the rivits and then cut about an inch out maybe two then slide the eyelet back on center it drill out one hole verry slowly put a grade 8 .5/20/1 bolt with washers through and tighten it then do the second one it takes a little time but it works and i have had one on my van for the past 5 years and no problembs to date http://photos-f.ak.fbcdn.net/photos-ak- ... 436636980_
ya i ain't that techy can't figure it out( new here )try this one http://viewmorepics.myspace.com/index.c ... D=27942277
http://viewmorepics.myspace.com/index.c ... D=32477058
by Astroboy303 » February 4th 2010, 6:45am
let me know if you try my way it really works great .HOTWHEELS68 wrote:I just baught a rear roll pan for my safari and the eyelet of the spring is in the way . would it be possible to drill out the rivets ,cut off the end of the spring, then re-attach the eyelet with bolts instead, to make the roll pan workhas anybody tried this or at least thought of doing it. thanks
by astro355 » February 4th 2010, 9:18am
by Astroboy303 » February 5th 2010, 5:51am
by Astroboy303 » February 5th 2010, 6:15am
astro355 wrote:Since you haul a trailer with it, why not replace the fiberglass leafs with the steel ones? As long as the springs were cut right and carefully, it would be a stiffer ride by making the springs shorter but also more rigid (ie brittle). Hauling a trailer with that setup is the only thing that draws my concern.
by astro355 » February 5th 2010, 6:17am
Astroboy303 wrote:astro355 wrote:Since you haul a trailer with it, why not replace the fiberglass leafs with the steel ones? As long as the springs were cut right and carefully, it would be a stiffer ride by making the springs shorter but also more rigid (ie brittle). Hauling a trailer with that setup is the only thing that draws my concern.
Of course it is possibly more fradgile But if i wanted to go that rout than why not go four link it would be allott easier than changing over to steelies (Properly ) but i have been towing on that setup for a long time and i checked it yesterday pulled the hole thing apart and it shows vertually no excessive wear that i have seen when the weather pick's up here i will have to send picks ., the ride changed only when i cut the first set on my first astro i cut too mutch off 3" Rode like crap bagged it and sold it in 95 i have done allott with these astro's and found what i like and what i don't like i drive this astro every where daily i have a great ride NO BAGS go cross country from Kansas to California twice a year whith no problems somtimes even with my vega behind it my wife and kids too i have found this to work verry well .
by Astroboy303 » February 5th 2010, 6:29am
astro355 wrote:Astroboy303 wrote:astro355 wrote:Since you haul a trailer with it, why not replace the fiberglass leafs with the steel ones? As long as the springs were cut right and carefully, it would be a stiffer ride by making the springs shorter but also more rigid (ie brittle). Hauling a trailer with that setup is the only thing that draws my concern.
Putting steel leafs on these vans is a direct bolt-on. 96 and newer vans come with steel leafs. The only thing I would be worried about would be split-ends on the end of the spring you cut. Fiberglass likes to fray like that. But hey, if it works for you, great.
by Gary » February 5th 2010, 4:03pm
by Astroboy303 » February 6th 2010, 4:37am
tha would be cool if i didn't live in redneck hell where there are no real fab shops,the only junkyard is in a guy's backyard or driveway or i have to drive 400 miles to another state the newest car in the junkyard is a 85Jim,yrs ago when I was a kid(kind of hard to believe I was at one time huh-LOL)I worked at a front-end/spring replacement shop called Fry-The-Wheelman.They had a forge and the typical real old guy blacksmith with the hammer and anvil.He would hammer out any leaf spring anyone could ever want and still keep the temper in the spring steel.They had never ever gotten a spring back and he was with them when they opened in the late 1940's.To watch him work was a true work of art.They have since closed up the shop,but for this o/p to find that kind of shop might be a very good long term answer.
by Gary » February 6th 2010, 12:33pm
Astroboy303 wrote:tha would be cool if i didn't live in redneck hell where there are no real fab shops,the only junkyard is in a guy's backyard or driveway or i have to drive 400 miles to another state the newest car in the junkyard is a 85Jim,yrs ago when I was a kid(kind of hard to believe I was at one time huh-LOL)I worked at a front-end/spring replacement shop called Fry-The-Wheelman.They had a forge and the typical real old guy blacksmith with the hammer and anvil.He would hammer out any leaf spring anyone could ever want and still keep the temper in the spring steel.They had never ever gotten a spring back and he was with them when they opened in the late 1940's.To watch him work was a true work of art.They have since closed up the shop,but for this o/p to find that kind of shop might be a very good long term answer.
by Astroboy303 » February 7th 2010, 8:00pm
Gary wrote:Astroboy303 wrote:tha would be cool if i didn't live in redneck hell where there are no real fab shops,the only junkyard is in a guy's backyard or driveway or i have to drive 400 miles to another state the newest car in the junkyard is a 85Jim,yrs ago when I was a kid(kind of hard to believe I was at one time huh-LOL)I worked at a front-end/spring replacement shop called Fry-The-Wheelman.They had a forge and the typical real old guy blacksmith with the hammer and anvil.He would hammer out any leaf spring anyone could ever want and still keep the temper in the spring steel.They had never ever gotten a spring back and he was with them when they opened in the late 1940's.To watch him work was a true work of art.They have since closed up the shop,but for this o/p to find that kind of shop might be a very good long term answer.
Consider weither it is a better answer to drive now to get what ya need or get stuck with the fiberglass spring broken the same distance form home later.
by astro355 » February 7th 2010, 8:53pm
Astroboy303 wrote:
good point but i have better plans for later but my first plan is getting out of Kansas then my projects are endless ,body drop,front wheel tubs ,four link 11" rear bags ,9" front bags ,and a built turbocharged ls6 (or the cl6 from the trucks cast iron block boared to 427 )o and a 9" Should be awsome
by Astroboy303 » February 7th 2010, 9:03pm
Is Kansas the name of your wife or something?
It is currently May 23rd 2013, 5:08am
| Lowered Suspension Forum |
| Moderator: chevy57bert |
To create a new topic in Lowered Suspension, click this button:
| Previous topic Next topic |
| Recent Image Attachments | |||
| Sponsors |
