Lowering spindles
Lowering spindles
Postby Munken [OP] » November 30th 2009, 9:38pm
I checked around the forum and have also been out on the net but could not find anything, so I ask.
Is there lowering spindles to 89 Astro which lower more than 2", like 3"- 4"? Or if the drop is more than 2" will the lower control arm become below the rim, resulting in that if you get a flat tire you lands on the control arm?
:think:
"Nothing is impossible, the impossible just takes a little longer"
Munken
Section Moderator
Section Moderator
Firing on 5 Cylinders (L2)
Years of Membership: Munken has been a member for 3 full yearsMunken has been a member for 3 full yearsMunken has been a member for 3 full years
Topics: 66
Alias (AKA): Munken the lunatic
Extra Info: LT 4.3L V6 RWD
Re: Lowering spindles
Postby moneymaker » December 4th 2009, 2:27pm
2" is the standard for drop spindles. For a static drop you would have to get lowering springs as well to get more than a 2" drop. But you will have to change the shocks in order to get ride quality out of it. Stock shocks are normally fine with 2-3" of drop. But range of motion in a stock shock is limited with 4" drop.
moneymaker
Years of Membership: moneymaker has been a member for 3 full yearsmoneymaker has been a member for 3 full yearsmoneymaker has been a member for 3 full years
Topics: 7
Alias (AKA): maddog
Extra Info: tbi 5.0v8 rwd
Postby Munken [OP] » December 4th 2009, 2:44pm
Okay, thanks alot :thumbup:
Munken
Section Moderator
Section Moderator
Topics: 66
Return to Lowered Suspension
It is currently May 23rd 2013, 4:47am
Lowered Suspension Forum
Lowered SuspensionLowering Suspension, Slamming, Flip-kits, Spindles, Shackles, Hangers, Lowering Coils, Air Bags, Hydraulics.
To create a new topic in Lowered Suspension, click this button:
gaastro96
Date: Mar 05 '13
Time: 7:13pm
astro352
Date: Feb 12 '13
Time: 3:48pm
marcus38
Date: Feb 11 '13
Time: 1:36am
Attached by: diego89
diego89
Date: Jan 31 '13
Time: 6:08am
Date: Jan 14 '13
Time: 4:43pm
