Using Expanding foam & fiberglass to fix rust holes?
Postby fede [OP] » February 11th 2009, 9:58pm
Hi, it may seem a little stupid but i was thinking of patching up my rusted rocker panels with expanding spray foam then fiberglassing over it. I'm just looking for a cheap way of fixing them since i don't know how to weld and i don't wanna spend the money on labor to take it to a body shop. I know the rockers are an important part of the structure of the van. But this has be better than just doing nothing at all and letting it get even worse. I got this idea when i saw this guys 89 voyager on cardomain. http://www.cardomain.com/ride/321255/13 This guy is a genius!! all the custom stuff to his van he did himself. and he used that spray foam/fiberglass to create a custom front lip.
So what do you guys think?
These are some pictures of my rockers that i took almost a year ago (they have gotten much worse now :( ) :
http://img125.imageshack.us/my.php?imag ... 342dj4.jpg
http://img520.imageshack.us/my.php?imag ... 341dq5.jpg
91 Astro LT
fede
Years of Membership: fede has been a member for 8 full yearsfede has been a member for 8 full yearsfede has been a member for 8 full yearsfede has been a member for 8 full yearsfede has been a member for 8 full yearsfede has been a member for 8 full yearsfede has been a member for 8 full yearsfede has been a member for 8 full years
Topics: 68
  • RUST
    by 1lowcab1lowcab is online! » January 2nd 2017, 12:31am in Exterior
    Last post by Lumpy View the latest post
    January 8th 2017, 4:50pm
  • Prevent further Rust
    by dnwong » November 14th 2016, 3:17pm in Exterior
    Last post by WoodButcher View the latest post
    November 16th 2016, 3:33am
    February 26th 2017, 2:01am
Re: Using Expanding foam & fiberglass to fix rust holes?
Postby astro355 » February 12th 2009, 12:53am
Yeah, that's really creative. You can do that with the rocker panels. Just make sure you cut out ALL of the rusted metal and treat the rest of it (POV-15) before you start with the foam. Luckily you have the running boards so that will help protect the fiberglass from all types of road debris.
astro355
Firing on 4 Cylinders (L6)
Year: 1989
Extra Info: 355 V8 700R4
Postby Leeann_93 » February 12th 2009, 4:55am
Just a slight correction - that's POR-15 (it works great).
'00 Astro LS AWD vin W - WIP
Image Image
Topics: 27
Year: 2002
Extra Info: LS 4.3L AWD
Postby Gary » February 12th 2009, 5:23am
Tell ya what.Check the rear frame area around where the rear shocks mount to it.If you find that rusted out or cracked,might want to consider another van.Let us know what you find.
Gary
Firing on 4 Cylinders (L3)
Years of Membership: Gary has been a member for 8 full yearsGary has been a member for 8 full yearsGary has been a member for 8 full yearsGary has been a member for 8 full yearsGary has been a member for 8 full yearsGary has been a member for 8 full yearsGary has been a member for 8 full yearsGary has been a member for 8 full years
Topics: 136
Extra Info: high top
Postby Matrixx » February 12th 2009, 6:43am
Hi fede
Thanks for the links, that guy sure knows how to fabricate, great job. I think the running boards on your van were the main cause of the rust. They have a tendency to trap moisture in between the gaps and have no way to dry out properly.
As others have stated, I would really check the whole under carriage out to see if it's really going to be worth fixing it. If it's just the panels you posted that have that much rust on them, then you should be able to fix it without to much problems. Follow the advice of others that commented and please keep us updated, Thanks.:)
Matrixx
Years of Membership: Matrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full years
Postby Big_kid » February 12th 2009, 1:28pm
It's been done before. My F150 was full of it when I got it, it had even more when i got rid of it.
:chevy:
Firing on 6 Cylinders (L5)
Topics: 138
Images: 66
Extra Info: 2WD conversion
Postby fede [OP] » February 12th 2009, 9:08pm
Thanks for the replies, i have checked the undercarriage and its in really good condition ill take a couple pictures when i get a chance, basically the only rusted area only my van is the rockers. I ordered the POR-15 kit that comes with a cleaner and prep today.
91 Astro LT
fede
Topics: 68
Postby astro355 » February 13th 2009, 12:50am
fede wrote:Thanks for the replies, i have checked the undercarriage and its in really good condition ill take a couple pictures when i get a chance, basically the only rusted area only my van is the rockers. I ordered the POR-15 kit that comes with a cleaner and prep today.
Is that the starter kit? If it is, it is not enough. Its never enough. If you can add to that order, I would suggest adding at least a quart of the POR-15 (thanks leeann).
astro355
Year: 1989
Postby toddb » March 9th 2009, 5:41pm
Hi, Ive done poor man body repair before. I did not use foam beacaus it will retain moisture and cause the repair to fail in short order. I used chrome tape ( it is like duct tape supper sticky and fairly stiff ).
1 - Grind arear to be repaired to bare metal
2 - remove as much rust and debris as possible behind/inside hole.
3 - treat inside of vehicle rust spot with some sort of rust paint (POR15)
4 - form chrome tape to cover hole
5 - use long and strong (kitty hair) fiber glass for first coat
6 - finish up with regular body filler
7 - paint inside of repair with more rust paint to keep water out.
8- people wont know it's not metal inside or out with out a magnet.
I've also used metal and rivets in the same fashion. both methods last for years and years if water can be keeped out of repair
1997 Safari 2WD 3:73 locking. 300,000 km - almost full load.
2000 Safari AWD 3:73 locking. 275,000 km - Full load.
toddb
Years of Membership: toddb has been a member for 8 full yearstoddb has been a member for 8 full yearstoddb has been a member for 8 full yearstoddb has been a member for 8 full yearstoddb has been a member for 8 full yearstoddb has been a member for 8 full yearstoddb has been a member for 8 full yearstoddb has been a member for 8 full years
Return to Exterior
It is currently February 26th 2017, 2:01am
Exterior Forum
Attached by: astrotardis
astrotardis
in Exterior
Comments: 152
Time: 5:37am
Attached by: nosxjeep
nosxjeep
in Exterior
Date: Feb 22 '17
Time: 6:10pm
in Exterior
Comments: 27
Date: Feb 15 '17
Time: 3:23am
hiilikeyourvan
in Exterior
Comments: 27
Date: Feb 14 '17
Time: 10:41pm
Attached by: markmitch
in Exterior
Date: Feb 05 '17
Time: 2:27am
