1991 astro vaccum and belt routing?
Postby boe402u [OP] » March 13th 2009, 3:38pm
I was wondering how I can find out what the belt and vaccum routing is on a 1991 astro van? My stickers came off from inder the hood.
Thank You.
boe402u
Years of Membership: boe402u has been a member for 8 full yearsboe402u has been a member for 8 full yearsboe402u has been a member for 8 full yearsboe402u has been a member for 8 full yearsboe402u has been a member for 8 full yearsboe402u has been a member for 8 full yearsboe402u has been a member for 8 full yearsboe402u has been a member for 8 full years
Re: 1991 astro vaccum and belt routing?
Postby Matrixx » March 13th 2009, 9:05pm
Hi boe402u
Welcome to the Forum
Here are some belt diagrams:
http://www.autozone.com/az/cds/en_us/09 ... oPages.htm
Here are some vacuum diagrams:
Hope this helps.:)
Matrixx
Years of Membership: Matrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full years
Postby JAMIN » September 14th 2010, 3:47am
this link appears to be broken. Does anyone have the vaccuum schematics?
93 SBcargo
JAMIN
Years of Membership: JAMIN has been a member for 6 full yearsJAMIN has been a member for 6 full yearsJAMIN has been a member for 6 full yearsJAMIN has been a member for 6 full yearsJAMIN has been a member for 6 full yearsJAMIN has been a member for 6 full years
Extra Info: cargo
Postby fast68 » September 14th 2010, 5:26am
vacuum schematics arent always same just because same engine and model and year.
different emissions levels and packages plus if built in 48 states or in cali or in canada all have different vacuum schematics
i would go to a junkyard and try to locate another vna your year with same three letter emissions digit code on the sticker,.
or in the SPID label in glovebox in the engine cover
the vacuum lines on these are pretyt basic though
not much to them.
cruise control
egr vacvuum solenoid
heater a/c vacuum line
pcv
most everything connects to or originates from an intake manifold vacuum source
i might have the sticker on the rad support of the 92 i just stripped, ill check and see
fast68
Years of Membership: fast68 has been a member for 8 full yearsfast68 has been a member for 8 full yearsfast68 has been a member for 8 full yearsfast68 has been a member for 8 full yearsfast68 has been a member for 8 full yearsfast68 has been a member for 8 full yearsfast68 has been a member for 8 full yearsfast68 has been a member for 8 full years
Topics: 12
Alias (AKA): fast
Extra Info: 4.3L Z EXT RWD
Postby Lumpy » September 20th 2010, 3:39pm
JAMIN wrote:this link appears to be broken. Does anyone have the vaccuum schematics?
The upper image is busy and reduced. Sorry. The board won't seem to accept
images larger than 600 horizontal without clipping them.
As others have suggested, various individual vehicles will have slightly
different vacuum routings. Veh's built for cold climates, for example,
have a different PCV valve hose routing.
Year: 1989
Postby Phantom » September 20th 2010, 4:09pm
Phantom
Firing on 7 Cylinders (L4)
Postby JAMIN » October 17th 2010, 10:12pm
thanks, the second pic was what I was lookink for. The other thing I was looking for was the check valve in front of the TBI going to the "black ball" under the heatercore. Engine runs well, just want to double check my vaccuum lines.
93 SBcargo
JAMIN
Extra Info: cargo
It is currently March 28th 2017, 8:33pm
Technical Information Forum
Date: Mar 10 '17
Time: 2:17am
Comments: 14
Date: Feb 28 '17
Time: 6:05pm
Comments: 14
Date: Feb 18 '17
Time: 10:24pm
Comments: 14
Date: Feb 18 '17
Time: 10:03pm
Comments: 14
Date: Feb 18 '17
Time: 5:30pm
