long time lurker
Please do not post support requests in the new members lounge! This forum is for new member introductions and assistance only. Please post other topics in their appropriate areas so they stay categorized.
long time lurker
Postby dblwall [OP] » April 20th 2009, 8:38pm
Great forum here guys to go along with a great vehicle, the Astro. First one was a 1990 Astro, had for 14 yrs with no problems. Needed a bit more room so got a used 2000 three years ago also problem free until now. Nothing big, just the AC / heat vent control not operating correct lately.
Searching here has pointed me in the right direction, assuming it's the vacuum hoses.
Had too have it smogged today, passed with flying colors with 145,000 on it. While the engine hump was off I tried looking for cracked / loose hoses. Before I dig into everything is it usually the Black White Orange hose that goes bad? Or do I follow it thru the firewall and look there?
dblwall
Years of Membership: dblwall has been a member for 4 full yearsdblwall has been a member for 4 full yearsdblwall has been a member for 4 full yearsdblwall has been a member for 4 full years
Re: long time lurker
Postby gtkane » April 21st 2009, 3:00am
Welcome aboard!
The coloured vac hoses are usually the "inside" hoses. The problem usually lies under the hood, where the line taps into the intake. You'll probably find a loose hose if you feel around a bit.
User album #4...check it out!
gtkane
Years of Membership: gtkane has been a member for 5 full yearsgtkane has been a member for 5 full yearsgtkane has been a member for 5 full yearsgtkane has been a member for 5 full yearsgtkane has been a member for 5 full years
Alias (AKA): Astruck
Extra Info: nasty 4.3
Postby Matrixx » April 21st 2009, 4:30am
Hi dblwall
Welcome to the Forum
As gtkane stated, it's usually the black thin line that cracks under the hood. The most common one to crack which also has with mine a couple of times is the Black line running along the front of the engine from the drivers side intake manifold leading to the heater control valve located on the passenger side just under the heater core (black box).
This is the most common cause for the problem you now have. Also check and make sure the line hasn't fallen off the heater control valve itself located at the base of it, this has happened to me as well once before. I would also check the other vacuum lines if that one seems to be fine. Hope this helps, please keep us updated, Thanks.:)
Matrixx
Years of Membership: Matrixx has been a member for 5 full yearsMatrixx has been a member for 5 full yearsMatrixx has been a member for 5 full yearsMatrixx has been a member for 5 full yearsMatrixx has been a member for 5 full years
Postby dblwall [OP] » April 22nd 2009, 1:13am
Thanks guys I'm half way there I think. The hard small line from the drivers side was cracked (actually broke in half) and thought that was it. Changed it and still no go. Found another line, not sure where it goes. The line with the red arrow is what I replaced. The one with the blue arrow I can't seem to find where it goes. Only thing I see is a hard black plastic ball underneath the heater.
dblwall
Postby Matrixx » April 22nd 2009, 2:01am
Hi dblwall
One line goes to that hard plastic ball and the other line goes to the heater control valve (on the bottom of it). Hope this helps. Please keep us updated, Thanks (Thanks for the picture as well dblwall, great shot).:)
Matrixx
Postby dblwall [OP] » April 22nd 2009, 3:30am
Thanks Matrixx that did it :ty: . Just peeled the hard liner in the fender well back and was able to get at the 2 bolts holding it on. When I get a chance gonna put all new lines on it. BTW what function does that hard plastic ball perform?
dblwall
Postby Matrixx » April 22nd 2009, 4:33am
That is a vacuum storage reservoir to help assist the engine in supplying vacuum to the controls that run off vacuum. Hmm, I hope that makes sense.:)
Matrixx
Return to Member Introductions
It is currently May 19th 2013, 5:43am
Member Introductions Forum
Member IntroductionsHello and welcome to the best and original home for Astro & Safari owners. Please introduce yourself to the community and make yourself at home. Tell us about yourself and post your introductions and welcome messages here.
To create a new topic in Member Introductions, click this button:
ChrisL
Date: Apr 30 '13
Time: 11:58pm
Attached by: Jasen
Date: Apr 14 '13
Time: 4:48am
OneEye
Comments: 13
Date: Apr 09 '13
Time: 2:07am
sauce
Date: Apr 07 '13
Time: 9:47pm
Tegnus
Comments: 432
Date: Apr 07 '13
Time: 7:17pm
