brake line leakage
brake line leakage
Postby RichinMD [OP] » May 31st 2009, 10:24pm
1995 Astro 2wd with tow package.
I have a leak in my brake lines at the rear T fitting on top of the rear end. Unfortunately it is the forward side of the T meaning I need to change the long line. Do I need to drop the fuel tank for this and does anyone have access to a brake line diagram. I have a sneaky suspicion that I won't be able to find any prefabricated lines so this should be fun.
Thanks,
Rich
1995 Astro, 175k miles, VIN W, 2WD, Tow Pkg
RichinMD
Years of Membership: RichinMD has been a member for 7 full yearsRichinMD has been a member for 7 full yearsRichinMD has been a member for 7 full yearsRichinMD has been a member for 7 full yearsRichinMD has been a member for 7 full yearsRichinMD has been a member for 7 full yearsRichinMD has been a member for 7 full years
Year: 1995
Extra Info: 2wd vin W
Re: brake line leakage
Postby astro355 » June 1st 2009, 1:46am
Hello,
is the leak in the metal line or in the rubber hose? The T-fitting should be attached to the rubber hose.
astro355
Firing on 4 Cylinders (L6)
Year: 1989
Extra Info: 355 V8 700R4
Postby RichinMD [OP] » June 1st 2009, 3:12am
It's on the metal line at the union, my mistake on the location. The line is pretty rusted although I may be able to splice it a few feet back next to the gas tank. Not sure right now how much room I would have to try to work the problem. I probably won't have time to get to it until next weekend so if anyone knows if I can get a pre fabricated line, that would help a ton.
RichinMD
Year: 1995
Postby astro355 » June 1st 2009, 8:00am
You will not be able to find a prefab line. Its not terribly hard, I'm working on it right now. Taking the gas tank down is only 15 minutes, just make sure you have as little gas as possible so its not heavy.
astro355
Year: 1989
Postby butch27 » June 2nd 2009, 2:45am
Hijack: Working on the same thing right now . Are the rear lines 1/4" or are they 3/16"? :?
butch27
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: butch27 has been a member for 8 full yearsbutch27 has been a member for 8 full yearsbutch27 has been a member for 8 full yearsbutch27 has been a member for 8 full yearsbutch27 has been a member for 8 full yearsbutch27 has been a member for 8 full yearsbutch27 has been a member for 8 full yearsbutch27 has been a member for 8 full years
Topics: 30
Alias (AKA): butch27
Postby RichinMD [OP] » June 2nd 2009, 11:21pm
I believe it to be 1/4 inch but I'm not sure. Haven't gotten the line out yet, need to drive my other car a bit more so I can drain more gas out of the tank. I found a spot to break into the lines just behind the drivers door connected by a union. Not sure if that's how it was designed or if someone has changed the lines out before, but it is very convenient. I attempted to disconnect the metal line from the rubber one just above the rear end, but no luck there. Snapped the metal line and still can't get it out of the hose. I went ahead and disconnected the metal lines from the T and will just replace the rubber hose as well.
RichinMD
Year: 1995
Postby astro355 » June 2nd 2009, 11:29pm
The brake line is 1/4". I just got done with this myself.
And yes, that union is also on my van and appears to be stock.
astro355
Year: 1989
Return to Brakes
It is currently February 24th 2017, 4:38am
Brakes Forum
Attached by: chevymaher
in Brakes
Comments: 32
Date: Nov 28 '16
Time: 5:59am
in Brakes
Comments: 32
Date: Nov 28 '16
Time: 3:12am
in Brakes
Comments: 32
Date: Nov 28 '16
Time: 2:48am
in Brakes
Date: Nov 12 '16
Time: 6:03am
Attached by: 97cargocrawler
97cargocrawler
in Brakes
Date: Nov 10 '16
Time: 10:33pm
