replacement oil cooler lines
Postby jal [OP] » June 11th 2009, 6:31pm
Sorry if this is in the wrong forum.
The oil cooler lines on my 2001 Astro (55,000 miles) have been leaking for a long time and cause the accessory belt to squeak. I finally ordered one from gmpartsdirect, after independently getting the part number from a local dealer. The part number is 15764375. Overall the item I received looks correct including the fitting for the oil cooler and the bends in the metal portion of the lines. However, as you can see from the photos below, the fittings that go to the radiator appear to be much different. The first image is the upper fitting for the original line; the second image is for the new lower fitting. Anybody have a clue whether I really have the right part?
jal
Years of Membership: jal has been a member for 8 full yearsjal has been a member for 8 full yearsjal has been a member for 8 full yearsjal has been a member for 8 full yearsjal has been a member for 8 full yearsjal has been a member for 8 full yearsjal has been a member for 8 full yearsjal has been a member for 8 full years
Images: 3
Re: replacement oil cooler lines
Postby Matrixx » June 12th 2009, 5:39am
Hi jal
What someone has done is removed the threaded portion of that fitting in picture-1. It shouldn't have been done that way. As you can see a clip in picture-1 that was suppose to be removed, then the oil line fitting just slides out from their.
That's what your seeing in picture-2 when the lines are disconnected properly from the retaining clips. It looks the same. Please keep us updated, thanks. :)
PS: Don't loose the clips.:)
Matrixx
Years of Membership: Matrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full years
Postby Mr_Bowtie » June 12th 2009, 2:41pm
I was going to suggest that last night, but I wasn't 100% sure. Why in the world wouldn't new lines just come with the fittings on them? I may have to replace mine soon......ugh. :banghead:
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Year: 1985
Extra Info: 350 with 700r4
Postby jal [OP] » June 12th 2009, 5:36pm
I called the place I got them from, and they confirmed that everything was OK. The threaded fittings come off if you remove a small clip, and then they go onto the new lines. I changed it out this morning, and it took maybe 45 min (including oil+filter change and lube).
jal
Images: 3
Postby Mr_Bowtie » June 12th 2009, 9:30pm
Good to know it was a straight forward swap. I will be doing this soon if my suspensions are correct. :(
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Year: 1985
Postby Leeann_93 » June 13th 2009, 4:35am
They are very different between the 2001 and 1992 motors. Yours will come with threaded nuts installed, no clips.
'00 Astro LS AWD vin W - WIP
Image Image
Topics: 27
Year: 2002
Extra Info: LS 4.3L AWD
Postby Matrixx » June 13th 2009, 8:22am
Actually folks, the correct way is to remove each clip with a small pointed pick and the line fittings just slide out. Their isn't any need to remove the threaded portion which adds more work if your just replacing the oil cooler lines. I have done it twice on my van, and it's the same style with jal's (from what I see in the above pictures). Just to clarify.:)
Matrixx
It is currently February 23rd 2017, 9:45pm
AstroNuts
Comments: 59
Date: Today
Time: 5:19am
sixsixsixsix is online!
Comments: 22
Time: 4:37am
Attached by: 97cargocrawler
97cargocrawler
Comments: 59
Date: Feb 21 '17
Time: 6:29pm
Attached by: Coaster
CoasterCoaster is online!
Comments: 107
Date: Feb 20 '17
Time: 5:25pm
Comments: 107
Date: Feb 20 '17
Time: 1:44am
Users browsing this forum: Bing [Bot] and 5 guests
