by bud0810 [OP] » January 20th 2011, 7:34pm
by offroad safari » January 20th 2011, 8:16pm
by bud0810 [OP] » January 20th 2011, 8:50pm
offroad safari wrote:i used to run 235/75s all the time on my 89 2wd, they only rubbed during tight cornering. I even ran 235/70s with 2" drop spindles, but that took some modification to the fender. structure
by bud0810 [OP] » January 20th 2011, 10:28pm
by B-rad » January 21st 2011, 1:13am
by Mr_Bowtie » January 21st 2011, 3:08am
by loopie » January 21st 2011, 6:57am
by bud0810 [OP] » January 22nd 2011, 1:23am
loopie wrote:Crank the bars up and any trimming you need to do, you'll need to do anyways when you change the method of lift.
Not sure about tire wear tho...you are supposed to get an alignment after adjusting the T-bars a lot.
You can leave the rear stock for a 235. You'll just have that Baja/Desert Pre-Runner look
by cowboydan » January 26th 2011, 5:05am
bud0810 wrote:anyone?????????? someone has had to crank there t-bars on a newer astro
by cowboydan » January 26th 2011, 5:16am
by bud0810 [OP] » January 26th 2011, 7:45am
cowboydan wrote:Bud0810, is that your van on your avatar? you should post a big pic of your van
by bud0810 [OP] » January 26th 2011, 3:35pm
by bud0810 [OP] » January 26th 2011, 3:37pm
by cowboydan » January 26th 2011, 3:53pm
by cowboydan » January 26th 2011, 3:55pm
by cowboydan » January 26th 2011, 3:57pm
cowboydan wrote:nope.... it's a mini puller....?
by bud0810 [OP] » January 26th 2011, 4:10pm
by cowboydan » January 26th 2011, 4:15pm
by bud0810 [OP] » January 26th 2011, 5:51pm
by B-rad » January 28th 2011, 5:35am
It is currently May 22nd 2013, 5:39am
| Lifted Suspension Forum |
| Moderator: chevy57bert |
| Previous topic Next topic |
| Recent Image Attachments | |||
| Sponsors |
