Suspension lift vs body lift
Postby borzoi [OP] » April 28th 2011, 9:06pm
So I have no idea what I'm asking, except I've been told that a body lift is mainly for appearance and for bigger tires, while a suspension lift actually increases ground clearance. I don't care what my van looks like, but I do not want to rip off the oil pan (been there with another vehicle) and find myself walking my dogs 30 miles back to civilization. Do overland lifts actually increase minimum ground clearance? Is there a good tutorial somewhere on the forum? Do I have any idea what I'm talking about? WAIT. Don't answer that.
Doug
2003 AWD Astro w/2" front pucks, 2" shackles + add-a-leaf, Skid Plates
Firestone A/T 235/75/16, same rims & tires as our SoCal off-road Teardrop trailer
borzoi
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: borzoi has been a member for 6 full yearsborzoi has been a member for 6 full yearsborzoi has been a member for 6 full yearsborzoi has been a member for 6 full yearsborzoi has been a member for 6 full yearsborzoi has been a member for 6 full years
Topics: 9
Year: 2003
  • Lift Help
    by Superno-van » March 31st 2017, 8:20pm in Lifted Suspension
    Last post by K/4 View the latest post
    April 1st 2017, 6:17am
  • 03 Awd Lift
    by Rbennett2082 » November 9th 2016, 12:12am in Lifted Suspension
    Last post by nonhog View the latest post
    December 12th 2016, 11:01pm
    7
    26
    April 29th 2017, 10:29am
Re: Suspension lift vs body lift
Postby chevy57bert » April 28th 2011, 9:14pm
Welcome to AS
I will not answer your last question :rofl: :rofl:
Take a search on this forum, you will find a lot about body lifts.
look at the Build / Projects.. body lift is a cheap way to increase lift / look.
Suspension lift is a other ball game....
it`s like racing... how much money you have to spend. and don`t stop half way....
chevy57bert
Section Moderator
Section Moderator
Firing on 7 Cylinders (L3)
Topics: 68
Images: 68
Alias (AKA): Bertjuh
Year: 1992
Extra Info: Ext 4.3L rwd
Postby borzoi [OP] » April 28th 2011, 9:17pm
Bert - Thanks for the welcome. So are the Overland lifts just body lifts?
P.S. Hung out at Twente for a bit. Beautiful place.
Doug
borzoi
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 9
Year: 2003
Postby chevy57bert » April 28th 2011, 9:48pm
Couldn`t find it.. but I got it ` GoneBlue lift project` -->> viewtopic.php?f=40&t=7256
Twente is nice:) so you where here? Football??
chevy57bert
Section Moderator
Section Moderator
Topics: 68
Images: 68
Year: 1992
Postby bud0810 » April 28th 2011, 10:36pm
tires are what is going to give you your ground clearance no matter what kind of lift you do your rear axle is going to sit at the same hieght untill you put bigger tires on it
bud0810
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: bud0810 has been a member for 6 full yearsbud0810 has been a member for 6 full yearsbud0810 has been a member for 6 full yearsbud0810 has been a member for 6 full yearsbud0810 has been a member for 6 full yearsbud0810 has been a member for 6 full years
Alias (AKA): bud
Postby borzoi [OP] » April 28th 2011, 11:07pm
bud0810 wrote:tires are what is going to give you your ground clearance no matter what kind of lift you do your rear axle is going to sit at the same height until you put bigger tires on it
Okay, thanks.
That makes sense to me.
So is this right:
If I add rear shackles, say a 2" lift, and put on tires that raise the rear axle 1", I will have 3" of ride height increase and 1" of additional ground clearance in back.
Stock rear clearance is 7.4", so I'll be at 8.4"
If I put 2" torsion bar lift (can I do this with OVL torsion bar key?) and put on the same tires as rear, I will have 3" ride height increase AND 3" additional ground clearance under the engine.
Front stock clearance is 6.8, so I will end up with 9.8" of front clearance.
And will I also need to install the ball joint relocation kit.
Or am I just confused?
Thanks again you all!!
Doug
borzoi
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 9
Year: 2003
Postby B-rad » April 29th 2011, 1:30am
I think you got it! I started with just about 2" in the front via the Tbars, and put air shocks in the rear and left them aired up and did just fine with 235-75-15's on stock rims... every van is different though so you might have some rub but a little triming will be the worst you will do. I can't rememeber if I had to trim mine or not... but I did cut all the plastic off anyway to make it look higher
1996 Safari SLT AWD, T-bars cranked, S-10 Springs, Rancho Shocks, 31"BFG's, Realtree CamoWrap, Conversion van sofa/ sleeper, 5 passanger, family fun camping/hunting van! (Manual Trans. Case, 3" BL To be installed)
B-rad
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: B-rad has been a member for 7 full yearsB-rad has been a member for 7 full yearsB-rad has been a member for 7 full yearsB-rad has been a member for 7 full yearsB-rad has been a member for 7 full yearsB-rad has been a member for 7 full yearsB-rad has been a member for 7 full years
Extra Info: AWD SLT
Return to Lifted Suspension
It is currently April 29th 2017, 10:29am
Lifted Suspension Forum
ThatVanGuy
Date: Apr 07 '17
Time: 11:32pm
Jasekcco
Date: Apr 04 '17
Time: 8:04am
Attached by: zach914v8
zach914v8zach914v8 is online!
Comments: 169
Date: Mar 31 '17
Time: 3:00am
Date: Mar 17 '17
Time: 3:39pm
Date: Mar 09 '17
Time: 10:53pm
