2" OLV Lift Install '04 AWD to 4" Lift to 5" Lift
Postby Corsemoto [OP] » October 29th 2011, 9:53pm
Got the front part of my Overland 2" lift installed yesterday then the heavy rains came and disrupted as I was finishing bumper bracket, bumper, etc.
While looking for tight lines, cables, etc, I noticed the upper radiator hose and throttle cable are a little tight so will probably try and re-route those and maybe trim the lips off the upper shroud that keeps the upper hose from moving. Also, the lower rad hose is fairly close to serpentine belt so I'm going to play with that and see if I can space it further away. Other than those few items, everything looks good, pretty straightforward install, no pics from that part as I was in too much of a hurry trying to beat the rain.
Today, I finished up the rear with the Overland lift shackles. I bought the kit used from a member on here and the shackles needed new bushings which I sourced from airbagit.com. With new bushings installed and fully greased, the original shackles came out with ease and slotted the lift shackles in place.
The Yokohama Geolandar A/T-S 235/70-16 tires (29.2") actually rub more with the lift installed as the front bumper lower is moved closer to the centerline of the tire. So, I still have some bumper cover trimming and bracket relocation to perform and replace broken rear e-brake cable.
I adjusted the driver's side torsion bar one turn (approximately 1/4") to even out front ride height. I don't ever drive with any rear seats in the van and the fuel tank is next to empty right now. The rear driver's side started out 1/4" higher than passenger side, so drive it some and see if it settles and make adjustments from there.
Front measurement:
Rear measurement:
Here's the van pre-lift with new tires:
Lift installed:
Pre-lift:
Lift installed:
Next up I need to replace passenger side wheel hub and then I'll do add-a-leaf springs for the rear to firm up the back to better support load without sag.
Corsemoto
Firing on 4 Cylinders (L3)
Years of Membership: Corsemoto has been a member for 8 full yearsCorsemoto has been a member for 8 full yearsCorsemoto has been a member for 8 full yearsCorsemoto has been a member for 8 full yearsCorsemoto has been a member for 8 full yearsCorsemoto has been a member for 8 full yearsCorsemoto has been a member for 8 full yearsCorsemoto has been a member for 8 full years
Topics: 36
Images: 13
Year: 2004
Extra Info: LT AWD
  • 03 Awd Lift
    by Rbennett2082 » November 9th 2016, 12:12am in Lifted Suspension
    Last post by nonhog View the latest post
    December 12th 2016, 11:01pm
  • How to do a 3+1 (4") AWD Lift -by WimpTech
    by Wimpazz » December 30th 2016, 7:37pm in Lifted Suspension
    Last post by Wimpazz View the latest post
    March 22nd 2017, 5:37pm
    7
    97
    March 30th 2017, 3:41pm
Re: 2" OLV Lift Install '04 AWD
Postby Jasen » October 29th 2011, 10:02pm
:thumbup:
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Year: 1997
Postby Shad0wXCalibur » October 29th 2011, 10:16pm
Not a big lift but just enough to make it look tougher. I like. I still have some add-a-leafs I'm not using. If you want them, I'd be willing to ship them.
1987 Astro
2000 Safari
Shad0wXCalibur
Years of Membership: Shad0wXCalibur has been a member for 5 full yearsShad0wXCalibur has been a member for 5 full yearsShad0wXCalibur has been a member for 5 full yearsShad0wXCalibur has been a member for 5 full yearsShad0wXCalibur has been a member for 5 full years
Topics: 41
Extra Info: Lifted 2wd
Postby Corsemoto [OP] » October 29th 2011, 10:52pm
Thanks, would like to do additional lift at some point but with new tires and alignment will keep as-is - for a little while anyway! Previous to alignment I added just under an inch of front ride height via torsion bar preload, due to sag in front and even out with rear.
I''ll pm you on those add-a-leafs.
Corsemoto
Topics: 36
Images: 13
Year: 2004
Extra Info: LT AWD
Postby Lumpy » October 29th 2011, 11:31pm
...... :rockon:
Thanks for taking the pre and post lift shots.
That's always very helpful, I think. Lets the guys with the non-lifted
vans know how whimpy they look... :poke:
Year: 1989
Postby Corsemoto [OP] » October 29th 2011, 11:42pm
:mrgreen: Was in a hurry yesterday or I would've taken some pre-lift height measurements.
Headed to Lowe's to pick up a few more Dremel accessories to trim bumper cover. :swerve:
Corsemoto
Topics: 36
Images: 13
Year: 2004
Extra Info: LT AWD
Postby Corsemoto [OP] » October 30th 2011, 2:15am
Got back from an around town and highway test run, I really need to trim the bumper cover in the morning so I don't scare everyone at the gas station pulling up to the pumps!
More serious, I have a vibration from take-off up to about 20mph or so. I'm going to take the one turn of preload out of the driver's side torsion bar I added to even out ride height and test drive in the morning. This feels like it's coming through the front drivetrain, not the rear and while the passenger side hub bearing has a slight amount of play it wasn't vibrating before lift install. :think:
Corsemoto
Topics: 36
Images: 13
Year: 2004
Extra Info: LT AWD
Postby Shad0wXCalibur » October 30th 2011, 4:31am
Wonder if the CV axles are being funny. Have you checked those?
1987 Astro
2000 Safari
Shad0wXCalibur
Topics: 41
Postby Corsemoto [OP] » October 31st 2011, 12:48am
Yep, when I was looking for the source of play in right front wheel I noticed some light colored grease flung off of inner cv and thought it was the Amsoil grease I used to lube chassis and some ended up on the cv and got flung off. I looked at the passenger halfshaft again today when trimming bumper cover for tire clearance and think the grease might be coming out the end of the inner cv boot (towards center) and maybe the clamp is loose. Also noticed the axle seal I replaced not too long ago is leaking again so gotta check fluid level in front diff in the am.
So... looks like I may be doing passenger side wheel hub, cv halfshaft and axle seal. Probably gonna replace axle housing tube that bolts to front diff as well because I tried to clean up a little nick/gouge in the housing where the seal seats and think that may be the source of the seal leak.
Corsemoto
Topics: 36
Images: 13
Year: 2004
Extra Info: LT AWD
Postby Hank » November 21st 2011, 4:59am
Lift looks damn good, glad it all worked out. Strange twist of fate, I need adjustable shackles now. lol
Camaro eating, trailer dragging 2003 AWD tuned with hptuners.
See http://www.hptuners.com
http://www.hptuners.com/forum/showthread.php?t=11225
Balancing by http://www.innovativebalancing.com
Hank
Years of Membership: Hank has been a member for 9 full yearsHank has been a member for 9 full yearsHank has been a member for 9 full yearsHank has been a member for 9 full yearsHank has been a member for 9 full yearsHank has been a member for 9 full yearsHank has been a member for 9 full yearsHank has been a member for 9 full yearsHank has been a member for 9 full years
Topics: 58
Images: 45
Postby Corsemoto [OP] » November 22nd 2011, 12:00am
Thanks Hank, everything in the kit was just as you described.
What are you planning with the lift shackles?
You can get them from airbagit.com, it's where I got the replacement bushings for the ones you sold me.
http://www.airbagit.com/product-p/sha-as8400a.htm
Corsemoto
Topics: 36
Images: 13
Year: 2004
Extra Info: LT AWD
Postby Hank » November 22nd 2011, 3:15pm
Thanks for the link, those are nice shackles and a little less expensive than Overland.
It confused me though, a lift shackle in the lowering shaclkes section of the website..
I was thinking of getting a set to help tweak the van level but it looks like I was crooked when I measured it. Must have been me with my new short leg..
But now with the torsions and KYB's I think I'm going to raise the front up 1-1.5"
Hank
Topics: 58
Images: 45
Postby Corsemoto [OP] » November 22nd 2011, 4:49pm
From searching another thread here: viewtopic.php?f=40&t=11591&p=127905&hilit=airbagit#p127905
those shackles are the ones Overland supplies in the kit and the replacement bushings I ordered from them are the same. Yes, it's a little strange they are in the lowering section of the site. Overland had the bushings in stock as you told me but were a little slower in responding to my inquiry so I ordered the bushings over the phone from Airbagit as I wanted to make sure I was getting the right parts. They were pleasant to deal with, reasonable price on the bushings/shipping. You can possibly get a 5% discount or so if you mention Twitter or something too...
Corsemoto
Topics: 36
Images: 13
Year: 2004
Extra Info: LT AWD
Postby Corsemoto [OP] » December 16th 2011, 12:40am
So...
I installed add-a-leafs to my spring packs, I picked up the Fabtech FTS202's that Shad0wXCalibur didn't have any use for since he went with S10 heavy-duty leaf spring packs. I noticed recently how sagged out my leafs were even unloaded and really bad even with moderate loads so decided to try the add-a-leafs as they were the cheap solution to my sagging leaf springs. I'll get into the install when I have time, I figured you'd rather see pictures in order to get an idea of what they do.
Previous to FTS202 leaf spring install with OLV 2" lift, shackles in highest position these are the measurements (ground to fender):
LF 33"
RF 33 1/4"
LR 34 1/8"
RR 34"
With FTS202 leaf springs installed:
LF 33 1/4" (+2 turns preload - I noticed this side was sagging again, same as pre-lift)
RF 33 1/2"
LR 35 5/8"
RR 35 5/8"
I then added lift to front in order to even out with rear via torsion preload and kept track of how many full rotations (if need to return to previous setting):
LF 34" (+4 turns, approximately 2 turns remaining before bolt bottoms)
RF 34" (+2 1/2 turns, only 1/2 turn remaining before bolt bottoms)
LR 35 5/8"
RR 35 5/8"
So the add-a-leafs added approximately 1 1/2" of lift in the back, the front is max lift with stock torsion keys and the vibration that appeared after the original 2" lift install has disappeared. :auto-mysterymachine:
Still sorting out some things with shocks and shock mounts but looks like going to be welding new shocks mounts on rear axle.
Here's an animation showing the the evolution of lift:
Corsemoto
Topics: 36
Images: 13
Year: 2004
Extra Info: LT AWD
Postby Hank » December 16th 2011, 3:45am
Looks damn good!
Hank
Topics: 58
Images: 45
Postby Shad0wXCalibur » December 16th 2011, 4:11am
1 1/2" is pretty good. I wasn't sure how much they would lift because they look a little on the thin side but Fabtech says they design their add-a-leafs like that for comfort.
1987 Astro
2000 Safari
Shad0wXCalibur
Topics: 41
Postby Corsemoto [OP] » December 16th 2011, 4:29am
Yeah, it rides really nice even over bumps, though I'm still going to replace them with the heavy duty S10 leaf springs down the road.
My van is now 85" tall at it's highest point - top of roof rack in the rear. They grow so fast... :cry:
Corsemoto
Topics: 36
Images: 13
Year: 2004
Extra Info: LT AWD
Postby Mr_Bowtie » December 16th 2011, 5:39pm
That is one nice looking Van, the lift looks awesome! Its just the inspiration I need for my next day off when I am planning to install my front lift blocks! :rockon:
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Year: 1985
Extra Info: 350 with 700r4
Postby Lumpy » December 16th 2011, 7:16pm
That looks really good, Corse. Just enough rake so it doesn't look 60s Rat Drag.
Nice touch on the animation image. How do you do that?
Year: 1989
Postby Corsemoto [OP] » December 16th 2011, 7:31pm
Thanks guys, I'm really satisfied with the outcome and sorting through shock options now as my original plan didn't pan out. I'd like to sell these tires and pick up some 265/70-16s but that's not in the cards right now. It'd look right though, that's for sure!
I loaded it down with toolbox, jacks, jackstands, storage bins, misc parts, etc and lost about an inch of height in the rear so it's sitting about 1/2 higher in rear than front right now.
Lumpy, I googled "create gif" and went to the first one on the page http://picasion.com/ and uploaded pics. Genius, pure genius. :lol:
Corsemoto
Topics: 36
Images: 13
Year: 2004
Extra Info: LT AWD
Return to Lifted Suspension
It is currently March 30th 2017, 3:41pm
Lifted Suspension Forum
Attached by: zach914v8
zach914v8zach914v8 is online!
Date: Mar 17 '17
Time: 3:39pm
Comments: 14
Date: Mar 09 '17
Time: 10:53pm
scorean
Comments: 30
Date: Jan 28 '17
Time: 7:20am
scorean
Comments: 30
Date: Jan 27 '17
Time: 9:20pm
scorean
Comments: 30
Date: Jan 27 '17
Time: 9:18pm
