Solving the Slider Door with Big Tires Problem
Postby Lumpy [OP] » January 4th 2015, 8:46am
Here's one way -
Topics: 258
Year: 1989
  • Big shackles
    by andy_b » November 10th 2016, 1:52am in Lifted Suspension
    Last post by andy_b View the latest post
    November 10th 2016, 4:00am
    26
    February 24th 2017, 9:02am
Re: Solving the Slider Door with Big Tires Problem
Postby WoodButcher » January 4th 2015, 3:35pm
Has anyone come up with an easy solution?
I saved these pics and now that Lump has brought it up again I thought I would ask.
I can't see how this would work but I have thought of replacing that swing-arm with a piece hinged in the center that could lengthen what we have, any ideas?
34346
34338
If you guys have pics of anything like this post them up.
WoodButcher
Firing on 4 Cylinders (L5)
Topics: 28
Images: 434
Alias (AKA): Bruce
Year: 1997
Extra Info: 4.3 RWD
Postby coppermtn » January 4th 2015, 5:54pm
I welded mine shut! easy rite.. ha
Wouldn't a tub of the rear inner fenders work? Not too difficult..
87 4.3 V6 auto. SFA dana 44 ox locked, 5.13 gears, prorock dana 60 detroit rear. Stak 3 speed t-case. Tom woods shafts. 37 inch krawlers.
coppermtn
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: coppermtn has been a member for 8 full yearscoppermtn has been a member for 8 full yearscoppermtn has been a member for 8 full yearscoppermtn has been a member for 8 full yearscoppermtn has been a member for 8 full yearscoppermtn has been a member for 8 full yearscoppermtn has been a member for 8 full yearscoppermtn has been a member for 8 full years
Topics: 12
Alias (AKA): soup kitchen
Postby WoodButcher » January 4th 2015, 9:18pm
coppermtn wrote:I welded mine shut! easy rite.. ha
Sure,
if you want to narrow the axle and fab up a four link....
WoodButcher
Topics: 28
Images: 434
Alias (AKA): Bruce
Year: 1997
Extra Info: 4.3 RWD
Postby coppermtn » January 9th 2015, 11:29pm
if were talkin an inch, just offset the rim in the rear..
My 37's with a std width rear axle barely rubs the stock fender at full stuff
if were talkin a foot, then yea
coppermtn
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 12
Postby 97cargocrawler » January 10th 2015, 12:39am
I've got about an inch higher to go...
Lumpy has about 8" to go :poke:
If I change tires I'm good as it sits. Modding the door is for weewee lift POSERS! :D
97cargocrawler
Firing on 8 Cylinders (L4)
Years of Membership: 97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years
Topics: 42
Alias (AKA): CC, CARGO, CRAWLER, ASSHOLE
Year: 1997
Postby coppermtn » January 10th 2015, 12:50am
whats the offset on your rims?
*As in, tuck the tire an inch or 1.5" in with a different offset rim.
No lift req'd.
coppermtn
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 12
Postby 97cargocrawler » January 10th 2015, 1:02am
coppermtn wrote:whats the offset on your rims?
No lift req'd.
4.75" backspacing....and I have a 1.5" spacer. They aint really tucked in. My track width is like 85" or so.
97cargocrawler
Topics: 42
Year: 1997
Postby coppermtn » January 10th 2015, 1:06am
wow. my width is 80"-81"
outside tire to outside tire width
coppermtn
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 12
Postby Lumpy [OP] » January 10th 2015, 3:07am
coppermtn wrote:
My 37's ...
Pics? Or did I miss (or forget) something?
Topics: 258
Year: 1989
Postby coppermtn » January 14th 2015, 12:49am
all the pics with my van have 37 inch tires. BFG Krawlers
viewtopic.php?f=127&t=67210
coppermtn
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 12
Postby kennyj » January 14th 2015, 3:37am
There's a guy on another van forum who modified a Ford van hinge for more clearance. By cutting away material from one end and adding material to the other end he was able to lengthen the roller arm, moving the hinge point, while maintaining the overall length of the arm from rollers to mounting point. Pretty clever!
I haven't looked to see how it would work on an Astro. Just reporting what I saw. Somebody with a welder and a cool new welding table may be able to do something with the idea. :poke:
I'll try to find the guy's thread and post the link here.
kennyj
Blue Status (L2)
Blue Status (L2)
Years of Membership: kennyj has been a member for 7 full yearskennyj has been a member for 7 full yearskennyj has been a member for 7 full yearskennyj has been a member for 7 full yearskennyj has been a member for 7 full yearskennyj has been a member for 7 full yearskennyj has been a member for 7 full years
Topics: 38
Alias (AKA): Kenny
Year: 1998
Extra Info: 225k miles
Postby kennyj » January 14th 2015, 4:06am
Found it!
http://www.expeditionportal.com/forum/t ... n-tutorial
Not as exotic as Lumpy's pic/solution up there, but a good idea nevertheless.
kennyj
Blue Status (L2)
Blue Status (L2)
Topics: 38
Alias (AKA): Kenny
Year: 1998
Postby Lumpy [OP] » January 14th 2015, 4:30am
Thanks for the link, Kenny. I'll go digest it.
Topics: 258
Year: 1989
Postby WoodButcher » January 14th 2015, 1:58pm
Seeing that I'm thinking, extend / lengthen the bar with the casters from the body 2" or so and move the pivot at the door forward that same number.
First conclusion, what do you think?
WoodButcher
Topics: 28
Images: 434
Alias (AKA): Bruce
Year: 1997
Extra Info: 4.3 RWD
Postby Lumpy [OP] » January 14th 2015, 2:49pm
WoodButcher wrote:Seeing that I'm thinking, extend / lengthen the bar with the casters from the body 2" or so and move the pivot at the door forward that same number.
I couldn't make a whole lot out of that tutorial for the Furd doors. Just not getting a clear picture of how their hardware works and if it's the same or similar as ours.
But I think you've hit on the complication that I keep seeing any time I think about lengthening that rear/middle trolly thing on ours. Just making it longer works in the open position but then will give it problems closing. So what we need in ours is to somehow make that hardware LONGER when it's open but then back to normal length when it's closed. OR to move the door portion of the connection appropriately forward to allow it all to still happen (your concept). Your idea seems simpler than some kind of "folding bracket" solution.
Unlike the Furds, mine is WELDED to the door (all of them are?). That doesn't make mod's impossible at all but it doesn't make experimentation simple. If it were bolted we could tryout spacers and/or bolt it to different parts of the door and what not just to see what would happen.
Topics: 258
Year: 1989
Postby chevy57bert » January 14th 2015, 3:53pm
A few more.. just make it a little longer..
chevy57bert
Section Moderator
Section Moderator
Firing on 7 Cylinders (L3)
Topics: 67
Images: 33
Alias (AKA): Bertjuh
Year: 1992
Extra Info: Ext 4.3L rwd
Postby Lumpy [OP] » January 14th 2015, 5:14pm
Can you show us more please Bert?
Show it open/closed? Show it from the INSIDE when closed? Construction details etc?
Thanks
Topics: 258
Year: 1989
Postby chevy57bert » January 14th 2015, 7:10pm
I can`t .. Sorry.. not my Astro..
if the hinge is not to long it will fit perfect ..
chevy57bert
Section Moderator
Section Moderator
Topics: 67
Images: 33
Year: 1992
Postby WoodButcher » January 15th 2015, 3:52am
I notice in those pics the latch is not screwed in place. Bert, did you see this yourself and it worked?
I can't imagine that working without a modification of the track.
Wait a minute, the first pic w/o the pins in place the center bar is upside down,,,
the pic with the bolts in might fly.
WoodButcher
Topics: 28
Images: 434
Alias (AKA): Bruce
Year: 1997
Extra Info: 4.3 RWD
Return to Lifted Suspension
It is currently February 24th 2017, 9:02am
Lifted Suspension Forum
scorean
Comments: 30
Date: Jan 28 '17
Time: 7:20am
scorean
Comments: 30
Date: Jan 27 '17
Time: 9:20pm
scorean
Comments: 30
Date: Jan 27 '17
Time: 9:18pm
scorean
Comments: 30
Date: Jan 27 '17
Time: 9:17pm
scorean
Comments: 30
Date: Jan 27 '17
Time: 9:16pm
