Solving the Slider Door with Big Tires Problem
Re: Solving the Slider Door with Big Tires Problem
Postby WoodButcher » February 19th 2015, 4:03am
Same deal w/o the extension, that trolley carries 50% of the door's weight. Adding the extension is adding more leverage to the equation.
Think of a lever and fulcrum, we just tripled the length of the lever.
WoodButcher
Firing on 6 Cylinders (L5)
Topics: 28
Images: 450
Alias (AKA): Bruce
Year: 1997
Extra Info: 4.3 RWD
  • Big shackles
    by andy_b » November 10th 2016, 1:52am in Lifted Suspension
    Last post by andy_b View the latest post
    November 10th 2016, 4:00am
  • Strongest / Safest Way to Ride on 31s Tires
    by ormoto » March 8th 2017, 1:56am in Lifted Suspension
    March 20th 2017, 9:55pm
    March 28th 2017, 8:42pm
Postby WoodButcher » February 19th 2015, 4:09am
Lol. This hinge makes me wish I still smoked weed.
This is one of those things that screams out for a good "sit down" and "look see."
With enough weed I would have sat there for days,,,
or until nature called.
WoodButcher
Topics: 28
Images: 450
Alias (AKA): Bruce
Year: 1997
Extra Info: 4.3 RWD
Postby ronaldperu » February 19th 2015, 4:36am
97cargocrawler wrote:Wow! Some folks have tooooo much free time. Is that RUST damage I see there by the trolley cover?
is that scorpions ness...or is a nest of scorpions ? :confused: :banana-stoner:
ronaldperu
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: ronaldperu has been a member for 3 full yearsronaldperu has been a member for 3 full yearsronaldperu has been a member for 3 full years
Topics: 5
Images: 41
Alias (AKA): ROJO
Year: 1996
Extra Info: ls
Postby Lumpy [OP] » February 19th 2015, 7:45pm
Great improvement this morning. After yesterday's complaint that the trolley was too tight in the track, I loosened it up. Just chuck it up in a vise and hit the small bearings with a 2 lb hammer. Just hit 'em right on the side of the bearing to go LOOSER. Hit 'em on the bracket fingers to go TIGHTER (the other direction). I hit them once toward tighter and it got worse. So I hit them twice toward looser and it's Goldylocks -
It now opens well, slides rearward and forward well and gets close to closing well. Closing still requires that you make sure the trolley has not gone too far forward, then push it with the rear assist handle.
Maybe I'll experiment with a #10 bolt and nut to act as a stop for the forward movement of the trolley.
But for now, it's working great.
Year: 1989
Postby jadesdan » July 12th 2016, 4:06pm
*post deleted*
Lumpy was kind enough to answer my question privately. I still might try this :D
jadesdan
Years of Membership: jadesdan has been a member for 1 full year
Images: 2
Alias (AKA): Dan
Year: 2002
Extra Info: LSE AWD
Postby jadesdan » July 13th 2016, 1:58pm
UPDATE
Since I was responsible for reviving this thread, I feel like I should contribute my two cents.
Once again, I'm jealous of the Gen1 guys :violin:
It appears that the gen2 vans (mine is 2002) have a different bracket and trolley than the gen1. They reversed which side the "backbone" of the hinge ears is on, and the way the whole assembly is stuffed in there, I can't see a way to extend it (although, I do like the ease of disassembly with these three bolts). I'm assuming for you guys who have done the mod, when the door is closed the trolley is pushed inboard an extra 3.5-3.625", but on my van, the trolley is pretty much "bottomed out" when the door is closed. I played around with some ideas of a spring loaded 3-part hinge, and/or an extendable bracket that slides in and out, but I only have about 20 minutes to devote to this this week, so I doubt I'll be exploring those options.
Anyway, I hope this helps the next gen2 guy who really wants bigger tires (or wheel spacers). I haven't given up yet, but I'm close :shock:
looks like I can't even trim my way into bigger tires :violin:
jadesdan
Images: 2
Alias (AKA): Dan
Year: 2002
Extra Info: LSE AWD
Postby jadesdan » July 13th 2016, 9:53pm
So here's my new idea.... if I extend both brackets with a "filler" piece, then I'll maintain the same geometry when the door is closed, but once the trolley rotates 90 or so degrees out, the door will swing wider. The only downside is that I'll have to "notch" a section of the door out to accommodate the longer brackets.
note: the computer sketch is not to scale, but the measurements are there to judge the geometry relations. The second shot is from below and shows the approximate demo section. The blue is where the weather stip mates up.
Thoughts?
jadesdan
Images: 2
Alias (AKA): Dan
Year: 2002
Extra Info: LSE AWD
Postby jadesdan » July 13th 2016, 9:55pm
shot from underneath, looking up
jadesdan
Images: 2
Alias (AKA): Dan
Year: 2002
Extra Info: LSE AWD
Postby 97cargocrawler » July 14th 2016, 12:08am
jadesdan wrote:shot from underneath, looking up
Too bad this is a family friendly site.
Lift it 'till it's no longer an issue :2:
97cargocrawler
Orange Status (L5)
Orange Status (L5)
Years of Membership: 97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years
Topics: 42
Alias (AKA): CC, CARGO, CRAWLER, ASSHOLE
Year: 1997
Postby 97cargocrawler » July 14th 2016, 12:09am
. :roll:
97cargocrawler
Orange Status (L5)
Orange Status (L5)
Topics: 42
Year: 1997
Postby jadesdan » July 14th 2016, 1:38am
How did you deal with the slider before your big lift?
jadesdan
Images: 2
Alias (AKA): Dan
Year: 2002
Extra Info: LSE AWD
Postby 97cargocrawler » July 14th 2016, 4:00pm
jadesdan wrote:How did you deal with the slider before your big lift?
While others messed with the hinges and sliced and diced the door, I left mine alone because I was still able to squeeze my *** through the 12" opening. I knew one day it wouldn't be an issue. I also contemplated (and bought and tested) using airbags to temporarily lift the side of the van high enough to clear the tire. I ended up lifting the van higher and didn't need the air bag.
I experimented with all the bits and pieces and each had a major tradeoff. Clears the tire, makes the door way more difficult to close... etc.
97cargocrawler
Orange Status (L5)
Orange Status (L5)
Topics: 42
Year: 1997
Postby dryhumor » July 19th 2016, 12:13am
I'm thinking about using actuators to make the door open up. My tires kinda stick out a lot now.
dryhumor
Years of Membership: dryhumor has been a member for 3 full yearsdryhumor has been a member for 3 full yearsdryhumor has been a member for 3 full years
Topics: 12
Images: 8
Year: 1999
Extra Info: LS1 someday
Postby MI_Ghost » July 19th 2016, 12:42am
dryhumor wrote:I'm thinking about using actuators to make the door open up. My tires kinda stick out a lot now.
Does that actuator come with the ladder truck your going to need just to get up to the door to open it? :lol: :lol:
~Ghost
Ast' Cargo: 2001 Astro Cargo
MI_Ghost
Years of Membership: MI_Ghost has been a member for 1 full year
Images: 46
Alias (AKA): Ghost
Year: 2001
Extra Info: Big White RWD Box
Postby jadesdan » July 29th 2016, 5:04am
SOLVED!!!!!!!
sort of
So here it fabbed and painted (always paint, right Lumpy?) according to the original design. Unfortunately, the angle that this sits at would require me to notch out a piece of the body frame next to the weather strip.... not going to happen, so it's back to the drawing board.
Version II has a slight hook to it, and clears the van body (it's also reinforced from underneath). Because this one is cocked off to the right (as we're looking at it) it requires a little more trimming of the door.
Here's where I started cutting, using the drywall attachment on my dremel.
It's dull, and slow, but cuts straight and doesn't run off on me :)
Here's close to the final cut. I did notch out the door panel about 1/2" too much, and I ended up having to grind down that section to the left of the bolt holes.
Here's what it looks like when it's closed. Not too bad, but I could have done better. I have a nice piece of rubber strip that should fit in there perfectly.
Here it is open, not pretty, but you'll never see it unless your peaking behind the door.
So why the "sort of" remark? Well, I must have missed one of my measurements, because the door sits rearward in the van about 3/16". It still closes, but it's tight, and will be better when I add a spacer between the 3 hole bracket and the door. That will push it forward when it's in the closed position. Also, I only gained about 1" of extension through this whole thing. It's obviously longer than 1", but because the door now slides at an inward angle to the van, the farther back it slides, the less clearance. I've got another idea to give me that extra 1/2"-1" I need, but I'll save that for another night.
Sorry I don't have any pics of the tire clearance, it got dark and I had to come inside.
jadesdan
Images: 2
Alias (AKA): Dan
Year: 2002
Extra Info: LSE AWD
Postby MI_Ghost » July 29th 2016, 9:06am
I like the Idea, but I couldn't understand the measurements in your drawing.
Looks functional to me. But I have about a gazillion questions.
How long did you lengthen the pieces?
If your tucking the pivot into the door. Would the trim really need to be cut?
How much shorter would it need to be to not go past the seal and require cutting the door open?
Could you do a measurement from the top of the fender lip to the door trim panel?
Stock will be around 1.75" on a cargo, 1.25" on the passenger. I would be interested in the amount of increase.
~Ghost
MI_Ghost
Images: 46
Alias (AKA): Ghost
Year: 2001
Postby jadesdan » July 29th 2016, 5:37pm
Ghost, the measurements in the drawing are no where close to scale. I just "sketched" that up to see the ratio between the length added to the roller and the total door movement.
I just realized that I can add about 1/2" of length to the van side of the roller and it will still be functional, so I'm going to take it off, disassemble (grind and break the welds) and make it longer. When I do that, I'll take measurements.
The other problem with clearance, is the door is no longer parallel to the van body when it's open.... the back of the door is angled away. So when the door is half open (the roller is just passing the wheel) you have the most clearance, but as you keep going backward that distance closes. It's hard to explain, but think about two sides of a triangle... the closer you are to the point, the smaller the gap between to two sides.
Pics and updates to follow.
jadesdan
Images: 2
Alias (AKA): Dan
Year: 2002
Extra Info: LSE AWD
Postby TurnNburn » December 29th 2016, 10:30pm
Now that I am in the territory where this is going to come into a factor when I buy my next set of tires, has anyone come up with a solution to this in the last 6 months on the second gens?
2000 Astro- 7'' lift, NP233C 4x4 T-case, 31x10.5x15 A/T, ongoing camperization in progress
"If you wont drink a beer with me then we probably cant be friends"
Build thread- viewtopic.php?t=103066
TurnNburn
Firing on 7 Cylinders (L1)
Alias (AKA): My friends call me fluffy
Year: 2000
Extra Info: 4x4 Overlander
Postby nosxjeep » February 16th 2017, 5:09pm
Love this!
I mentioned this type of mod in another thread and was led here!
Excellent work from everyone and I love seeing the 2nd Gen Bracket work.
I hope to contribute in the future.
:thumbup:
nosxjeep
Topics: 5
Alias (AKA): NoS
Year: 2005
Extra Info: LS AWD 3+1 30s
Postby sixsix » February 17th 2017, 4:36pm
Bruce, I just went back and reread the thread and it seems a recurring theme is... "make sure the bracket is positioned or oriented..." or "get the bracket to fold back right".
Is it possible that a well-positioned spring or sheet-metal backing might ensure the added length goes the right way before it goes around the corner?
Just a thought & my .02.
Mike
The Van's Build: viewtopic.php?f=127&t=59385
There are 3 types of people in this world - First, the type that can count
and Second, the type that can't.
Firing on 6 Cylinders (L2)
Years of Membership: sixsix has been a member for 2 full yearssixsix has been a member for 2 full years
Topics: 21
Images: 874
Year: 1992
Extra Info: LT W-CPI Motor 200K
PreviousNext
Return to Lifted Suspension
It is currently March 28th 2017, 8:42pm
Lifted Suspension Forum
Attached by: zach914v8
zach914v8zach914v8 is online!
Date: Mar 17 '17
Time: 3:39pm
Comments: 13
Date: Mar 09 '17
Time: 10:53pm
scorean
Comments: 30
Date: Jan 28 '17
Time: 7:20am
scorean
Comments: 30
Date: Jan 27 '17
Time: 9:20pm
scorean
Comments: 30
Date: Jan 27 '17
Time: 9:18pm
