Solving the Slider Door with Big Tires Problem
Re: Solving the Slider Door with Big Tires Problem
Postby WoodButcher » February 17th 2017, 5:47pm
Possibly. There was not much room when closed, Lump tried a stop on the face or back of bracket itself and it got in the way. If the bracket were made with a tang off the top or bottom it may be done, possibly.
WoodButcher
Firing on 7 Cylinders (L5)
Topics: 28
Images: 454
Alias (AKA): Bruce
Year: 1997
Extra Info: 4.3 RWD
  • Strongest / Safest Way to Ride on 31s Tires
    by ormoto » March 8th 2017, 1:56am in Lifted Suspension
    Last post by ormoto View the latest post
    March 30th 2017, 9:55pm
    41
    May 28th 2017, 3:57am
Postby DaveAstro » May 4th 2017, 5:03pm
Coaster wrote:how about a gull wing door and fold down steps??
:D
I didn't need steps, but there's the gullwing
Dave ASTRO, WebMaster - Vanning.Com
90 Astro,"the grey ghost", Haulin A$$, Not kids.
93 Safari, "Lunavan"
E-Z Vanners of Mass, Maine, NY, NJ, England and Finland!!
DaveAstro
Years of Membership: DaveAstro has been a member for 6 full yearsDaveAstro has been a member for 6 full yearsDaveAstro has been a member for 6 full yearsDaveAstro has been a member for 6 full yearsDaveAstro has been a member for 6 full yearsDaveAstro has been a member for 6 full years
Alias (AKA): Dave ASTRO
Year: 1990
Postby sixsixsixsix is online! » May 4th 2017, 7:51pm
Hiya' - Welcome Back. Nice Van.
Well... you got the "Clearing the Wheels" thingie solved.
LOL
How 'bout in the garage or shopping center, tho?
Mike
The Van's Build: viewtopic.php?f=127&t=59385
"Though the hippopotamus has no sting, the wise man would prefer to be sat upon by the bee."
- Banacek
Firing on 7 Cylinders (L2)
Years of Membership: sixsix has been a member for 3 full yearssixsix has been a member for 3 full yearssixsix has been a member for 3 full years
Topics: 21
Images: 880
Year: 1992
Extra Info: LT W-CPI Motor 200K
Postby MI_Ghost » May 5th 2017, 2:18am
Mike
Mike in case you hadn't noticed. That not green asphalt under those tires.
That van is definitely not a parking lot princess.
@ Dave
When you going to update that paint job. Flat Black primer is the rage now!
I think it would look WICKED in flat black! Just leave a little grey ghost shape on the front fender so you can keep the name.
~Ghost
Ast' Cargo: 2001 Astro Cargo
MI_Ghost
Firing on 7 Cylinders (L1)
Years of Membership: MI_Ghost has been a member for 1 full year
Images: 74
Alias (AKA): Ghost
Year: 2001
Extra Info: Big White RWD Box
Postby sixsixsixsix is online! » May 5th 2017, 3:19am
MI_Ghost wrote:Mike in case you hadn't noticed. That not green asphalt under those tires.
I'm glad you squared that away, ghost.
I was worried for Dave there a sec or 2...
Mike
- Banacek
Topics: 21
Images: 880
Year: 1992
Postby nosxjeep » May 15th 2017, 9:41pm
Ok, so crazy idea...
Instead of modifying the hinges of the slider to kick out father, how about kicking out the entire rail that it slides on?
Maybe just in the back on a scissor hinge or something that springs out when the door releases?
Just so you know where the idea came from... I was thinking of running a steel protective bar along the side of the van there. What if i extended the rail to run inside the bar, about 3 inches father out.
nosxjeep
Alias (AKA): NoS
Year: 2005
Extra Info: LS AWD 3+1 30s
Postby TurnNburn » May 15th 2017, 10:28pm
I like what you are thinking...
if you had a donor van you could cut the track off and weld it on top of the stock track. that could work, but then as far as you push it out, will be that much further away from the door seal.
2000 Astro- 7'' lift, NP233C 4x4 T-case, 31x10.5x15 A/T, ongoing camperization in progress
"If you wont drink a beer with me then we probably cant be friends"
Build thread- viewtopic.php?t=103066
TurnNburn
Firing on 8 Cylinders (L1)
Years of Membership: TurnNburn has been a member for 1 full year
Alias (AKA): My friends call me fluffy
Year: 2000
Extra Info: 4x4 Overlander
Postby nosxjeep » May 15th 2017, 10:34pm
Plus, you'd be sticking out the side of the van. Which if you tuck it inside some Boulder bars then that's fine, but otherwise it would look weird.
That's why i was thinking that unbolting or cutting lose the original track and having it pop out on a sort of hinge, but then you'd need to make sure it supports the weight of the door... At least partial weight.
nosxjeep
Alias (AKA): NoS
Year: 2005
Postby 97cargocrawler » May 16th 2017, 8:41am
Believe me, it does NOT work. One day I thought I was the absolute schnitzel and had finally solved this issue, nope. The F'n door was nearly impossible to get latched and part of the upper roller mech scrapes the cover with as little as maybe 1/4" of the track pushed out. It was like 4 hours of wasted time. But maybe you will see some solution I missed.
97cargocrawler
Firing on 2 Cylinders (L5)
Years of Membership: 97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years
Topics: 42
Alias (AKA): CC, CARGO, CRAWLER, ASSHOLE
Year: 1997
Postby nosxjeep » May 16th 2017, 3:30pm
The other 2 rollers were my concern as from just looking at them i can't visualize where binding would occur. I'll have to prop the door up, pull the rear roller off and see.
But CC, what do you mean by "scraping the cover"?
I guess I'll see it for myself eventually.
nosxjeep
Alias (AKA): NoS
Year: 2005
Postby 97cargocrawler » May 16th 2017, 4:09pm
nosxjeep wrote:The other 2 rollers were my concern as from just looking at them i can't visualize where binding would occur. I'll have to prop the door up, pull the rear roller off and see.
Center roller/track section, the outer cosmetic panel that covers the track. The cover attaches to the body sheet metal so it stays put while the track will move outward with spacers etc. The arm that holds the roller will scrape the backside of the cosmetic panel. There's very little clearance behind the panel. If you were to eliminate the panel no worries at all, it will just look hideous with the center section of your body panel missing. I contemplated losing the panel altogether but I still had issues with the door not wanting to latch. I had to slam it with hands both on the front and rear of the slider. I could see losing a finger so I reverted back to stock. Moving the track out does allow for tire clearance but opens up a whole new can of worms.
The tapered effect might work better.
97cargocrawler
Topics: 42
Year: 1997
Postby nosxjeep » May 16th 2017, 8:33pm
Ah! OK, I know what you mean now... for some reason I was thinking that you were talking about one of the other rollers, but yes the middle track "cover" would definitely need to go!
I had 2 different ideas:
1) run a steel bar as a rear quarter off road guard and run the track inside it (with an obvious extension so it still goes into its stock forward location.
2) stay more stock and have both the track and the cover mounted to a reinforced angled steel swing out in the back (but not in front) creating a diagonal line away from the van.
nosxjeep
Alias (AKA): NoS
Year: 2005
Previous
Return to Lifted Suspension
It is currently May 28th 2017, 3:57am
Lifted Suspension Forum
Rockridge
Date: May 17 '17
Time: 3:06pm
Rockridge
Date: May 17 '17
Time: 12:28pm
Comments: 14
Date: May 17 '17
Time: 2:00am
Attached by: nosxjeep
nosxjeep
Comments: 91
Date: May 16 '17
Time: 8:33pm
Comments: 14
Date: May 15 '17
Time: 8:33pm
