Replacing Upper Ball Joint: what am I doing wrong?
Postby Astrodawn [OP] » March 18th 2017, 7:14pm
how tf do you drill out these rivets?
http://imgur.com/a/PIMy6
Astrodawn
Topics: 19
Year: 1998
Extra Info: LT 4.3L V6 AWD
  • New Upper Control Arm Kit
    by Mmusicman » February 27th 2017, 5:05pm in Stock Suspension
    Last post by WoodButcher View the latest post
    February 28th 2017, 4:52am
    44
    May 29th 2017, 1:18am
Re: Replacing Upper Ball Joint: what am I doing wrong?
Postby safariking » March 18th 2017, 7:17pm
better to grind them off a dremmell might work then just hit them with a punch they'll come out after you grind them off smack the top with a hammer
safariking
Years of Membership: safariking has been a member for 4 full yearssafariking has been a member for 4 full yearssafariking has been a member for 4 full yearssafariking has been a member for 4 full years
Topics: 19
Images: 9
Year: 1999
Extra Info: SLE 4.3
Postby Astrodawn [OP] » March 18th 2017, 7:21pm
i don't have a dremel, just a drill.
but thanks!
Astrodawn
Topics: 19
Year: 1998
Postby Coaster » March 18th 2017, 7:45pm
i used an air chisel. it literally took 10 seconds per ball joint.
Coaster
Firing on 8 Cylinders (L1)
Years of Membership: Coaster has been a member for 4 full yearsCoaster has been a member for 4 full yearsCoaster has been a member for 4 full yearsCoaster has been a member for 4 full years
Topics: 102
Year: 1995
Extra Info: 4.3 cargo 2wd
Postby Mmusicman » March 18th 2017, 8:12pm
Just did mine... did it the easy way! :mrgreen:
viewtopic.php?p=1160298#p1160298
2000 Chevy Astro LS AWD | 31" LT265/70R17 Tires | 8" LIFT | 10" TOTAL
92 Chevy Astro Shorty | V8-350
Firing on 8 Cylinders (L2)
Years of Membership: Mmusicman has been a member for 3 full yearsMmusicman has been a member for 3 full yearsMmusicman has been a member for 3 full years
Topics: 35
Year: 2000
Extra Info: 2000 AWD 92 V8-350
Postby Astrodawn [OP] » March 18th 2017, 8:21pm
i've considered all these options, but i'm doing it the cheapest way i can (not buying the whole control arm + paying for realignment) and using the tools i have available (a drill).
i'm not familiar with using drills yet, so do i just need to keep chipping away at the rivets? am i not applying enough force/using the right drill bits/drilling it from the right side?
i'm tired. haha.
Astrodawn
Topics: 19
Year: 1998
Postby chevymaher » March 18th 2017, 8:24pm
Probably dulled the bit. Use a new one and keep oil on it. If it smokes stop and let it cool. Just keep at it your almost there.
Topics: 83
Year: 1994
Postby Astrodawn [OP] » March 18th 2017, 8:35pm
am i going for depth or trying to grind down the rivet to be flush with the joint?
Astrodawn
Topics: 19
Year: 1998
Postby Coaster » March 18th 2017, 8:44pm
once you remove the top of the rivet just pry the ball joint off the arm. again, i used my air chisel to pry the ball joint off in seconds after air chiselling off the rivets.
air chisels are cheap and awesome
Coaster
Topics: 102
Year: 1995
Postby chevymaher » March 18th 2017, 8:48pm
Astrodawn wrote:am i going for depth or trying to grind down the rivet to be flush with the joint?
No once it is even with the top it should drive out with a punch.
Topics: 83
Year: 1994
Postby M_a_t_t » March 18th 2017, 8:49pm
Also drill bits work better spinning one way or the other. Typically righty tighty/clockwise looking at the back of the drill
M_a_t_t
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: M_a_t_t has been a member for 2 full yearsM_a_t_t has been a member for 2 full years
Topics: 12
Year: 1995
Extra Info: cl rwd
Postby Astrodawn [OP] » March 18th 2017, 9:13pm
http://m.imgur.com/ZjuA0h6
Thanks for all the help!
How do I get it all flush? Do I need to use a bigger bit or?
Astrodawn
Topics: 19
Year: 1998
Postby Coaster » March 18th 2017, 9:16pm
use a cold chisel and a hammer to separate the joint from the arm
Coaster
Topics: 102
Year: 1995
Postby Astrodawn [OP] » March 18th 2017, 9:37pm
I don't have a chisel.
I'm trying to punch it out now, but I'm not sure it's ready to go. Can someone look at my previous photo and tell me if I need to drill more?
Astrodawn
Topics: 19
Year: 1998
Postby Astro Pop » March 18th 2017, 10:04pm
Larger drill. If they dull up grab the next larger one. Perfect size doesn't matter here just get the top off them beat the $h** out of it to loosen it up. Like Maher said lots of WD40 or thin oil to lubricate the bit and keep it sharp.
Astro Pop
Firing on 7 Cylinders (L1)
Years of Membership: Astro Pop has been a member for 5 full yearsAstro Pop has been a member for 5 full yearsAstro Pop has been a member for 5 full yearsAstro Pop has been a member for 5 full yearsAstro Pop has been a member for 5 full years
Topics: 26
Images: 8
Alias (AKA): Xfirepop
Year: 1996
Extra Info: AWD - 3 inch lift
Postby Coaster » March 18th 2017, 10:08pm
Astrodawn wrote:I don't have a chisel.
go buy one. they cost around $2
Coaster
Topics: 102
Year: 1995
Postby Astrodawn [OP] » March 18th 2017, 11:41pm
Astro Pop wrote:Larger drill. If they dull up grab the next larger one. Perfect size doesn't matter here just get the top off them beat the $h** out of it to loosen it up. Like Maher said lots of WD40 or thin oil to lubricate the bit and keep it sharp.
ok thanks. took a nap, ate some food, i'm going to try again. this machine WILL bend to my will dammit.
Astrodawn
Topics: 19
Year: 1998
Postby safariking » March 18th 2017, 11:51pm
if you don't have a chisel use a big screwdriver like a chisel hammer it between the control arm and ball joint it will seperate by the looks of your pictures your close
safariking
Topics: 19
Images: 9
Year: 1999
Extra Info: SLE 4.3
Postby Rinny » March 19th 2017, 12:08am
Milled off the top of the rivets and punched them out.
I would say it is easier to just take the control arm out?
Rinny
Years of Membership: Rinny has been a member for 1 full year
Year: 2003
Extra Info: AWD 2 INCH LIFT
Postby Astrodawn [OP] » March 19th 2017, 12:11am
Pretty sure I just dulled the largest bit. Wooooo.
This sucks.
There's hardly any clearance in the wheel well to use a hammer to punch these out.
Astrodawn
Topics: 19
Year: 1998
Return to Stock Suspension
It is currently May 29th 2017, 1:18am
Stock Suspension Forum
astronot
in Stock Suspension
Comments: 26
Date: May 24 '17
Time: 2:17am
Comments: 57
Date: May 17 '17
Time: 9:22pm
Comments: 57
Date: May 17 '17
Time: 7:55pm
Comments: 57
Date: May 17 '17
Time: 7:52pm
Comments: 57
Date: Apr 22 '17
Time: 4:47am
