I searched but cant find. Is there a bushing kit available to swap front end bushings to urethane? If so what bushings would I do?
Just saw this mod on a car show & wondered if anyone had done it to their astro
by smokinjoe [OP] » February 21st 2012, 6:19am
by Phantom » February 21st 2012, 6:50am
by smokinjoe [OP] » February 21st 2012, 9:25pm
by kennyj » February 22nd 2012, 1:40am
smokinjoe wrote:So when trying to buy them I have a choice of 2 sizes, 1 5/8 or 1 1/4 (I think) Shouldnt there be just one size on a 95 2wd astro?
by Phantom » February 22nd 2012, 2:08am
by Chevymankevin » February 22nd 2012, 5:37pm
95 Safari Daily driver 185K
by smokinjoe [OP] » February 22nd 2012, 8:05pm
by Chevymankevin » February 22nd 2012, 10:20pm
by tireboy » February 24th 2012, 7:48am
Urethane bushings are very common upgrade for sway bar frame mounts and end link kits as it will help stiffen the sway bar and give a better steering response , providing a better handling vehicle ,,, there are several brands available , but I prefer the Moog graphite impregnated bushings as they have a graphite lubricant permanently in them so you never have to use a grease gun on them.
Other brands need to use a grease fitting to lube them as they will squeak if they are not lubed ..you can get the bushings at Advance auto for about 20 dollars for both sides , they are on their website the Moog are a blue color
This is about as far as you would really need to go for a street driven vehicle because when you change the control arm bushings to Urethane bushings it will stiffen up the ride quality so much that it can make for a rough ride which may make it too stiff to enjoy , but that depends on what you prefer, this extent is more for vehicles that are driven off road a lot or carry very extreme heavy loads and need that extra stiffness for control
It is currently May 26th 2013, 2:03am
| Stock Suspension Forum |
| Moderator: chevy57bert |
| Previous topic Next topic |
| Recent Image Attachments | |||
| Sponsors |
Users browsing this forum: Baiduspider [Spider] and 1 guest
