Leaf spring squeak
Leaf spring squeak
Postby Astronaught [OP] » October 7th 2010, 3:21am
Anyone else have their leaf springs squeak? I just replaced mine and now they squeak, almost like a lurch when I start to move. Is there something I should have greased?
Astronaught
Years of Membership: Astronaught has been a member for 2 full yearsAstronaught has been a member for 2 full years
Extra Info: 4.3 RWD
  • What size (leaf) springs?
    by DOcean » March 11th 2013, 12:44am in Stock Suspension
    Last post by DOcean View the latest post
    March 11th 2013, 10:42pm
  • Spring Help Please
    by Astro93cpi » April 25th 2013, 4:03am in Stock Suspension
    Last post by Corsemoto View the latest post
    April 25th 2013, 8:13am
    73
    May 21st 2013, 4:04pm
Re: Leaf spring squeak
Postby astroturf » October 7th 2010, 11:39am
Not that I am aware of.
How old are your shocks?
Jim
astroturf
Years of Membership: astroturf has been a member for 3 full yearsastroturf has been a member for 3 full yearsastroturf has been a member for 3 full years
Topics: 112
Extra Info: 2wd Passenger
Postby hardlecure » October 7th 2010, 12:20pm
mine do.. it's kind of embarrassing actually. I wonder if it's not the rubber parts at the end where the bolts hold it to the body have dried up and are now making the noise.
A$$, Gas or Grass.... Nobody Rides For Free
hardlecure
Years of Membership: hardlecure has been a member for 3 full yearshardlecure has been a member for 3 full yearshardlecure has been a member for 3 full years
Extra Info: One Wheel Peel
Postby Lumpy » October 7th 2010, 3:48pm
hardlecure wrote:mine do.. it's kind of embarrassing actually. I wonder if it's not the rubber parts at the end where the bolts hold it to the body have dried up and are now making the noise.
If this van's squeekin', don't be peekin'.
Firing on 2 Cylinders (L4)
Topics: 116
Year: 1989
Extra Info: 9 in. lift Camo
Postby chevy57bert » October 7th 2010, 7:20pm
There is no harm done to get those leaves greased up..
Check if the ends off the leaves are not wear out.
chevy57bert
Section Moderator
Section Moderator
Years of Membership: chevy57bert has been a member for 3 full yearschevy57bert has been a member for 3 full yearschevy57bert has been a member for 3 full years
Topics: 66
Alias (AKA): Bertjuh
Extra Info: Ext 4.3L rwd
Postby unrreal » October 7th 2010, 10:58pm
Astronaught wrote:Anyone else have their leaf springs squeak? I just replaced mine and now they squeak, almost like a lurch when I start to move. Is there something I should have greased?
mine have begun to squeak on the front spring hangers on both sides of the van, i guess is the added stress of the leafs i put on there with more arc :twisted: thats just my guess though
unrreal
Years of Membership: unrreal has been a member for 3 full yearsunrreal has been a member for 3 full yearsunrreal has been a member for 3 full years
Topics: 21
Images: 12
Year: 1999
Extra Info: 4.3 ls awd
Postby Astronaught [OP] » October 9th 2010, 3:19am
So it sounds like a fairly common problem. I will probably grease the rubber boot a bit to see if that helps. I also think I may not have torqued the metal saddle bracket down tight enough which could definitley be causing the issue. We will see
Astronaught
Extra Info: 4.3 RWD
Postby hardlecure » October 31st 2010, 2:27am
I spoke to my dad about it. He says to jack up the back of the van until the rear tires are off the ground with the suspension fully relaxed and spray graphite lube between the leaf springs and it should make the squeaks go away.
Though I haven't done it yet I think the best way to do this would be to put a couple bricks at the front tires to stop the van from rolling forward, stack up some bricks under the back end with jack stands on top of them, using a floor jack under the pumpkin, and jack it up a bit while incrementally moving the jack stands up one notch at a time under the 2 frame rails at the rear (just in case the van tips), when you get the rear tires off the ground about 6 - 8 inches, lower the van down into the groves on top of the jack stands SLOWLY, this should allow the leaf spring to extend to the most relaxed position and then lube to your hearts content.
hardlecure
Postby chevy57bert » October 31st 2010, 8:06pm
hardlecure wrote:relaxed position and then lube to your hearts content.
:goodpost:
chevy57bert
Section Moderator
Section Moderator
Topics: 66
Postby earlman » November 8th 2010, 10:27am
Yeah, my 97 squeaks. I'll be trying some graphite lube.
earlman
Years of Membership: earlman has been a member for 3 full yearsearlman has been a member for 3 full yearsearlman has been a member for 3 full years
Topics: 7
Extra Info: LT 4.3L V6 RWD
Return to Stock Suspension
It is currently May 21st 2013, 4:04pm
Stock Suspension Forum
Attached by: musicmaestro
musicmaestro
in Stock Suspension
Date: Apr 20 '13
Time: 9:53pm
Attached by: markmitch
in Stock Suspension
Date: Apr 09 '13
Time: 7:07pm
Date: Mar 17 '13
Time: 5:12pm
navymaverick
in Stock Suspension
Comments: 18
Date: Mar 08 '13
Time: 9:43pm
Comments: 29
Date: Nov 27 '12
Time: 5:41pm
