What headers fit 1996 or newer Vortec V8 Astro?
Postby webcat [OP] » February 12th 2011, 2:55am
I see that almost everyone is using the headman headers 68600 for the older style Astros but what about the 1996 and up ?
webcat
Firing on 3 Cylinders (L3)
Topics: 253
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
  • 97 Astro 5.7 Vortec V8 Swap
    by akforceten » February 13th 2017, 11:57pm in V8 Swap
    Last post by akforceten View the latest post
    February 15th 2017, 5:52pm
  • Hedman headers!
    by nwmod39 » February 22nd 2017, 3:31am in V8 Swap
    Last post by nwmod39 View the latest post
    February 23rd 2017, 5:09am
    63
    May 28th 2017, 4:07am
Re: What headers fit 1996 or newer Vortec V8 Astro?
Postby chevymaher » February 12th 2011, 3:19am
I just did a web search.Seems lacking any listings for newer years.So I looked up exhaust manifolds.They are exactly the same at the top and the angle where the pipe bolts on slightly different.I would bet same part fits newer models.A guy I know changed heads on a S-10 from old stlye 90 to new stlye 97 vortec and he used the same exhaust he had.That what got me thinking they the same.It was a V-8I never done it but I bet they the same.
Topics: 83
Year: 1994
Postby Phantom » February 12th 2011, 5:23am
I was looking up listings and seems that since there is only a small market for headers for Astros , you may have to contact some muffler shops or speed shops that may have knowledge on what are interchangeable , I looked up headers for S-10 Blazer with the 4.3L and the parts that they showed are the same as for the V8 ,
http://www.summitracing.com/search/Depa ... s=Rank|Asc
Phantom
Firing on 7 Cylinders (L4)
Postby webcat [OP] » February 12th 2011, 7:57pm
Wow, i did'nt know they sold them like that where you could remove 1 tube on each header to make them work on a V6 .
webcat
Topics: 253
Postby Mr_Roboto » February 15th 2011, 5:33am
It's probably for clearancing an S10. I know that you have to remove the steering shaft otherwise which is a pain.
Mr_Roboto
Firing on 8 Cylinders (L1)
Years of Membership: Mr_Roboto has been a member for 9 full yearsMr_Roboto has been a member for 9 full yearsMr_Roboto has been a member for 9 full yearsMr_Roboto has been a member for 9 full yearsMr_Roboto has been a member for 9 full yearsMr_Roboto has been a member for 9 full yearsMr_Roboto has been a member for 9 full yearsMr_Roboto has been a member for 9 full yearsMr_Roboto has been a member for 9 full years
Topics: 37
Postby Hot Rod Astro » May 10th 2012, 4:04pm
Hey out there!! I purchased a set of Pace Setter headers for an S10 4.3 the drivers side header had to be cut up and reshaped because they are designed to have the steering column slip through one of the tube bends. It's been quite a headache but they'll get'er done. It takes a big man to buy headers for an Astro Van but it takes a bigger man ta cut'em up!! Also the spark plug wires are becoming an issue, will probably have to go to L shaped ends because when they come straight out they're to close to the header pipes in a couple instances.
This is a 97 base Astro Van 4.3 liter rear wheel drive with, Magnaflow exhaust system, ram air, Pace Setter Headers, Maxxis White Walls in the front, Maxxis HT 750s in the back, Burgundy powder coated rims, KYB MonoMax shocks all the way around, Burgundy curtains in rear side windows bow tied, and I had the front springs cut 2" so it got the lean. Also am having the grill painted green but flat, no clear coat and the turning signal lenses tinted amber.
My little Hot Rod Astro!!!! Pics to come after job is finished!!!!
Hot Rod Astro
Years of Membership: Hot Rod Astro has been a member for 5 full yearsHot Rod Astro has been a member for 5 full yearsHot Rod Astro has been a member for 5 full yearsHot Rod Astro has been a member for 5 full yearsHot Rod Astro has been a member for 5 full years
Alias (AKA): Hot Rod Astro
Year: 1997
Postby wheels55 » May 25th 2012, 4:59pm
I used a set of G8 GT Kooks Long Tubes. I have a 2001 Astro 2WD and a 2007 5.3L in it. Driver side slid right in. Passenger side needed one of the primary pipes rerouted slightly.
:layrubber:
2001 Astro 2WD
5.3L / Built 4L60e
EST 450BHP -- 372HP/345TQ @ Rear Tires
Precision Industries Vigilante 3000
LG G5Xe cam/Comp Cams 921 springs
Kooks Longtube Headers
2007 Trailblazer SS ECM/TCM
Magnaflow muffler and resonator
wheels55
Years of Membership: wheels55 has been a member for 9 full yearswheels55 has been a member for 9 full yearswheels55 has been a member for 9 full yearswheels55 has been a member for 9 full yearswheels55 has been a member for 9 full yearswheels55 has been a member for 9 full yearswheels55 has been a member for 9 full yearswheels55 has been a member for 9 full yearswheels55 has been a member for 9 full years
Topics: 16
Images: 47
Year: 2001
Extra Info: 5.3L V8 372-RWHP
Return to V8 Swap
It is currently May 28th 2017, 4:07am
V8 Swap Forum
Rinny
in V8 Swap
Comments: 170
Date: May 25 '17
Time: 12:57am
Rinny
in V8 Swap
Comments: 170
Date: May 25 '17
Time: 12:50am
dryhumor
in V8 Swap
Comments: 18
Date: May 22 '17
Time: 5:18pm
dryhumor
in V8 Swap
Date: May 22 '17
Time: 1:15am
Rinny
in V8 Swap
Comments: 170
Date: May 19 '17
Time: 10:56am
