Distributor mark wont line up
Postby sfeaver [OP] » May 9th 2010, 12:35am
I am putting a L31 350 V8 into my van, and got a LT4 camshaft to go in the motor. Its almost all together, and I go to put in the distributor but it wont line up to the "8" mark right on, its a few degrees before it. One tooth over its past it.
I took off the timing cover and confirmed the dots line up on the gears. It appears that advancing the cam one tooth would put the distributor bang on.
My question, is how accurate is that mark on the distributor? I confirmed on my 4.3 that it is bang on with it at #1 TDC.
Thanks for any advice..
Scott
sfeaver
Firing on 7 Cylinders (L1)
Years of Membership: sfeaver has been a member for 8 full yearssfeaver has been a member for 8 full yearssfeaver has been a member for 8 full yearssfeaver has been a member for 8 full yearssfeaver has been a member for 8 full yearssfeaver has been a member for 8 full yearssfeaver has been a member for 8 full yearssfeaver has been a member for 8 full years
Topics: 25
Year: 1997
Extra Info: LT RWD 350ci V8
  • Anyone have LS swap fuel line pics?
    by dryhumor » May 11th 2017, 5:26am in V8 Swap
    Last post by dryhumor View the latest post
    May 22nd 2017, 4:17am
    7
    69
    June 26th 2017, 3:05am
Re: Distributor mark wont line up
Postby LEVE » May 9th 2010, 2:53am
Take a look at cylinder #1. Are both valves closed? They should be.... If they're not, you're not at Zero degrees of the Power stroke.
LEVE
Years of Membership: LEVE has been a member for 7 full yearsLEVE has been a member for 7 full yearsLEVE has been a member for 7 full yearsLEVE has been a member for 7 full yearsLEVE has been a member for 7 full yearsLEVE has been a member for 7 full yearsLEVE has been a member for 7 full years
Topics: 18
Extra Info: AWD 4.3L-W
Postby sfeaver [OP] » May 9th 2010, 3:07am
I think I got it figured out.. I bought an aftermarket aluminum distributer, and its clamp is "fixed" meaning it bolts in one spot.
The factory plastic one isnt, and if turned a bit it lines right up. So I think all I need to do is change clamps and line it up. Too bad I pulled the timing cover back off (and water pump, compressor, ps pump bracket etc) hehe Oh well.
If it sound like i goofed somewhere here please let me know!
Scott
sfeaver
Topics: 25
Year: 1997
Postby sfeaver [OP] » May 9th 2010, 3:09am
Leve: Ya both valves closed. Both timing marks pointing at 12 o'clock. But see my other post, i think i figured it out..
Thanks,
Scott
sfeaver
Topics: 25
Year: 1997
Postby sfeaver [OP] » January 5th 2011, 1:35am
Just to update this for others in case they run into this.. You need to set proper timing with the scan tool. So that 8 mark isnt exact. I was fine in the first place. Also, since the computer handles timing, even being off one tooth the motor runs smooth. I couldnt believe it. Just need to set CMP retard to 0 degrees to clear the check engine light.
Scott
sfeaver
Topics: 25
Year: 1997
Return to V8 Swap
It is currently June 26th 2017, 3:05am
V8 Swap Forum
timothy47130
in V8 Swap
Comments: 37
Date: Jun 23 '17
Time: 2:27am
RinnyRinny is online!
in V8 Swap
Comments: 232
Date: Jun 21 '17
Time: 10:25pm
timothy47130
in V8 Swap
Date: Jun 20 '17
Time: 4:47pm
Attached by: markmitch
in V8 Swap
Date: Jun 20 '17
Time: 3:49pm
in V8 Swap
Date: Jun 20 '17
Time: 3:17am
Users browsing this forum: Google Adsense [Bot] and 2 guests
