Best fuel pump to use??
Postby kartracer [OP] » March 22nd 2015, 5:17am
What is the best fuel pump to install in the tank for a V8 conversion. I am questioning whether the stock 4.3 pump is up to the task.
kartracer
Years of Membership: kartracer has been a member for 2 full yearskartracer has been a member for 2 full years
Alias (AKA): JMR
Year: 1996
Extra Info: 5.7L 4L80E RWD
  • 5.7L high output oil pump question
    by Rinny » April 7th 2017, 7:01pm in V8 Swap
    Last post by Rinny View the latest post
    April 9th 2017, 12:40am
    27
    April 24th 2017, 12:40am
Re: Best fuel pump to use??
Postby AstroWill » March 22nd 2015, 5:50am
The stock pump will work fine if using the same type of injection.
Firing on 1 Cylinder (L6)
Topics: 63
Images: 111
Extra Info: 90TigerGTv8 03AWD
Postby RECox286 » March 22nd 2015, 6:36am
Volumn from a stock pump should be enough for 2 v6's.
Uncle Bob
RECox286
Topics: 39
Alias (AKA): Uncle Bob
Year: 1993
Extra Info: RWD V6 [325K mi]
Postby redfury » March 22nd 2015, 10:51pm
I looked into this and emailed a tech from Delphi. The pump itself is used for multiple gm models, from express vans to trucks and some cars. The difference between the models is the "frame" the pump is housed in to take into account the difference in fuel tank configurations.
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Year: 1998
Extra Info: LT 5.7L 4wd
Postby kartracer [OP] » March 22nd 2015, 11:02pm
THANK YOU ALL!!!!!!!!!!!!!!!!!!
kartracer
Alias (AKA): JMR
Year: 1996
Return to V8 Swap
It is currently April 24th 2017, 12:40am
V8 Swap Forum
Rinny
in V8 Swap
Comments: 160
Date: Apr 20 '17
Time: 11:28pm
Rinny
in V8 Swap
Comments: 160
Date: Apr 19 '17
Time: 2:46am
Rinny
in V8 Swap
Comments: 160
Date: Apr 16 '17
Time: 3:49am
Rinny
in V8 Swap
Comments: 160
Date: Apr 14 '17
Time: 12:28am
Rinny
in V8 Swap
Comments: 160
Date: Apr 13 '17
Time: 5:11am
