V8 SWAP LIST
V8 SWAP LIST
Postby chops [OP] » April 30th 2008, 3:15am
I have taken what many of the Original members have listed on the old site of what is needed and what is recommend to get for the TBI V8 swap so here it is if I missed anything let me know and I gladly add it to this list and hopefully it will get pinned.
1) The V8 (Preferably same year as your van but not necessary)
2) Motor Mounts (Available Two places Through Jakepatch or http://www.jagsthatrun.com)
3) TB bracket from V8 if not on motor
4) V8 fuel injectors (Need to put them on Astro TBI don’t forget rebuild kit)
5) 7747 computer w/V8 chip Or new chip from http://www.tbichips.com
6) V8 exhaust manifolds or Headman headers (68600) (use copper gaskets)
7) V8 distributor
8) Wire and connectors to lengthen some wires
9) Nipple for the back of the manifold
10) V8 knock sensor if using TBI
11) Truck valve covers
12) Thermostat housing for V8 (Don’t use V6 housing hole too small)
13) Front tranny seal (better do it now while its easy to get too)
14) Transgo shift kit
The following has been recommended by several members
(You don’t need but are strongly recommended)
1) intake w/ all acc. connected from an 87-92 van or truck 305 or 350 will make connecting everything easy to connect rather than trying to make the V6 stuff fit.
2) Tranny cooler
3) Oil cooler
4) Flowkooler disc in waterpump vanes
5) 3 flu radiator out of an 89 Astro (heavy duty)
6) Taurus electric fan
7) vette servo
hope this helps you all!!! :banana: :layrubber:
If your gonna street race dont be affraid to go to the left!
chops
Years of Membership: chops has been a member for 9 full yearschops has been a member for 9 full yearschops has been a member for 9 full yearschops has been a member for 9 full yearschops has been a member for 9 full yearschops has been a member for 9 full yearschops has been a member for 9 full yearschops has been a member for 9 full yearschops has been a member for 9 full years
Topics: 40
Alias (AKA): Thechopfather
  • 97 Astro 5.7 Vortec V8 Swap
    by akforceten » February 13th 2017, 11:57pm in V8 Swap
    Last post by akforceten View the latest post
    February 15th 2017, 5:52pm
  • V8 swap mounts recomendation
    by codydaniels » September 10th 2016, 9:29am in V8 Swap
    Last post by bubbalowe View the latest post
    September 22nd 2016, 2:50pm
    100
    February 24th 2017, 4:35am
Re: V8 SWAP LIST
Postby cavegearhauler » May 27th 2008, 3:47pm
Hey Chops thats a pretty complete list but I wonder if it works out as well for the 97 and up folks.
I have a 99 and will probably buy a 5.7 to replace the knocking 4.3 that i have now but don't want so much of a hot rod. I have other crap for that so I am thinking of buying a complete motor with TBI on it and everything. That way all I need is the stock 5.7 exhaust and ... ? I know I will need new mounts and all but what else should I need if I buy the motor complete? Whats that about a nipple for the manifold? Is this a early astro need? Why would I need to change the valve covers as well? OK I know, I know, lots of questions but I like to be prepared!
I also think I am going to cut through the front of my copre support to pull the motor. I need to pull one fender off anyway to replace it and repair the inner panel beneath it anyway so what one more side. I already have the new bumper and the new fender and little pieces and painted them to match the body so they are ready to go on after the swap! I also think I will be eventually swapping out the front bumper with a modified late 90s ford f 150 bumper to have a steel bumper that I can winch,pull and tie to. Plus it will look sharp with the gurad and the lift! ;-)
thanks all. Listen if you have done this swap on a later model van and have some tips or advice please feel free to help me out. I am good with making mods and repairs but not with researching mundane details on swaps. I am more old school and have delt with three and five wire engines.
thanks in advance!!
Matt
cavegearhauler
Years of Membership: cavegearhauler has been a member for 8 full yearscavegearhauler has been a member for 8 full yearscavegearhauler has been a member for 8 full yearscavegearhauler has been a member for 8 full yearscavegearhauler has been a member for 8 full yearscavegearhauler has been a member for 8 full yearscavegearhauler has been a member for 8 full yearscavegearhauler has been a member for 8 full years
Location: Im in the panhandle of Florida between Pensacola and Panama City.
Alias (AKA): Matt/Cavin'Safari
Re: V8 SWAP LIST
Postby chops [OP] » May 28th 2008, 2:45am
everything I have read and heard is if you go with the same year everything is basically plug and play I am in the process of doing my V8 swap but I eliminated the computer and am going carbed lil more intense from my understanding. that list is a basic list. the ones to really talk to on this is safarirob,lockdoc,rebel and a few others [Rule 21 Violation]they have and still are answering many of my questions...
Last edited by AstroAustin on September 26th 2008, 9:58pm, edited 1 time in total.
Reason: This post does not comply with forum rules (Rule 21), the infraction in this post has been removed and this post has been locked.
chops
Topics: 40
Re: V8 SWAP LIST
Postby cavegearhauler » May 28th 2008, 12:27pm
Thanks Chops...
Well I will make this an open invitation to "those who know", if I can use the same motor and go plug-n-play that might make it easier on me then buying a new comp or even a chip. Chops, I thought of going carbed and I have a 305 set-up ready to go but its going in another ride (the '49 you see as my avatar) that was already down for the new engine when the van started to go (arrgh!) so I thought I would keep it TBI and everything else works pretty well so no complaints there. Its already been down almost a month so I need to get it going and would much rather do a "swap" than a "build" right now, thus the interest in simplification, so folks if you have personal experience in swapping a 5.7 v8 in and you used the same year and just plugged in the harness and it was fine please let me know-- in fact let me know if it didn't go fine too! I could really use the firsthand knowlege here! That would make it much easier on me and make the list a little shorter.... right now I have headers, v8, new mounts, and thats pretty much it other than some wiring stuff which I would think would be easy, especially if I buy a complete motor and have the wiring on it.
Well thanks in advance anybody, I truly do appreciate it!
Matt
cavegearhauler
Re: V8 SWAP LIST
Postby trendkiller » May 29th 2008, 4:39am
So, even if you have a 93-95 van, you should use the 7477 computer? (7477 translates to 89-92 from my information)
trendkiller
Years of Membership: trendkiller has been a member for 8 full yearstrendkiller has been a member for 8 full yearstrendkiller has been a member for 8 full yearstrendkiller has been a member for 8 full yearstrendkiller has been a member for 8 full yearstrendkiller has been a member for 8 full yearstrendkiller has been a member for 8 full yearstrendkiller has been a member for 8 full years
Re: V8 SWAP LIST
Postby cavegearhauler » May 29th 2008, 2:21pm
I have no idea on that either.... I have a 99 safari so that even further away from the earlier models. I wonder if I get the computer and all from the donor vehicle if can simply take the ECM out of the other computer and if its the same year just stick it in my computer? Is this possible even? I am well out of my expertise here....
thanks,
Matt
cavegearhauler
Re: V8 SWAP LIST
Postby midwestls » October 4th 2008, 1:59pm
cavegearhauler wrote:I have no idea on that either.... I have a 99 safari so that even further away from the earlier models. I wonder if I get the computer and all from the donor vehicle if can simply take the ECM out of the other computer and if its the same year just stick it in my computer? Is this possible even? I am well out of my expertise here....
thanks,
Matt
I'm kinda wondering the same actually. With a (In my case) 95 pickup ECM work with it's own motor in my 95 AWD??? Not saying I'm doing it yet but defiantly thinking about it? I want everything to still work properly though (ex tranny, AWD, cruise ect...).
midwestls
Years of Membership: midwestls has been a member for 8 full yearsmidwestls has been a member for 8 full yearsmidwestls has been a member for 8 full yearsmidwestls has been a member for 8 full yearsmidwestls has been a member for 8 full yearsmidwestls has been a member for 8 full yearsmidwestls has been a member for 8 full yearsmidwestls has been a member for 8 full years
Re: V8 SWAP LIST
Postby 68 TT » October 22nd 2008, 6:03pm
The 93 to 95 engines use the OBD-1.5 PCM which also controls the electronic transmission functions. It is PCM # 16197427.
68 TT
Years of Membership: 68 TT has been a member for 8 full years68 TT has been a member for 8 full years68 TT has been a member for 8 full years68 TT has been a member for 8 full years68 TT has been a member for 8 full years68 TT has been a member for 8 full years68 TT has been a member for 8 full years68 TT has been a member for 8 full years
Re: V8 SWAP LIST
Postby lotuseclat767 » March 11th 2009, 12:59am
Chops,
You still around? I noticed that you mentioned using the V-8 knock sensor instead of the V-6 knock sensor on your swap list. I used the V-6 sensor on my 93 swap and except for the vehicle being hard to start when hot, I haven't noticed any problems that may be related to using the V-6 sensor. Was there a reason to use the V-8 knocker and if so why? I know when I did my original swap in the late nineties and made the decision to go with the factory TBI, there was no one on the internet that had tried it at that time, so, I was on my own. Now, I'm trying to work out the various running problems I had back then now that I'm trying to get the old van going again and trying using it for long trips like I used to do before the V-6 died a premature death. Thanks.
Dino
________________________
1993 Astro Tiara Conversion with 350 (One of the first EFI swaps on the Net)
2001 Dakota R/T (Slammed and tuned)
1976 Lotus Eclat (soon to be custom fuel injected)
Locost Lotus 7 (scratch built - completion next year)
lotuseclat767
Years of Membership: lotuseclat767 has been a member for 8 full yearslotuseclat767 has been a member for 8 full yearslotuseclat767 has been a member for 8 full yearslotuseclat767 has been a member for 8 full yearslotuseclat767 has been a member for 8 full yearslotuseclat767 has been a member for 8 full yearslotuseclat767 has been a member for 8 full yearslotuseclat767 has been a member for 8 full years
Alias (AKA): Dino
Extra Info: Tiara conversion
Re: V8 SWAP LIST
Postby Matrixx » March 20th 2009, 10:36pm
Hi lotuseclat767
From what I gather, chops has been very ill lately, he hasn't been around much at all. Just to let you know. :)
Matrixx
Years of Membership: Matrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full years
Re: V8 SWAP LIST
Postby astrovan98 » April 1st 2009, 3:20pm
I usually use the internet auto parts suppliers websites to research compatable parts. This allows me to cross referrance parts that may be the same from engine to engine. I also speak with my parts guy at my G.M parts counter and ask him to see if a certain part for my donor engine is the same as my Astro engine, just to confirm. If you provide your G.M. guy with the last 8 digits of the VIN for the truck the engine came out of, he will get the exact part number for your engine component, then he can cross very accurately to your van.
astrovan98
Years of Membership: astrovan98 has been a member for 8 full yearsastrovan98 has been a member for 8 full yearsastrovan98 has been a member for 8 full yearsastrovan98 has been a member for 8 full yearsastrovan98 has been a member for 8 full yearsastrovan98 has been a member for 8 full yearsastrovan98 has been a member for 8 full yearsastrovan98 has been a member for 8 full years
Re: V8 SWAP LIST
Postby lawbuck » May 27th 2009, 6:44am
i have an 01 astro what do i need to put a v8 in mine?. on my 2nd 4.3 and not pleased. pressed for time borrowed my fathers chevy venture and hate that thing.
01 astro awd
lawbuck
Years of Membership: lawbuck has been a member for 8 full yearslawbuck has been a member for 8 full yearslawbuck has been a member for 8 full yearslawbuck has been a member for 8 full yearslawbuck has been a member for 8 full yearslawbuck has been a member for 8 full yearslawbuck has been a member for 8 full yearslawbuck has been a member for 8 full years
Topics: 7
Alias (AKA): larry
Re: V8 SWAP LIST
Postby Bertscova » August 17th 2009, 10:31pm
One thing Chops left out of his list were the bandaids and lots of them :screaming:
Horsies sell cars Torque wins races
1990 2wd Astro Van
1990 5.7 TBI w/roller cam upgrade
1.6 roller tip rockers
700R4
Stock Distributor w/ Upgraded electronics
Bertscova
Years of Membership: Bertscova has been a member for 8 full yearsBertscova has been a member for 8 full yearsBertscova has been a member for 8 full yearsBertscova has been a member for 8 full yearsBertscova has been a member for 8 full yearsBertscova has been a member for 8 full yearsBertscova has been a member for 8 full yearsBertscova has been a member for 8 full years
Topics: 54
Alias (AKA): Bert
Extra Info: TBI 5.7 Roller
Re: V8 SWAP LIST
Postby chevy57bert » May 21st 2010, 9:59pm
Motor Mounts V8 Swap
chevy57bert
Section Moderator
Section Moderator
Firing on 7 Cylinders (L3)
Topics: 67
Images: 33
Alias (AKA): Bertjuh
Year: 1992
Extra Info: Ext 4.3L rwd
Re: V8 SWAP LIST
Postby Gary » May 22nd 2010, 5:26am
Dennis-(Chops) has been very sick with with his fight with cancer and diabetics.He has lost his eye sight permanently and will not be posting anywhere.His fight with cancer is in recovery.
I want this thread to be a standing honor to one of the best.
Please pray for one of my friends and a fellow Astro brother.
Gary
Firing on 4 Cylinders (L3)
Years of Membership: Gary has been a member for 8 full yearsGary has been a member for 8 full yearsGary has been a member for 8 full yearsGary has been a member for 8 full yearsGary has been a member for 8 full yearsGary has been a member for 8 full yearsGary has been a member for 8 full yearsGary has been a member for 8 full years
Topics: 136
Extra Info: high top
Re: V8 SWAP LIST
Postby Jasen » May 22nd 2010, 3:50pm
My best thoughts go out Dennis
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Year: 1997
Re: V8 SWAP LIST
Postby kooljoekool1 » August 14th 2010, 9:14pm
Got a 99 safari myself , also thinking of doing the swap . Was talking to someone about it and was told that the 350 bolts up to the tranny from the safari , all i needed to get was the 350 engine and computer , will that work also ?????.....the kool one.. 8-)
kooljoekool1
Years of Membership: kooljoekool1 has been a member for 6 full yearskooljoekool1 has been a member for 6 full yearskooljoekool1 has been a member for 6 full yearskooljoekool1 has been a member for 6 full yearskooljoekool1 has been a member for 6 full yearskooljoekool1 has been a member for 6 full years
Extra Info: 4.3l v6 RWD
Re: V8 SWAP LIST
Postby InWI » September 2nd 2010, 4:41am
God Bless Dennis.
InWI
Years of Membership: InWI has been a member for 7 full yearsInWI has been a member for 7 full yearsInWI has been a member for 7 full yearsInWI has been a member for 7 full yearsInWI has been a member for 7 full yearsInWI has been a member for 7 full yearsInWI has been a member for 7 full years
Extra Info: SLT AWD
Re: V8 SWAP LIST
Postby phoneman » September 3rd 2010, 6:27pm
Safari / Jeep. Sounds right, huh? So why do I seem to be the only guy swapping an AMC 304 into my Safari? 1970 360 heads, small chamber, 2.02 valve, dog leg exhaust port. Crower cam. Exhaust manifolds will work, oil filter works, mounts will be easy. And, distributer in front - don't remove the doghouse for tuning!
The DN five speed behind the 304 will require only a minor crossmember mod, and the Safari driveshaft length will work.
I'm the only guy doing this. I'm strange. But answer this ... Have ya ever heard an AMC V8 spark knock? Nope - not even on 87 gas.
Phoneman.
phoneman
Years of Membership: phoneman has been a member for 6 full yearsphoneman has been a member for 6 full yearsphoneman has been a member for 6 full yearsphoneman has been a member for 6 full yearsphoneman has been a member for 6 full yearsphoneman has been a member for 6 full years
Alias (AKA): phoneman
Extra Info: drivetrainless
Re: V8 SWAP LIST
Postby 4gsafari » July 8th 2011, 1:39pm
Are these 2wd specific? Or are they good for an AWD as well? Year specific? I'm swapping a 5.7 into an originally 2wd swapped to AWD, that my 4.3 died in.
4gsafari
Years of Membership: 4gsafari has been a member for 6 full years4gsafari has been a member for 6 full years4gsafari has been a member for 6 full years4gsafari has been a member for 6 full years4gsafari has been a member for 6 full years4gsafari has been a member for 6 full years
Extra Info: 2WD LT gone AWD
Return to V8 Swap
It is currently February 24th 2017, 4:35am
V8 Swap Forum
Attached by: codydaniels
codydaniels
in V8 Swap
Comments: 77
Time: 1:43am
Rinny
in V8 Swap
Comments: 58
Date: Feb 15 '17
Time: 1:40am
Rinny
in V8 Swap
Comments: 58
Date: Feb 15 '17
Time: 1:32am
codydaniels
in V8 Swap
Date: Feb 12 '17
Time: 2:55am
in V8 Swap
Comments: 102
Date: Feb 11 '17
Time: 9:39am
