LM7 on 2003 astro cargo 2WD
Postby astromstro123 [OP] » December 2nd 2015, 11:25am
wtssuuuuup astrosafarians im new to the site. i just got my astro. its a 2003 astro cargo 2WD. i live in Southern Cali just recently talked with a carb referee.i told em i wanted to get an LM7 from a 2005 2007 silverado to pit in my astro and he said it was legal so im super excited. the thing is ive never done anything close to an engine change. so where the hell do i start so that i can do this right the first time? the ref i spoke with said my astro pretty much has to be a silverado when i open the hood.
astromstro123
Years of Membership: astromstro123 has been a member for 1 full year
Year: 2003
Extra Info: 2WD Cargo 4.3l V6
  • 5.3 ls engine in Astro... some questions if anyone knows...
    by zach914v8zach914v8 is online! » January 29th 2017, 12:27am in V8 Swap
    Last post by zach914v8zach914v8 is online! View the latest post
    January 31st 2017, 6:29pm
  • 97 Astro 5.7 Vortec V8 Swap
    by akforcetenakforceten is online! » February 13th 2017, 11:57pm in V8 Swap
    Last post by akforcetenakforceten is online! View the latest post
    February 15th 2017, 5:52pm
    57
    March 28th 2017, 8:32pm
Re: LM7 on 2003 astro cargo 2WD
Postby Sailing_Faith » December 3rd 2015, 5:38pm
Does an LM7 do the shut down every other cyl thing?
It would be amazing to get 30mpg on the hwy!
Sailing_Faith
Firing on 8 Cylinders (L1)
Years of Membership: Sailing_Faith has been a member for 4 full yearsSailing_Faith has been a member for 4 full yearsSailing_Faith has been a member for 4 full yearsSailing_Faith has been a member for 4 full years
Topics: 32
Alias (AKA): s/v Faith
Year: 1997
Postby DRZ » December 3rd 2015, 7:07pm
I thought the LM7 or even better the L33 Silverado motors would be an easy swap for our 2WD Astros until one of our members had to modify the dog house to clear the truck style "intake". The Silverado DOES have the correct oil pan for a 2WD swap, the truck wire harness has the computer on the left same as our Astros to save the 180 wire splices it took to get the LS1 from a Trans-Am to hook up in my '98 Astro. You will have to clearance the frame slightly to clear the A/C compressor. I would recommend getting the engine with the correct transmission also rather than mix and matching any more than you have to. On my '98 I had to remount the coil pacs above the intake as there wasn't room in the stock location due to the tight fit at the dog house opening in the van floor. I made the engine motor mounts myself and the stock V6 frame motor mount location is fine.
Click on one of the pictures and it will take you to some of the photobucket pics that Mike saved from my album. Clicking on the arrows lets you see the rest. This shows the LS1 intake which clears everything.
Get your engine as a "Dropout" which includes everything to make it operate in any vehicle and don't be fooled with low prices on just an engine. The cost of swapping that way ends up costing more and makes the job way harder.
DRZ
Firing on 5 Cylinders (L2)
Years of Membership: DRZ has been a member for 9 full yearsDRZ has been a member for 9 full yearsDRZ has been a member for 9 full yearsDRZ has been a member for 9 full yearsDRZ has been a member for 9 full yearsDRZ has been a member for 9 full yearsDRZ has been a member for 9 full yearsDRZ has been a member for 9 full yearsDRZ has been a member for 9 full years
Topics: 45
Images: 55
Alias (AKA): HPbyStan
Year: 2004
Extra Info: awd cargo Alloys
Postby DRZ » December 3rd 2015, 7:28pm
Sailing_Faith wrote:Does an LM7 do the shut down every other cyl thing?
I think the LM7 that does the shutdown thing is renamed the L59. Wouldn't bet the ranch on that tho.
The LM7 comes two ways, with a cable throttle body or the drive by wire deal. I only have used the cable style myself so have no advice on the electronic system.
DRZ
Topics: 45
Images: 55
Year: 2004
Postby DRZ » December 3rd 2015, 7:47pm
DRZ
Topics: 45
Images: 55
Year: 2004
Postby astromstro123 [OP] » January 6th 2017, 7:38am
can i get a 5.3 from one of the newer trucks?? also can i get the ecm seperately and is it a good or bad idea??
astromstro123
Year: 2003
Postby chevymaherchevymaher is online! » January 6th 2017, 1:19pm
astromstro123 wrote:can i get a 5.3 from one of the newer trucks?? also can i get the ecm seperately and is it a good or bad idea??
I would get the ecm with the motor. It is there and you need the wiring and ecm.
Topics: 82
Year: 1994
Postby WoodButcher » January 6th 2017, 3:47pm
You want the motor, trans and all the related harness and computers for that motor, "turnkey" is what they call it I believe. Unless your a top dog mechanic and understand all the systems and can build each part of that given motor from scratch it is the only way to go.
As it is you'll have modifications to make as DRZ pointed out so why add more complications if you don't need to?
I went the easy road with my '93, same year and type of intake / ignition just 2 extra cylinders.
WoodButcher
Firing on 6 Cylinders (L5)
Topics: 28
Images: 450
Alias (AKA): Bruce
Year: 1997
Extra Info: 4.3 RWD
Postby AstroWill » January 6th 2017, 4:54pm
astromstro123 wrote:the thing is ive never done anything close to an engine change. so where the hell do i start so that i can do this right the first time? the ref i spoke with said my astro pretty much has to be a silverado when i open the hood.
Well, as a first time swap, I would highly recommend getting the same year van engine, it's so much easier.
If you are willing, anything can be made to fit, but there are a lot of vehicles that get sold as 'project' vehicles, just because they got in too deep and never finished.
Topics: 61
Images: 87
Extra Info: 90TigerGTv8 03AWD
Postby DRZ » January 6th 2017, 10:17pm
It seems the stock LM7 inlet manifold won't clear the "dog house" so I bought a LS1 manifold from eBay because I know that one clears with no problems. It looks like I will have to use the LS1 water pump or modify the upper hose outlet to clear the now lowered Throttle body.
DRZ
Topics: 45
Images: 55
Year: 2004
Postby astromstro123 [OP] » January 7th 2017, 8:09am
is there such a thing as a rebuild manual for the 5.3l lm7 that has visual aids on what parts belong on the engine and where they go, all the wiring circuits?? can i get one at a dealer?? whats a good guide to rebuilding one of these engines?? or is it require me many years of experience to rebuild one of these?? tearing one down isnt a problem but i really want to be able to put one back together the right way. and i dont wana just take it to someone ao they can have all the fun.
thanks
astromstro123
Year: 2003
Postby Master slacker » January 7th 2017, 2:28pm
No Astro. No Safari. Just dreams.
Master slacker
Years of Membership: Master slacker has been a member for 1 full year
Return to V8 Swap
It is currently March 28th 2017, 8:32pm
V8 Swap Forum
Rinny
in V8 Swap
Comments: 112
Time: 1:22pm
Rinny
in V8 Swap
Comments: 112
Time: 1:09pm
jonamond
in V8 Swap
Comments: 24
Date: Mar 25 '17
Time: 3:35am
Rinny
in V8 Swap
Comments: 112
Date: Mar 19 '17
Time: 12:19am
Rinny
in V8 Swap
Comments: 112
Date: Mar 17 '17
Time: 1:17am
