Oil filter adapter leaking, not oil cooler lines
Postby mike_wiz [OP] » November 7th 2016, 7:56pm
Hi All, I have a 96 Safari AWD 4.3. I have been working on these vans for awhile, I own three for my business. But I have a new problem and have searched for an hour on this forum and can't find an answer. Oddly enough this has never happened to me in 18 years of owning these vans.
I am leaking massive oil while the engine is running from the top of the unit that the oil filter screws into, the same unit the oil cooler lines run into the side of. Best I have seen is this is called the oil filter adapter?
It is leaking from where this piece mates to the engine block.
How does this part come out? Is it just a seal that I can replace? Thanks for all the help in advance, this is only the 2nd time I have posted a problem as I have always found my answers by searching, but this one is baffling me!
Mike
mike_wiz
Years of Membership: mike_wiz has been a member for 6 full yearsmike_wiz has been a member for 6 full yearsmike_wiz has been a member for 6 full yearsmike_wiz has been a member for 6 full yearsmike_wiz has been a member for 6 full yearsmike_wiz has been a member for 6 full years
  • Oil Filters, why not use any filter that fits?
    by N6KB » December 11th 2016, 1:37am in Engines
    Last post by Zebediah III View the latest post
    December 11th 2016, 4:40am
  • Oil Cooling lines Need TIPS
    by BBruce » December 1st 2016, 6:16pm in Engines
    Last post by dkGarnet96 View the latest post
    December 2nd 2016, 5:38pm
    14
    March 25th 2017, 5:03am
Re: Oil filter adapter leaking, not oil cooler lines
Postby AstroWill » November 7th 2016, 8:07pm
When you remove the adapter, you will see there is a gasket between the adapter and the block, this will have to be replaced.
Or you can remove the adapter and lines completely and screw the filter directly to the block using the threaded portion from the adapter.
Topics: 60
Images: 87
Alias (AKA): Richard C., Advocatus Diaboli
Year: 2003
Extra Info: 90TigerGTv8 03AWD
Postby Leeann_93 » November 9th 2016, 11:06pm
Two torx bolts remove it.
'00 Astro LS AWD vin W - WIP
Image Image
Topics: 27
Year: 2002
Extra Info: LS 4.3L AWD
It is currently March 25th 2017, 5:03am
cybrvanr
Date: Mar 21 '17
Time: 4:55pm
Comments: 23
Date: Mar 17 '17
Time: 1:28pm
Comments: 23
Date: Mar 16 '17
Time: 4:38pm
dweseen
Date: Mar 16 '17
Time: 2:08am
Jawon
Date: Mar 09 '17
Time: 8:43pm
Users browsing this forum: Google Adsense [Bot] and 4 guests
