Low oil pressure
Low oil pressure
Postby dantheman [OP] » November 27th 2016, 11:43pm
Just replaced the power steering pump after noticing a small leak. Got the new one installed and pulley back on (NOT fun) and buttoned her up. Now at idle the oil pressure seems low. I'm accustomed to it idling at 40 psi, but now she's only reading 20 (when parked and at red lights) and fluctuating just a little. At normal driving speed, it reads a steady 40 psi. Any ideas as to what may be causing this?
dantheman
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: dantheman has been a member for 1 full year
Topics: 18
Alias (AKA): Dan
Year: 1999
Extra Info: 4.3L RWD
Re: Low oil pressure
Postby chevymaher » November 28th 2016, 12:05am
It is well within the specs for the motor. 8 lbs at idle is good according to GM bulletins.
I had extreme oil pressure issues on my original motor. Red zone at idle when hot. I replaced the oil pressure bypass spring in the oil pump with one from a 302 Z-28 camaro. Solved it for me.
They sell various ones for a small block. They are the same thing and fit. It just gives me that fuzzy feeling seeing the oil pressure gauge pegged all the time. So I go with the performance one.
Topics: 81
Year: 1994
Postby dantheman [OP] » November 28th 2016, 12:09am
Gotcha. Didn't know if it might've been something I did. Strange.
dantheman
Fueling (5/8 tank)
Fueling (5/8 tank)
Topics: 18
Alias (AKA): Dan
Year: 1999
Postby chevymaher » November 28th 2016, 12:13am
Probably did it all along. You just noticed since you were working on it.
Oil pressure is high when cold then when the engine is warm the oil gets hot and thinner. So at idle it goes down that is normal.
Topics: 81
Year: 1994
Postby dantheman [OP] » November 28th 2016, 12:22am
You're probably exactly right! Cool, as long as I'm ok at that psi I'm happy. I've put a ton of work into it and She runs like a top!
dantheman
Fueling (5/8 tank)
Fueling (5/8 tank)
Topics: 18
Alias (AKA): Dan
Year: 1999
It is currently February 23rd 2017, 9:40pm
AstroNuts
Comments: 59
Date: Today
Time: 5:19am
sixsixsixsix is online!
Comments: 22
Time: 4:37am
Attached by: 97cargocrawler
97cargocrawler
Comments: 59
Date: Feb 21 '17
Time: 6:29pm
Attached by: Coaster
CoasterCoaster is online!
Comments: 107
Date: Feb 20 '17
Time: 5:25pm
Comments: 107
Date: Feb 20 '17
Time: 1:44am
Users browsing this forum: Google Adsense [Bot] and 6 guests
