How to remove the Fan blade on a 97 Chevy?
Postby mr singh [OP] » February 28th 2011, 11:15pm
Guys i'm going to be working on putting my third alternator in soon, but the fan blade gets in my way..
How do I remove it? :confused:
Thanks!
Am
1997 2WD Chevy Astro ::160dB BEAST::
mr singh
Years of Membership: mr singh has been a member for 9 full yearsmr singh has been a member for 9 full yearsmr singh has been a member for 9 full yearsmr singh has been a member for 9 full yearsmr singh has been a member for 9 full yearsmr singh has been a member for 9 full yearsmr singh has been a member for 9 full yearsmr singh has been a member for 9 full yearsmr singh has been a member for 9 full years
Topics: 13
  • How to remove backing from steering pump?
    by Echo » December 31st 2016, 11:53pm in Engines
    Last post by Corsemoto View the latest post
    January 10th 2017, 11:08pm
  • Roaring rad fan?
    by Echo » December 4th 2016, 4:07am in Engines
    Last post by Echo View the latest post
    December 4th 2016, 5:55pm
    7
    13
    February 23rd 2017, 9:45pm
Re: How to remove the Fan blade on a 97 Chevy?
Postby chevymaher » February 28th 2011, 11:20pm
Disconnect the negative battery cable for safety.
Loosen the clamp, then remove the air cleaner assembly.
Remove the upper fan shroud retaining bolts, then remove the upper shroud from the vehicle.
Remove the fan and clutch assembly retainers using J-41240, or an equivalent fan clutch wrench.
If necessary, remove the 4 bolts holding the fan blade to the clutch, then separate the fan from the clutch assembly.
Exploded view of the fan and clutch assembly
engine fan.JPG (15.74 KiB) Viewed 5931 times
To install:
Installation is the reverse of the removal procedure. Tighten the components to the following specifications:
If removed, tighten the fan-to-clutch bolts to 24 ft. lbs. (33 Nm).
Install the fan blade and clutch assembly to the engine using J-41240 and tighten the retainers to 41 ft. lbs. (56 Nm).
Connect the negative battery cable. Start the engine and check operation.
Topics: 81
Year: 1994
Postby mr singh [OP] » February 28th 2011, 11:50pm
So its just held on via a stud/bolt.. and a pair of big *** spanners is all it really needs?
mr singh
Topics: 13
Postby GaryZ » March 1st 2011, 1:40am
mr singh wrote:So its just held on via a stud/bolt.. and a pair of big *** spanners is all it really needs?
My '98 has the same big-ass nut on the back of the fan. It threads on the snout of the water pump.
I use a very scientific method for removing this beast;
Clamp very large adjustable wrench (mine is 18") onto the nut with the wrench standing at 12 o'clock.
Plant both feet firmly and hit the wrench sharply with a big hammer from right-to-left.
The nut should come loose and twist the rest of the way off by hand.
:rolling:
'98 Astro AWD, white with gray interior,
3.42:1 diffs, 235/70 x 15 tires,
195,000 miles on original engine and trans
'99 Kawasaki ZX11D
'85 Yamaha Venture Royale with 1300 engine & Vmax cams
GaryZ
Years of Membership: GaryZ has been a member for 8 full yearsGaryZ has been a member for 8 full yearsGaryZ has been a member for 8 full yearsGaryZ has been a member for 8 full yearsGaryZ has been a member for 8 full yearsGaryZ has been a member for 8 full yearsGaryZ has been a member for 8 full yearsGaryZ has been a member for 8 full years
Postby redfury » March 1st 2011, 2:44am
It's a 32mm wrench if you want to spend the 40 bucks on one like I did. Then, you'll need a 20 dollar strap wrench to hold the pulley so it won't move on you. Lowes has a really nice one ( it's red ) for like 15 bucks. I just replaced mine as it was broken.
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Year: 1998
Extra Info: LT 5.7L 4wd
Postby cowboydan » March 1st 2011, 2:55am
in the steering forum i poset a sticky: 97 astro steering pump on the ground in less than an hr/less. check out the pics for the fastest/ easiest way. hope it helps
2006 sebring 2.7 touring: DD
cowboydan
Firing on 8 Cylinders (L2)
Years of Membership: cowboydan has been a member for 6 full yearscowboydan has been a member for 6 full yearscowboydan has been a member for 6 full yearscowboydan has been a member for 6 full yearscowboydan has been a member for 6 full yearscowboydan has been a member for 6 full years
Topics: 67
Alias (AKA): cbd
Year: 1997
Extra Info: 4.3w CL AWD
Postby Mr_Bowtie » March 1st 2011, 2:55am
Autozone rents the fan wrenches if you need one. After you take it off once its easier to remove the next time.
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Year: 1985
Extra Info: 350 with 700r4
Postby mr singh [OP] » March 2nd 2011, 11:51pm
Thanks fellas! I'm in the UK so somewhere limited to some of your array of auto mobilier tools stores :(
mr singh
Topics: 13
Postby Mr_Bowtie » March 3rd 2011, 1:33am
Oh that sucks. Just get a big cresent wrench at the store that will work. I have one in my garage I bought for like $10 that fit on there. Then a big hammer like someone mentioned! :banana:
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Year: 1985
Postby mr singh [OP] » March 17th 2011, 6:30pm
Sorry to up this again.
I got a 32mm adjustable spanner.. but how the hell do I stop the fan from spinning, tried wedging something in to stop it spinning and tried a little spanner on the bolts around the pulley and that didn't work.
Any ideas?
Thanks!!
mr singh
Topics: 13
Postby GaryZ » March 17th 2011, 7:02pm
mr singh wrote:Sorry to up this again.
Any ideas?
Thanks!!
You are beginning to understand the need of a "big hammer".
The fan belt needs to be installed.
Place the spanner on the nut with the handle at 12 o'clock.
Smack the handle with a "big hammer" to loosen.
'99 Kawasaki ZX11D
GaryZ
Postby ihatemybike » March 17th 2011, 7:05pm
I use the box end of a bigger combo wrench. Put the box end over one of the four pulley bolts, rotate clockwise till the handle come in contact with the center shaft/32mm nut, then use the 32mm wrench and work the two wrenches opposite each other.
Aaron
Prev Astros:99,97,00,94,87,86
ihatemybike
Firing on 6 Cylinders (L2)
Years of Membership: ihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full years
Topics: 67
Postby Gus_Mahn » March 18th 2011, 3:48am
Some shop guys use an air chisel with a dull bit. You hit it just off the edge of the flat on the loosen side of the nut. The nut will break loose and can be turned by hand or with a pair of channel locks. It can be tightened with the opposite method. Sorry I don't recall which direction is loosen. On my own Safari during a water pump replacement, I just pulled the plate off the back and jammed a screw driver between the housing and impeller.
Gus_Mahn
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: Gus_Mahn has been a member for 8 full yearsGus_Mahn has been a member for 8 full yearsGus_Mahn has been a member for 8 full yearsGus_Mahn has been a member for 8 full yearsGus_Mahn has been a member for 8 full yearsGus_Mahn has been a member for 8 full yearsGus_Mahn has been a member for 8 full yearsGus_Mahn has been a member for 8 full years
Topics: 10
Postby redfury » March 18th 2011, 4:50am
You can't go wrong with this. You have to remove the belt anyway. Cost me $14 at Lowes, works like a charm...stay away from the cheap ones from Harbor freight, they just use a thick rubber band....this uses a reinforced rubber belt so it won't stretch.
redfury
Topics: 53
Images: 13
Year: 1998
Postby mr singh [OP] » March 18th 2011, 6:56pm
OK folks, going to try out some of these ideas tomorrow or Monday.. will update you all :)
mr singh
Topics: 13
Postby Leeann_93 » March 19th 2011, 12:11am
^^ I used the same method on the '93 ;)
'00 Astro LS AWD vin W - WIP
Image Image
Topics: 27
Year: 2002
Extra Info: LS 4.3L AWD
Postby redfury » March 19th 2011, 3:11am
BTW, a 32mm wrench can be had for as little as $10. I overspent by going to NAPA for mine instead of Northern Tool and Hydraulic. The quality of that wrench didn't have to be a $40 ticket.
redfury
Topics: 53
Images: 13
Year: 1998
Postby webcat » March 19th 2011, 3:55am
nice pictures!
Here's the fan part.
webcat
Firing on 3 Cylinders (L3)
Topics: 253
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
Postby mr singh [OP] » April 30th 2011, 11:49pm
Been busy as hell.. getting back to work on this beast.
Used air chisel and few hits with a 18" adjustable wrench and came off :)
mr singh
Topics: 13
Postby redfury » May 1st 2011, 1:54am
redfury wrote:BTW, a 32mm wrench can be had for as little as $10. I overspent by going to NAPA for mine instead of Northern Tool and Hydraulic. The quality of that wrench didn't have to be a $40 ticket.
Actually, my mistake, it' s a 36mm wrench for those that care.
redfury
Topics: 53
Images: 13
Year: 1998
It is currently February 23rd 2017, 9:45pm
AstroNuts
Comments: 59
Date: Today
Time: 5:19am
sixsixsixsix is online!
Comments: 22
Time: 4:37am
Attached by: 97cargocrawler
97cargocrawler
Comments: 59
Date: Feb 21 '17
Time: 6:29pm
Attached by: Coaster
CoasterCoaster is online!
Comments: 107
Date: Feb 20 '17
Time: 5:25pm
Comments: 107
Date: Feb 20 '17
Time: 1:44am
