Low idle 550 rpm
Low idle 550 rpm
Postby ezbeinsteezy [OP] » January 10th 2017, 5:36pm
I have a low idle that just doesn't seem to go away I've done everything I could think of changing the air filter, fuel filter, iac, iat, cleaning the egr valve checking vacum lines it's drive me nuts what else could it be it doesn't die thankfully I don't have a maf sensor since it's a 95 what thinking is the injectors, intake manifold gasket or timing chain any input would be great :ty:
ezbeinsteezy
Year: 1995
  • Low oil pressure
    by dantheman » November 27th 2016, 11:43pm in Engines
    Last post by dantheman View the latest post
    November 28th 2016, 12:22am
  • Misfire at idle
    by MauiSafari » January 3rd 2017, 3:35am in Engines
    Last post by MauiSafari View the latest post
    February 15th 2017, 7:15am
    February 23rd 2017, 9:42pm
Re: Low idle 550 rpm
Postby 97cargocrawler » January 10th 2017, 10:03pm
What are you using to determine the rpm? A scan tool or some aftermarket pod gauge? I think stock rpm is in that range. I boosted mine up a bit (around 615) to keep the engine happy with my huge alternator, 4 electric fans and constant use of the a/c. I used a programmer to do that.
97cargocrawler
Firing on 8 Cylinders (L4)
Years of Membership: 97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years
Topics: 42
Alias (AKA): CC, CARGO, CRAWLER, ASSHOLE
Year: 1997
Postby ezbeinsteezy [OP] » January 10th 2017, 10:42pm
I bought a tach and it seems fairly accurate the reason why I think it's low is because it has a rattle like in the steering wheel it's nothing to do with the drive train and it's very minor but most people that ive talk to said that it's a little low. Is your idle really smooth at 600?
ezbeinsteezy
Year: 1995
Postby sfeaver » January 11th 2017, 4:17am
I looked at a tune from a 98, which is the earliest I have, and its lowest idle is 600 in neutral ac on or off, 650 in drive. 95 is probably similar. a V8 has 550 as its idle in gear. Engine warmed up.
If your seeing 550 on your scan tool, will it show you what the desired idle speed is? That will tell you right there if you are looking for a problem that isnt there!
sfeaver
Firing on 7 Cylinders (L1)
Years of Membership: sfeaver has been a member for 7 full yearssfeaver has been a member for 7 full yearssfeaver has been a member for 7 full yearssfeaver has been a member for 7 full yearssfeaver has been a member for 7 full yearssfeaver has been a member for 7 full yearssfeaver has been a member for 7 full years
Topics: 24
Year: 1997
Extra Info: LT RWD 350ci V8
Postby chevymaher » January 11th 2017, 3:13pm
This has been talked about before. It just depends on what they did when they built the van,. One guy got a new PCM and it was 650 rpm. And he had 550 originally. Mine has the goofy 550 deal in it.
They do like the higher idle better tho. I manually turned the idle screw up on mine without changing the computer. It idles at 700 in neutral. And 550 in gear and with the air on. But even that made a big difference in the way it acted. The extra air all the time. I mainly did it like cargo for the A/C to actually be working while it is sitting idling in parking lots in the summer. Heater works better to because it ia pumping hot water better in the winter idling.
Topics: 81
Year: 1994
Postby CoasterCoaster is online! » January 14th 2017, 3:36am
i have 2 different prom for my 95, both from 95 astro/safari.
the astro prom idles at 500 and 550 in gear/neutral and the safari prom idles at 600 and 650 in gear/neutral. astro prom shifts late, lockup at 48 mph. safari shifts early, lockup at 41 mph.
astro prom shifts way better. safari prom idles way better.
Firing on 8 Cylinders (L1)
Years of Membership: Coaster has been a member for 4 full yearsCoaster has been a member for 4 full yearsCoaster has been a member for 4 full yearsCoaster has been a member for 4 full years
Topics: 100
Year: 1995
Extra Info: 4.3 cargo 2wd
Postby sfeaver » January 14th 2017, 5:13am
I'm curious what else is different between the two proms.. Have the calibration ids handy? Maybe I can look it up if I still have the info..
sfeaver
Topics: 24
Year: 1997
Postby Mmusicman » January 14th 2017, 2:41pm
ezbeinsteezy wrote:I bought a tach and it seems fairly accurate...
"Seems accurate" based on what?
FYI: gauges (of any sort) are typically "less accurate" at the very bottom of their scales. Your's may be fine...but I'd check your OBD to be certain. Even then, it would need to be decided if the reading is normal anyway.
ezbeinsteezy wrote:..the reason why I think it's low is because it has a rattle like in the steering wheel..
One thing you may have overlooked is that the idle may be fine... but the motor-mounts may be shot. It's a VERY common problem. They are "typically" good for about 150K.
My mounts are blown in in my 2000.. and it makes the idle (in gear) feel rough, shaking steering wheel... neutral smooths out, even though the rpms actually stay the same. New mounts can make your van feel like new again.
Here's the idle on my 92... which is set to about 1000 rpms... :D
On one occasion it dips down to 800 or 900 and almost stalls.. mounts are new.
2000 Chevy Astro LS AWD | 31" LT265/70R17 Tires | 8" LIFT | 10" TOTAL
92 Chevy Astro Shorty | V8-350
Firing on 5 Cylinders (L2)
Years of Membership: Mmusicman has been a member for 3 full yearsMmusicman has been a member for 3 full yearsMmusicman has been a member for 3 full years
Topics: 30
Year: 2000
Extra Info: 2000 AWD 92 V8-350
It is currently February 23rd 2017, 9:42pm
AstroNuts
Comments: 59
Date: Today
Time: 5:19am
sixsixsixsix is online!
Comments: 22
Time: 4:37am
Attached by: 97cargocrawler
97cargocrawler
Comments: 59
Date: Feb 21 '17
Time: 6:29pm
Attached by: Coaster
Comments: 107
Date: Feb 20 '17
Time: 5:25pm
Comments: 107
Date: Feb 20 '17
Time: 1:44am
