dying after startup
dying after startup
Postby doggggboy [OP] » April 5th 2011, 7:45pm
2001 Astro 4.3l runs fine. Sometimes on startup it simply dies unless you give it more gas. Runs smooth but will die if you let up. If you shut it down and try to restart several times eventually it will start and idle fine. Happens both hot and cold engine. No codes showing. Any tips on where to start looking or is it back to the old shotgun approach and start replacing the cheapest thing first?
doggggboy
Years of Membership: doggggboy has been a member for 7 full yearsdoggggboy has been a member for 7 full yearsdoggggboy has been a member for 7 full yearsdoggggboy has been a member for 7 full yearsdoggggboy has been a member for 7 full yearsdoggggboy has been a member for 7 full yearsdoggggboy has been a member for 7 full years
  • Burning (oil?) smell at startup
    by Ingmire » December 28th 2016, 4:53pm in Engines
    Last post by TurnNburn View the latest post
    December 28th 2016, 5:28pm
    33
    June 22nd 2017, 12:57pm
Re: dying after startup
Postby Phantom » April 5th 2011, 7:48pm
Check fuel pressure to make sure the pump is able to provide sufficient fuel pressure , check to make sure the fuel filter is not plugged up , make sure all electrical connections are clean and tight.
Try just turning key on to hear fuel pump and turn off , do it about 3 times to fully prime pump then try to start and see if it runs well ,
Phantom
Firing on 7 Cylinders (L4)
Postby 1297chevastro » April 10th 2011, 1:49am
im having this problem on my '98. Does it smoke blue at idle, and smoke a ton when you rev it?
1991 S-10 Blazer 4x4 210k (project)
1999 Honda Si(Beater bomb)
2005 Safari -182k (RIP2014)
1297chevastro
Section Moderator
Section Moderator
Years of Membership: 1297chevastro has been a member for 6 full years1297chevastro has been a member for 6 full years1297chevastro has been a member for 6 full years1297chevastro has been a member for 6 full years1297chevastro has been a member for 6 full years1297chevastro has been a member for 6 full years
Topics: 33
Year: 2005
Postby paintdrying » April 10th 2011, 2:00am
Your fuel regulator may be leaking fuel into the oil. I would say compression check is in order.
paintdrying
Topics: 94
Extra Info: 108 000
Postby Thunderball » April 10th 2011, 3:46am
Mine does the same thing. When I start it up, it chugs a bit with rough idle sometimes. Once it runs for a few seconds all is fine. I get that rich smell out of the exhaust too. But, last week, i put in a bottle of STP Octane Booster, because it was on sale, to see if it made a difference in mileage. It didn't, but I noticed that my start ups were way better and much smoother. My engine is all tuned up and runs really good and has 175,000 miles on it. So, you may just be dealing with a gas issue. I know mine runs lousy on BP, Shell and any of those Ethanol-mixed gases. I normally run Marathon, Speedway and Sunoco.
If yours is actually dying out and stalling, you may have some tuneup issues, maybe an open vacuum line, or a clogged fuel filter.
_________________________________________________________________________________
2001 Astro LS - 4.3L V-6 - RWD - 260,000 miles
Thunderball
Years of Membership: Thunderball has been a member for 6 full yearsThunderball has been a member for 6 full yearsThunderball has been a member for 6 full yearsThunderball has been a member for 6 full yearsThunderball has been a member for 6 full yearsThunderball has been a member for 6 full years
Images: 5
Year: 2001
Extra Info: LS 4.3L V6 RWD
Postby Woodweasel » April 10th 2011, 3:07pm
I had the same "start and cant idle" issue a few months ago. Ended up the Idle Air Control valve was stuck. Replaced it and idles like new.
Woodweasel
Firing on 7 Cylinders (L1)
Years of Membership: Woodweasel has been a member for 8 full yearsWoodweasel has been a member for 8 full yearsWoodweasel has been a member for 8 full yearsWoodweasel has been a member for 8 full yearsWoodweasel has been a member for 8 full yearsWoodweasel has been a member for 8 full yearsWoodweasel has been a member for 8 full yearsWoodweasel has been a member for 8 full years
Topics: 36
Extra Info: 140K miles
Postby 1297chevastro » April 10th 2011, 5:11pm
Yeah im gonna check Fuel filter today. I will be doing a major tune up (Oil change and Filter, Fuel Filter,New Spark Plugs and wires,Clean egr valve,Fuel line flush) soon when i have the money. Is the idle air control a cheap fix? Also it idles better in neutral.
1297chevastro
Section Moderator
Section Moderator
Topics: 33
Year: 2005
Postby 1297chevastro » April 12th 2011, 12:27am
yes fuel filter. Stopped smoking blue just lightly smoking grey it's always done that. It runs crap at idle i park and all gear ranges except neutral. I can slowly bring rpms up while still running smooth but if i punch it stumbles and spits and runs very rough.
1297chevastro
Section Moderator
Section Moderator
Topics: 33
Year: 2005
Postby Woodweasel » April 12th 2011, 3:25pm
1297chevastro wrote:Yeah im gonna check Fuel filter today. I will be doing a major tune up (Oil change and Filter, Fuel Filter,New Spark Plugs and wires,Clean egr valve,Fuel line flush) soon when i have the money. Is the idle air control a cheap fix? Also it idles better in neutral.
Check your idle air control valve on the throttle body. An AC Delco IAC is around $100 at Rockauto. I dont recommend an aftermarket one ($35.00), it went out on me within 6 months. OR.... check your trans mount. When its in gear, there is a load on the trans mount, in neutral, no load. That might explain idling better in neutral.
Woodweasel
Topics: 36
Postby Leeann_93Leeann_93 is online! » April 12th 2011, 9:51pm
Before you replace the IAC, clean it and the bore in which it rides.
Much cheaper than replacing it...
'00 Astro LS AWD vin W - WIP
Image Image
Topics: 27
Year: 2002
Extra Info: LS 4.3L AWD
Postby redfury » April 13th 2011, 1:10am
Here's the way to check your IAC. If it doesn't start up, turn the key off, then turn the key on and wait 10 seconds. The IAC will reset itself and it should start up and idle fine. If it doesn't after trying that 2x, then you might have a different problem. The IAC controls idle. My van has this exact problem. I can't control the IAC with a bidirectional scanner either, so that right there tells me I have a bad IAC, or a bad signal to it. The dumb thing about mine is, I did a fuel pressure check on the van and immediately after pulling the gauge off, I started having the start up and idle issues...which I thought was extremely odd.
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Year: 1998
Extra Info: LT 5.7L 4wd
It is currently June 22nd 2017, 12:57pm
Rookie162
Date: Jun 13 '17
Time: 11:28pm
astrometalvan
Date: Jun 10 '17
Time: 5:10pm
Attached by: xit
xit
Date: Jun 07 '17
Time: 3:17pm
Attached by: Astro Pop
Astro Pop
Date: Jun 06 '17
Time: 6:17am
astrometalvan
Date: Jun 06 '17
Time: 1:14am
