2002 running rough at idle
Postby scott936 [OP] » April 12th 2011, 3:17am
OK, new plugs, wires, cap rotor, throwing no codes. Van runs rough at idle with foot on brake and in gear,I have checked for vac leaks none found. Any Ideas????
2002 Astro Van Cargo
Air Bags
Yokohama 225/60 17
Overhead console from 92 S 10
Custom Rear Bumper
Custom front seats
scott936
Years of Membership: scott936 has been a member for 6 full yearsscott936 has been a member for 6 full yearsscott936 has been a member for 6 full yearsscott936 has been a member for 6 full yearsscott936 has been a member for 6 full yearsscott936 has been a member for 6 full years
Topics: 37
Images: 20
Year: 2002
Extra Info: 2 WD Cargo
  • rough idle
    by edlps » February 28th 2017, 6:01am in Engines
    Last post by Astro Pop View the latest post
    February 28th 2017, 8:30am
  • Rough idle, blown head or intake gasket?
    by cathairez » October 19th 2016, 6:35pm in Engines
    Last post by Wimpazz View the latest post
    October 31st 2016, 1:47am
    9
    14
    March 26th 2017, 3:54pm
Re: 2002 running rough at idle
Postby throrope » April 12th 2011, 4:04am
I had that bad for years until recently. It would throw a knock code until warmed. EGR valve was gone. Now better, but I'm thinking I still have another itch. Manual sez a temp sensor out of range can cause that too. After five bucks on line, it's sitting next to the keyboard.
throrope
Years of Membership: throrope has been a member for 6 full yearsthrorope has been a member for 6 full yearsthrorope has been a member for 6 full yearsthrorope has been a member for 6 full yearsthrorope has been a member for 6 full yearsthrorope has been a member for 6 full years
Extra Info: LT 4.3L AWD
Postby scott936 [OP] » April 12th 2011, 10:50am
There are so many things it could be, O2, maf, egr - just a guessing game till it throwes a code
Air Bags
Yokohama 225/60 17
Custom Rear Bumper
Custom front seats
scott936
Topics: 37
Images: 20
Year: 2002
Postby chevymaherchevymaher is online! » April 12th 2011, 11:53am
Its just a personal opinion but I think the factory 500-600 idle is to low.The better mine runs the lower it seems to idle.with a slight vacuum leak it idled smoother.life would have been so much simpler if they had not sealed the idle screw.I am not asking much 750 rpm just a little faster than the starter spins it LOL 500 rpm any cough at all and what 400 rpm that enough to make any thing idle rough i can hear the motor now in its little sarcastic voice.Hey chief how about I spin backwards for ya would that be slow enough.
Topics: 82
Year: 1994
Postby scott936 [OP] » April 12th 2011, 12:28pm
chevymaher wrote:Its just a personal opinion but I think the factory 500-600 idle is to low.The better mine runs the lower it seems to idle.with a slight vacuum leak it idled smoother.life would have been so much simpler if they had not sealed the idle screw.I am not asking much 750 rpm just a little faster than the starter spins it LOL 500 rpm any cough at all and what 400 rpm that enough to make any thing idle rough i can hear the motor now in its little sarcastic voice.Hey chief how about I spin backwards for ya would that be slow enough.
I need to put attach on it to see what the rpms are at when idleing..... maybe its running back wards :rofl:
Air Bags
Yokohama 225/60 17
Custom Rear Bumper
Custom front seats
scott936
Topics: 37
Images: 20
Year: 2002
Postby scott936 [OP] » April 12th 2011, 12:32pm
today I will replace the fuel filter to eliminate that possible cause.... then go from there
Air Bags
Yokohama 225/60 17
Custom Rear Bumper
Custom front seats
scott936
Topics: 37
Images: 20
Year: 2002
Postby Woodweasel » April 12th 2011, 3:17pm
Try your Idle air control valve.
Woodweasel
Firing on 7 Cylinders (L1)
Years of Membership: Woodweasel has been a member for 7 full yearsWoodweasel has been a member for 7 full yearsWoodweasel has been a member for 7 full yearsWoodweasel has been a member for 7 full yearsWoodweasel has been a member for 7 full yearsWoodweasel has been a member for 7 full yearsWoodweasel has been a member for 7 full years
Topics: 36
Extra Info: 140K miles
Postby scott936 [OP] » April 13th 2011, 12:06am
Woodweasel wrote:Try your Idle air control valve.
Would the IAC cause the problem to worsen when AC is on and in gear? Today it started stalling when I was backing out of the garage.
Air Bags
Yokohama 225/60 17
Custom Rear Bumper
Custom front seats
scott936
Topics: 37
Images: 20
Year: 2002
Postby chevymaherchevymaher is online! » April 13th 2011, 12:20am
yes it would.It supposed to idle it up for both.When I put it in reverse you can hear it rev a second before it completely in gear.
Topics: 82
Year: 1994
Postby scott936 [OP] » April 13th 2011, 1:27am
Odds are that's the problem, I will go by my parts house and run a check on her see if any codes come up, IAC is $123.00 sound about right?
Air Bags
Yokohama 225/60 17
Custom Rear Bumper
Custom front seats
scott936
Topics: 37
Images: 20
Year: 2002
Postby chevymaherchevymaher is online! » April 13th 2011, 1:32am
113 bucks for a ac delco one here at the joint I get mine at.Wow the newer vans more it 67 bucks for my year.
Topics: 82
Year: 1994
Postby scott936 [OP] » April 13th 2011, 2:05am
The fun never stops... Check out my post in exteriors
Air Bags
Yokohama 225/60 17
Custom Rear Bumper
Custom front seats
scott936
Topics: 37
Images: 20
Year: 2002
Postby scott936 [OP] » April 13th 2011, 6:02pm
Ran codes.... None...???? Replaced the fuel filter no effect on the idle issue. I hate to throw parts at it till something sticks but I'm at a loss right now :banghead:
Air Bags
Yokohama 225/60 17
Custom Rear Bumper
Custom front seats
scott936
Topics: 37
Images: 20
Year: 2002
Postby chevymaherchevymaher is online! » April 13th 2011, 6:20pm
scott936 wrote:Ran codes.... None...???? Replaced the fuel filter no effect on the idle issue. I hate to throw parts at it till something sticks but I'm at a loss right now :banghead:
Did you check idle RPM with tach.Then put it in gear see what it doing?
Topics: 82
Year: 1994
Postby scott936 [OP] » April 13th 2011, 10:26pm
no not yet, bigger problems came up today the required immediate attention.... Front left tire and right rear found some safety issues that forced me to get a new set... Problem being I have a requirement for weight capacity so trying to find tires that are load range C and that fit is not easy. I ended up with Cooper HT Extra load, its not a true class C but its better then a P metric, had to jump up to 235/75/15. They will be here tomorrow, riding on a doughnut now how sexy is that... :lol:
Air Bags
Yokohama 225/60 17
Custom Rear Bumper
Custom front seats
scott936
Topics: 37
Images: 20
Year: 2002
Postby NY Safari TONKA » April 14th 2011, 6:07am
Try this chk all your sparkplug wires and make sure that the metalic contact to the Cap plus to the plugs are nice and thight...not by suction of insulation :banana:
NY Safari TONKA
Years of Membership: NY Safari TONKA has been a member for 5 full yearsNY Safari TONKA has been a member for 5 full yearsNY Safari TONKA has been a member for 5 full yearsNY Safari TONKA has been a member for 5 full yearsNY Safari TONKA has been a member for 5 full years
Extra Info: AWD EXT 4.3L V6
Postby scott936 [OP] » April 14th 2011, 10:35am
NY Safari TONKA wrote:Try this chk all your sparkplug wires and make sure that the metalic contact to the Cap plus to the plugs are nice and thight...not by suction of insulation :banana:
I will check that this afternoon, thanks
Air Bags
Yokohama 225/60 17
Custom Rear Bumper
Custom front seats
scott936
Topics: 37
Images: 20
Year: 2002
Postby scott936 [OP] » April 14th 2011, 8:05pm
Im using a friends (Shop) a reader to see if I can pick up any codes as I drive.... So far nothing.
Air Bags
Yokohama 225/60 17
Custom Rear Bumper
Custom front seats
scott936
Topics: 37
Images: 20
Year: 2002
Postby scott936 [OP] » June 8th 2011, 3:21am
Well the van never threw a code so i decided to start throwing parts at it. I replace the IAC, TPS and coil, its runs better but still has a bad idle issue so next I will play with the timing and see what I get :confused:
Air Bags
Yokohama 225/60 17
Custom Rear Bumper
Custom front seats
scott936
Topics: 37
Images: 20
Year: 2002
Postby scott936 [OP] » June 11th 2011, 3:17pm
OK today is the day to start playing with timing. I installed a spacer today for the TBI so we'll see if that does any good on Wednesday, that my long trip day
Air Bags
Yokohama 225/60 17
Custom Rear Bumper
Custom front seats
scott936
Topics: 37
Images: 20
Year: 2002
It is currently March 26th 2017, 3:54pm
cybrvanr
Date: Mar 21 '17
Time: 4:55pm
Comments: 23
Date: Mar 17 '17
Time: 1:28pm
Comments: 23
Date: Mar 16 '17
Time: 4:38pm
dweseen
Date: Mar 16 '17
Time: 2:08am
Jawon
Date: Mar 09 '17
Time: 8:43pm
