I have a slow leak. Nothing is dripping on the ground. I poured in the radiator a 1 oz bottle of UV dye. I drove two days to work, 100 miles. I am confused by the results.
I was expecting to find one spot where the leak was. Instead much of the top of the engine is covered with dye. It looks like something is dripping on a pully or the serptine belt and slung it to the top. The biggest concentration is on the bottom of the power steering pump. There is a noticable amount on the top of the intake manifold. I pulled the dip stick and the oil lights up some. This engine has never been overheated. It has 220K on it. I had the intake manifold gaskets replaced 75 k ago.
The intake manifold gasket has gone bad again............tell me this isn't true
