Am i running too hot?
Postby Rookie162 [OP] » June 13th 2017, 11:33pm
I seem to me ON the 210 or just past it
I was doing stop n go around 25-50 mph in 98-100 degrees
Can i do a mod to keep the the fans on maybe?
Rookie162
Fueling (1/2 tank)
Fueling (1/2 tank)
Alias (AKA): Mel
Year: 2002
Extra Info: 4.3L V6 AWD LS
  • Won't Stay Running
    by Merkur » January 17th 2017, 7:27am in Engines
    January 17th 2017, 8:52pm
    65
    June 29th 2017, 6:34am
Re: Am i running too hot?
Postby CopperFiremistCopperFiremist is online! » June 13th 2017, 11:56pm
Pullin The Pass
Years of Membership: CopperFiremist has been a member for 2 full yearsCopperFiremist has been a member for 2 full years
Topics: 17
Images: 5
Alias (AKA): B
Year: 1998
Extra Info: LS Swap
Postby 97cargocrawler » June 14th 2017, 12:04am
Those temp gauges are notoriously inaccurate. But yeah, and efan is great, especially to keep the ac cool in slow traffic.
97cargocrawler
Firing on 2 Cylinders (L5)
Years of Membership: 97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years97cargocrawler has been a member for 5 full years
Topics: 42
Alias (AKA): CC, CARGO, CRAWLER, ASSHOLE
Year: 1997
Postby TurnNburn » June 14th 2017, 12:08am
well, since your fan is bolted directly to the crankshaft of the engine, anytime the engine is running, your fan is turning
I would say your fine at that temp, as long as it doesn't start climbing up from there. Like CC said, notoriously inaccurate gauges.
2000 Astro- 7'' lift, NP233C 4x4 T-case, 31x10.5x15 A/T, ongoing camperization in progress
"If you wont drink a beer with me then we probably cant be friends"
Build thread- viewtopic.php?t=103066
TurnNburn
Firing on 8 Cylinders (L1)
Years of Membership: TurnNburn has been a member for 1 full year
Alias (AKA): My friends call me fluffy
Year: 2000
Extra Info: 4x4 Overlander
Postby timothy47130 » June 14th 2017, 12:58am
I replaced my fan clutch with a Hayden heavy duty when I first got my van and my temp gauge has always stayed between the 2nd bold white line and 210. Only downside is , it is loud when it's cold. That thing really drags the engine down if you take off when you first start it untill it disengages. But I guess that's a small price to pay to stay cool
1998 chevy astro mark III conversion with 125,000 miles
all stock besides-
dual exhaust
rear lifted 1" with s-10 leafs
10,000 lb capacity transmission cooler
corvette 2nd gear servo
Trans-go SK4L60E shift kit
5.7 Vortec swap on the way
timothy47130
Years of Membership: timothy47130 has been a member for 2 full yearstimothy47130 has been a member for 2 full years
Topics: 41
Images: 7
Alias (AKA): Tim
Year: 1998
Extra Info: mark III conversion
Postby Leeann_93 » June 14th 2017, 3:07am
I replaced my fan clutch with a severe duty clutch.
Mine runs just barely below 210 on the gauge, no matter what. But it's lower than that on any of my OBD II devices.
'00 Astro LS AWD vin W - WIP
Image Image
Topics: 27
Year: 2002
Extra Info: LS 4.3L AWD
Postby Zebediah III » June 14th 2017, 3:24am
The gauges are not very accurate. If you real real stickler, and have lots of extra time on your hands you can remove the clear lense from your cluster, reinstall your cluster and let the van run with an accurate scan tool on it. It's possible to pull the orange needle off the gauge and re-position it so that the van's gauge will read what your scan tool is showing. You can do this with oil, fuel etc, they still aren't 100% accurate but they will be a lot better than before. Just don't pull the speedometer one off. When you are done. Remove the cluster and put the clear lense back on.
Zebediah III
Years of Membership: Zebediah III has been a member for 7 full yearsZebediah III has been a member for 7 full yearsZebediah III has been a member for 7 full yearsZebediah III has been a member for 7 full yearsZebediah III has been a member for 7 full yearsZebediah III has been a member for 7 full yearsZebediah III has been a member for 7 full years
Extra Info: 383 Crate Motor
Postby Mmusicman » June 14th 2017, 4:25am
Rookie162 wrote:Can i do a mod to keep the the fans on maybe?
Weird question... unless you are running multiple electric fans, you should only have 1 mechanical fan (not fans) if the system is stock. I'm willing to bet the fan is either turning hard and something else is wrong, or the clutch is defective.
Everyone assumes fan, but the cooling system could have issues, the radiator could have issues... there is more than one possibility. The fan clutch however, is often the culprit.
Is the fan shroud intact? It is vital to proper cooling at idling or low speeds when it's hot out.
If the temp drops when you hit the highway, then your trouble definitely is an airflow issue at low speeds (fan or clutch). If however, your temp stays high, then it's something else.
220 is borderline high... but in the heat of the summer with the A/C on... it's not too far off from normal.
2000 Chevy Astro LS AWD | 31" LT265/70R17 Tires | 8" LIFT | 10" TOTAL
92 Chevy Astro Shorty | V8-350
Firing on 8 Cylinders (L2)
Years of Membership: Mmusicman has been a member for 4 full yearsMmusicman has been a member for 4 full yearsMmusicman has been a member for 4 full yearsMmusicman has been a member for 4 full years
Topics: 36
Year: 2000
Extra Info: 2000 AWD 92 V8-350
Postby ccookie66 » June 15th 2017, 10:24pm
75705
That's where mine runs. I used to think it was running too hot as well, so I changed my thermostat and still ran at the same temperature. So I guess it's normal.
1160Image
The Astro is always a turn key away from adventure.
ccookie66
Firing on 5 Cylinders (L2)
Years of Membership: ccookie66 has been a member for 5 full yearsccookie66 has been a member for 5 full yearsccookie66 has been a member for 5 full yearsccookie66 has been a member for 5 full yearsccookie66 has been a member for 5 full years
Topics: 135
Images: 47
Alias (AKA): Cameron
Year: 1992
Extra Info: 4.3L V6 TBI Shorty
Postby Rookie162 [OP] » June 19th 2017, 4:40pm
ccookie66 wrote:75705
Thabks for that. Lol ibwas gunna do the same.
Rookie162
Fueling (1/2 tank)
Fueling (1/2 tank)
Alias (AKA): Mel
Year: 2002
Postby Rookie162 [OP] » June 19th 2017, 4:43pm
CopperFiremist wrote:Imagevia Imgflip Meme Generator
How much cooker would my temp be with e fan(s)?
Rookie162
Fueling (1/2 tank)
Fueling (1/2 tank)
Alias (AKA): Mel
Year: 2002
Postby CoasterCoaster is online! » June 19th 2017, 5:27pm
none.
temp is controlled by the thermostat, not the fan
before you do anything that costs money, check the ACTUAL temperature. the computer knows what the temp is. mine runs exactly what the thermostat is, but says 210 on the dash
Years of Membership: Coaster has been a member for 4 full yearsCoaster has been a member for 4 full yearsCoaster has been a member for 4 full yearsCoaster has been a member for 4 full years
Topics: 102
Year: 1995
Extra Info: 4.3 cargo 2wd
It is currently June 29th 2017, 6:34am
Rmac
Time: 12:10am
Rookie162
Date: Jun 13 '17
Time: 11:28pm
astrometalvan
Date: Jun 10 '17
Time: 5:10pm
Attached by: xit
xit
Date: Jun 07 '17
Time: 3:17pm
Attached by: Astro Pop
Astro Pop
Date: Jun 06 '17
Time: 6:17am
