Tires For 1998 Astro LT 4.3
Postby luckybodog [OP] » August 6th 2011, 4:06am
Hi Everyone
I have Good year viva I think. They are 40,000 miles tires. The tire did not last 40,000 miles . They wore even but they didn't last but about 27,000 I am ready to try some different tires. I bought these at Walmart. Brands good places to buy any suggestions. luckybodog
luckybodog
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: luckybodog has been a member for 5 full yearsluckybodog has been a member for 5 full yearsluckybodog has been a member for 5 full yearsluckybodog has been a member for 5 full yearsluckybodog has been a member for 5 full years
Topics: 18
Extra Info: LT 4.3
  • 95 astro issues
    by Loyda » October 23rd 2016, 6:59pm in Engines
    October 23rd 2016, 11:30pm
  • 92 astro swap
    by 306astro » February 25th 2017, 7:51pm in Engines
    February 26th 2017, 9:49pm
    81
    April 23rd 2017, 6:47pm
Re: Tires For 1998 Astro LT 4.3
Postby 88astroLT » August 6th 2011, 9:49pm
I bought Michelin tires at Costco for $114 Tire size 225/70/15. I also tried Pep-Boys they are good too but the brands are mostly theirs except for Cooper.
88 Astro LT RWD 343k+ 3.23
97 Safari SLE RWD 143k+ 3.42 Limited Slip
88astroLT
Years of Membership: 88astroLT has been a member for 6 full years88astroLT has been a member for 6 full years88astroLT has been a member for 6 full years88astroLT has been a member for 6 full years88astroLT has been a member for 6 full years88astroLT has been a member for 6 full years
Topics: 19
Extra Info: LT 4.3L V6 RWD
Postby ihatemybike » August 7th 2011, 3:30am
BF Goodrich Long Trail TAs, dang thing last forever.
Aaron
Prev Astros:99,97,00,94,87,86
ihatemybike
Firing on 6 Cylinders (L2)
Years of Membership: ihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full yearsihatemybike has been a member for 8 full years
Topics: 67
Postby Shad0wXCalibur » August 7th 2011, 4:20am
My Astro and Safari had those same tires on there when I bought them. It appears the previous owners just wanted to put the cheapest set of tires they could find on. But mine are wearing pretty well. 87 Astro has been driven 10,000 miles on those tires since I bought it and they still look almost new so I think they could last the 40,000 miles. The Safari already had them on there for a year or so before I bought it but they still have plenty of tread left. There are lots of factors into how long tires last. Front end condition, alignment, air pressure, roads, wether you're loaded or unloaded and simply how you drive it. They ride decent, seem to have low rolling resistance for gas mileage (both vans get 20+ mpg), and I don't notice any abnormal road noise. When they wear out though, I'm going to a different tire just because I want a 235/75/15 and 215/75/15 is the biggest Vivas come in.
Now to answer your question :D . Telling you which tire to get isn't easy because it depends on what you want. Vivas are a passenger tire thus giving a softer ride. So you need to stick to passenger tires if that's what you want. If you live in an area where it snows but don't want two sets of tires, a good all-terrain is what you need. If you want better handling or if you tow/haul quite a bit of weight around, you need an LT tire. I wanna try to the Yokohama Touring-S for my next tire. They make them in 235/75/15 and it could be a tire you want to check out. My friend has them on his Eclipse and says they're working out just fine as far as wear, ride, etc.
1987 Astro
2000 Safari
Shad0wXCalibur
Years of Membership: Shad0wXCalibur has been a member for 5 full yearsShad0wXCalibur has been a member for 5 full yearsShad0wXCalibur has been a member for 5 full yearsShad0wXCalibur has been a member for 5 full yearsShad0wXCalibur has been a member for 5 full years
Topics: 41
Extra Info: Lifted 2wd
Postby luckybodog [OP] » December 5th 2012, 2:36pm
Just a quick note . I bought Ha nooks at the dealer. They are like balloons and cost about $400.00 . I was suckered by the rebate. I'm going with Michelins next time. It all about the money I get all upset about a few bucks. I had the handles on one of my Astros put on at a van place in Ohio. He loaned me a van to take home while he fixed the handles . The Van rode ten times better than mine. I looked on the van it had Michelins on it. I think a few more bucks would be worth the ride.Now that I am Old. Ha
luckybodog
Fueling (5/8 tank)
Fueling (5/8 tank)
Topics: 18
Extra Info: LT 4.3
Postby Big_kid » December 5th 2012, 2:52pm
I like my Grabbers- LT for a stiffer sidewall, gets rid of the 'driving a sponge' feeling.
Firing on 7 Cylinders (L5)
Topics: 140
Images: 72
Extra Info: 2WD conversion
Postby Ragenme » December 5th 2012, 5:17pm
I had to put two tires on the front about 8 months ago. I purchased Firestone destination le. I like having the stiffer side wall. Plus they dig in when I need them to.
ragenme If you can't fix it with a hammer then its probably a electrical problem!
Ragenme
Years of Membership: Ragenme has been a member for 4 full yearsRagenme has been a member for 4 full yearsRagenme has been a member for 4 full yearsRagenme has been a member for 4 full years
Topics: 16
Images: 23
Alias (AKA): Ragenme
Year: 1998
Extra Info: SLX 4.3 V6 RWD
Postby Leeann_93 » December 6th 2012, 3:35am
Firestone Destination LE here, both on the Safari and the Astro.
'00 Astro LS AWD vin W - WIP
Image Image
Topics: 27
Year: 2002
Extra Info: LS 4.3L AWD
It is currently April 23rd 2017, 6:47pm
Jakstro
Date: Apr 17 '17
Time: 5:42am
Attached by: nonhog
nonhog
Date: Apr 14 '17
Time: 11:06pm
sadglad
Comments: 9
Date: Apr 12 '17
Time: 8:42pm
kristuphir
Date: Apr 08 '17
Time: 8:10am
stanvalp
Comments: 64
Date: Apr 08 '17
Time: 3:19am
