fuel pressure regulator
Postby Lewin [OP] » August 19th 2011, 8:23pm
where is the fuel pressure regulator located on a 1997 safari with vortec V6? anyone have a write-up for it as well?
thanks
Lewin
Years of Membership: Lewin has been a member for 1 full year
Alias (AKA): Lewin
Extra Info: Galv Conv
  • fuel pump pressure 1999
    by motokorte » March 19th 2013, 3:25pm in Engines
    Last post by motokorte View the latest post
    March 31st 2013, 2:58pm
  • low fuel pressure question
    by vstar » February 12th 2013, 7:03pm in Engines
    Last post by vstar View the latest post
    February 15th 2013, 7:23pm
    9
    35
    May 21st 2013, 1:03pm
Re: fuel pressure regulator
Postby Phantom » August 20th 2011, 1:50pm
It is attached to the side of the fuel metering body
Here is a pic of it
http://www.partsgeek.com/gbproducts/DC/ ... oogle+Base
Phantom
Firing on 7 Cylinders (L4)
Years of Membership: Phantom has been a member for 2 full yearsPhantom has been a member for 2 full years
Postby brianecamp » August 21st 2011, 4:52am
I just went through the same issue with my 97 . . .
hard starts for the last four months and finally not at all . . .
took me about a day and a half to remove and reinstall my new multiport injectors . . .
i also thourougly cleaned the throttle body, mass air flow sensor and all the sensors that I could get to . . .
runs great now . . .
i bought the delphi unit off of partsgeek.com - you will not need to purchase the bracket because it comes with the kit . . .
you will need to rotate the injectors around in order for the intake manifold to seal - do not be afraid as they are made for moving . . .
same way with the injector arms - they are made to bend into place . . .
you will not need a nut kit - that was last year's model . . .
leean is excellent help on this fuel issue . . .
enjoy !!!
brianecamp
Years of Membership: brianecamp has been a member for 1 full year
Alias (AKA): brian
Extra Info: Cargo
Postby Lewin [OP] » August 21st 2011, 10:04pm
im finding that if i start it up every 5 hours or so (havent pushed it beyond 5 hours yet) im good to keep running. but when i let it sit.... UGH!!!! :screaming: hard to get started again. Im going to try fuel filter this week since according to the prior owners records it hadnt been changed in 5 years BUT the fuel pump was changed 3 years ago. have to check with local auto store see if they have a fuel pressure guage i can get from them to make sure im getting good pressure.
Lewin
Alias (AKA): Lewin
Postby brianecamp » August 30th 2011, 3:23am
it'll be hit or miss . . .
and testing will let you know some things . . .
my pressure dropped too soon - which narrowed the problem down to the the spider assembly including the fuel pressure regulator . . .
or the fuel pump supply inside the tank . . .
i don't want to speak for her, but leeann was suggesting dropping the tank, after my test . . .
i opted for the spider because i wanted multiport fuel injection, anyway . . .
once you go to all that trouble - you may as well do it all . . .
also, i have known the mechanic for decades who replaced the pump in '04 and didn't think he would **** it up . . .
so, like one of the responders said in response to me "you've got to get down and dirty with this . . ."
and you will - but, you will have a much better appreciation of your systems when you get through . . .
good luck !!!
brianecamp
Alias (AKA): brian
Extra Info: Cargo
Postby brianecamp » August 30th 2011, 3:25am
actually, my mechanic treats me with a lot more respect since i've done the work . . .
just something to think about . . .
brianecamp
Alias (AKA): brian
Extra Info: Cargo
Postby Lumpy » August 30th 2011, 5:59pm
brianecamp wrote:actually, my mechanic treats me with a lot more respect since i've done the work . . .
My mechanic gives me a break and does freebies, because I remove the doghouse,
clean the engine (or parts in question) label the plug wires etc. I always try and
make sure little stuff like vacuum lines, fuel filter, air filter, fluid levels, battery charge etc
are taken care of so that he doesn't have to wade through all that to diagnose something.
Firing on 2 Cylinders (L4)
Topics: 116
Year: 1989
Extra Info: 9 in. lift Camo
Postby Novalis » September 6th 2011, 2:54pm
I'm having what I think is the same problem. For the last month or so it was getting harder and harder to start. Now its to the point where it will not start on its own. If I give it a shot of starting fluid it fires right up, and runs great. Any thoughts on the problem would be great.
1997
Chevy Astro AWD
4.3L
Novalis
Years of Membership: Novalis has been a member for 2 full yearsNovalis has been a member for 2 full years
Alias (AKA): Novalis
Extra Info: 4.3L AWD
Postby Leeann_93Leeann_93 is online! » September 7th 2011, 4:14am
You need to test fuel pressure and leakdown at the schrader valve near the rear of the driver's side head.
Post the results.
If it starts with starting fluid (scary by the way), you have a fuel delivery issue. Generally means the fuel pump is getting weak, but we need the numbers. When's the last time the fuel filter was changed?
'02 Astro SL AWD vin X
Years of Membership: Leeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full years
Topics: 17
Images: 3
Year: 2002
Extra Info: SL 4.3L AWD
It is currently May 21st 2013, 1:03pm
kumisukka
Comments: 0
Time: 2:20pm
Attached by: chevymaher
Comments: 19
Time: 1:37am
Comments: 19
Time: 12:40am
Attached by: aztec1987
aztec1987
Date: May 19 '13
Time: 2:44am
aztec1987
Date: May 19 '13
Time: 12:03am
Users browsing this forum: magpie-crawler [Crawler], TaxiVanTaxiVan is online! and 3 guests
