Pulled code 32; EGR Circuit fault
Postby JTalley [OP] » September 23rd 2011, 8:58pm
I have a loss of power, the engine rattles on acceleration, and it seems to run rather warm. This has been going on since shortly after I got the van and has gotten noticeably worse lately.
What do I do?
-Jake
Ed- 1992 Chevy Astro, RWD, 4.3L V6 "Z" Vin
JTalley
Years of Membership: JTalley has been a member for 6 full yearsJTalley has been a member for 6 full yearsJTalley has been a member for 6 full yearsJTalley has been a member for 6 full yearsJTalley has been a member for 6 full yearsJTalley has been a member for 6 full years
Topics: 16
Alias (AKA): Jake
  • Code 1402 popping up...
    by RECox286 » January 31st 2017, 7:38pm in Engines
    Last post by zach914v8 View the latest post
    January 31st 2017, 10:22pm
  • Rough idle and trouble code 12
    by PalIstvan » April 22nd 2017, 11:38am in Engines
    April 22nd 2017, 4:04pm
    87
    June 24th 2017, 7:54pm
Re: Pulled code 32; EGR Circuit fault
Postby throrope » September 23rd 2011, 10:23pm
Sounds like classic EGR (Exhaust Gas Recirculation) valve failure.
Our '94 lit the SES light from every cold start and gave a rattle. A couple miles down the road, the SES went out. Took longer on cold days. I wasn't excited about power either. I finally checked the code which was for the anti knock circuit. Only after I bought and read GM's driveability manual which is in addition to the service manual, did I understand that the EGR valve failed to open under acceleration causing the knock. The PCM or computer following programming set the SES light, stored the code for knock and retarded spark to protect the engine. A programmed time interval after the knock sensor stopped sending, the PCM turned off the SES, but left the timing retarded and sapped power.
After replacing the EGR with one from Advance Auto for about 130 bucks, SES and ping (rattle) gone and power back.
Hope this helps, good luck and keep us posted.
throrope
Years of Membership: throrope has been a member for 6 full yearsthrorope has been a member for 6 full yearsthrorope has been a member for 6 full yearsthrorope has been a member for 6 full yearsthrorope has been a member for 6 full yearsthrorope has been a member for 6 full years
Extra Info: LT 4.3L AWD
Postby JTalley [OP] » September 23rd 2011, 10:31pm
Can the valve be cleaned?
-Jake
JTalley
Topics: 16
Alias (AKA): Jake
Postby throrope » September 23rd 2011, 10:59pm
I and many here have successfully cleaned it. Mine eventually gave up the ghost. A search should reveal success stories.
On our '94, the position of the EGR valve makes it subject to pieces of carbon holding it open. In response to many Mr. Goodwrench's who sandwiched a faucet aerator screen between two gaskets, GM has a $20 EGR gasket that incorporates a stainless steel screen. You may have to tolerate a few dumb looks at the counter before they find the part number. My aftermarket replacement valve came with a standard gasket.
throrope
Postby JTalley [OP] » September 23rd 2011, 11:26pm
How would I clean it? Several searches have revealed absolutely nothing anywhere... :confused:
-Jake
JTalley
Topics: 16
Alias (AKA): Jake
Postby throrope » September 24th 2011, 12:15am
This is the best I can do. From the M/L Van 1994 Driveability, Emissions and Electrical Diagnosis Manual
throrope
Postby JTalley [OP] » September 24th 2011, 11:46pm
I removed something that I was told is the EGR valve, and it looked like it, but there were no electrical wires. Just one vacuum line. My dad and I cleaned it, but there doesn't seem to be any affect on the performance. May have even made it worse, actually.
-Jake
JTalley
Topics: 16
Alias (AKA): Jake
Postby throrope » September 25th 2011, 12:51am
Without seeing it, I suspect you may have pulled the PCV (Positive Crankcase Ventilation) valve. They cost around three bucks. Either way, I'm lost.
I'm guessing yours is a '92 from the posts. I'm not sure we use the same part, but I'm sure if you look up your year's EGR on an online parts retailer, the picture will show a wiring connection. Otherwise, I'll be surprised and learn something new.
BTW, I purchased the set of manuals that provided the pages I posted for thirty bucks through Amazon.com.
Good luck and please keep her on the road.
throrope
Postby JTalley [OP] » September 25th 2011, 1:28am
Mine's a 92. I just looked it up, and I found out that apparently mine doesn't have any wiring on it.
Also, while I still have the loss of power and some bad engine rattling, I haven't got the code 32 again since I've cleaned it.
Think I'll try and get some oil tomorrow and change it. I heard Valvoline is the best. Should I go 10W-30 or 10W-40? I think 40 would be best since the van has about 174,xxx miles on it.
-Jake
JTalley
Topics: 16
Alias (AKA): Jake
Postby JTalley [OP] » September 26th 2011, 3:09pm
Got Valvoline 10W-30 and did an oil change yesterday with an ACDelco oil filter. Reduced the rattle, but it's still there. Some more driving revealed that cleaning the EGR did help some with the performance.
-Jake
JTalley
Topics: 16
Alias (AKA): Jake
It is currently June 24th 2017, 7:54pm
Rookie162
Date: Jun 13 '17
Time: 11:28pm
astrometalvan
Date: Jun 10 '17
Time: 5:10pm
Attached by: xit
xit
Date: Jun 07 '17
Time: 3:17pm
Attached by: Astro Pop
Astro PopAstro Pop is online!
Date: Jun 06 '17
Time: 6:17am
astrometalvan
Date: Jun 06 '17
Time: 1:14am
Users browsing this forum: Bing [Bot], weatherweather is online! and 6 guests
