Engine Removal
Engine Removal
Postby szczerba [OP] » September 26th 2011, 6:50pm
Can a 2001 Astro front /Grill, radiator mounts etc. be removed to replace the engine?
2001 Astro 4.3l rwd 160K
szczerba
Years of Membership: szczerba has been a member for 5 full yearsszczerba has been a member for 5 full yearsszczerba has been a member for 5 full yearsszczerba has been a member for 5 full yearsszczerba has been a member for 5 full years
Alias (AKA): BigAl
Extra Info: 4.3l v6
  • subframe removal questions
    by Intenseman » November 12th 2016, 2:29am in Engines
    Last post by astroracer View the latest post
    November 12th 2016, 4:48am
  • So many engine options!?
    by Echo » December 4th 2016, 11:15pm in Engines
    Last post by Lumpy View the latest post
    March 19th 2017, 1:31am
    9
    48
    March 30th 2017, 3:35pm
Re: Engine Removal
Postby Jasen » September 26th 2011, 11:01pm
They typically come out the bottom. once everything is ready to remove the engine, unbolt the sub frame and roll it out from underneath.
If you take it out the front you have to cut out the radiator support and then either weld it back in or get or fab up a bolt on tab system to reinstall it.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Year: 1997
Re: Engine Removal
Postby szczerba [OP] » September 27th 2011, 2:08am
Thanks for the reply. When you say subframe what are you referring to? This is a driveway project using floor jacks and stands.
szczerba
Alias (AKA): BigAl
Extra Info: 4.3l v6
Re: Engine Removal
Postby Phantom » September 27th 2011, 2:50am
Here is an example of how the subframe slides out ,,I have a pic of how to remove from front , just cant find it at the moment , it is actually easier to remove the subframe and it makes for a roll around cart till you put it back on the van , there is a nice pic of a late model Ben2 with body raised up on the site , don't recall which thread though
89 safari subframe.JPG (95.98 KiB) Viewed 12314 times
Phantom
Firing on 7 Cylinders (L4)
Re: Engine Removal
Postby Jasen » September 27th 2011, 2:51am
That looks like a driveway project to ;)
I've seen the van lifted with an engine hoist to.
200k
Ultra gauge
Topics: 260
Images: 101
Year: 1997
Re: Engine Removal
Postby paintdrying » September 27th 2011, 2:54am
That really does not look to bad.
paintdrying
Topics: 94
Extra Info: 108 000
Re: Engine Removal
Postby Jasen » September 27th 2011, 2:59am
paintdrying wrote:That really does not look to bad.
Compared to weaseling it out, getting hung up on something, smashing your hand trying to keep the motor or tranz from smashing something else.. :lol:
200k
Ultra gauge
Topics: 260
Images: 101
Year: 1997
Re: Engine Removal
Postby chevymaherchevymaher is online! » September 27th 2011, 3:07am
Because of the core support being a solid piece, out the bottom the way,on his year van.I pulled a 90 van engine out the front.It really has alot of room coming out.Actually comes out easier than pulling the engine and tranny,at the same time,than out of a normal car.Normal being engine actually under the hood.Chevelle,mustangs and the like.
Topics: 82
Year: 1994
Re: Engine Removal
Postby szczerba [OP] » September 27th 2011, 4:28am
Thanks to all. Any more pics or tips will help. We have 10 days to complete this repair
szczerba
Alias (AKA): BigAl
Extra Info: 4.3l v6
Re: Engine Removal
Postby szczerba [OP] » September 28th 2011, 12:54am
Thanks for the comments but I am uncomfortable looking at that pic with the body raised and supported in an area doesn't seem to part of the main body support. Is that a safe place to hold all that weight?
What method is used to raise the body? Using jacks or engine hoist? Where is the lift points?
What need to be disconnected between the 2 halves.
Need Help
szczerba
Alias (AKA): BigAl
Extra Info: 4.3l v6
Re: Engine Removal
Postby RECox286 » September 28th 2011, 1:17am
Get under, over and around to see what stays with the body, and what needs disconnecting. Things should be pretty obvious, and then when you lift the body, most of the weight will be left sitting on
the ground. It is not as scary as you might think. Be sure to set the E-brake, and chock the rear tires. You will be able to see the areas that can be considered lift points if you look. I would suggest that
you get yourself a copy of Haynes, or Chiltons repair manual, or better yet, look on Ebay for a Factory Service Manual. It's mostly like learning to ride a bike, scary the first time...
Good luck
Bob
RECox286
Topics: 38
Alias (AKA): Uncle Bob
Year: 1993
Extra Info: RWD V6 [325K mi]
Re: Engine Removal
Postby astroracer » September 28th 2011, 1:32am
You would be much farther ahead to pull the motor out the front... It sounds to me like you don't have a lot of experience with this kind of work. If that's the case you probably don't have most of the tools required either. Leave the trans in the van and and use an engine lift plate bolted directly to an engine hoist to lift the engine up and out. Very simple.
Pulling the engine out the front does require cutting the upper radiator support but that is much easier than removing the entire sub. Disconnecting the steering and brakes. trans lines, drive shaft, shifter linkage, etc.
Mark
2004 Astro
2001 Astro (the wifes)
2000 Monte Carlo SS
2000 Astro Conversion Van
1994 Formula V8 Firebird
1956 Chevy Station Wagon
astroracer
Years of Membership: astroracer has been a member for 7 full yearsastroracer has been a member for 7 full yearsastroracer has been a member for 7 full yearsastroracer has been a member for 7 full yearsastroracer has been a member for 7 full yearsastroracer has been a member for 7 full yearsastroracer has been a member for 7 full years
Alias (AKA): astroracer
Year: 1988
Extra Info: Major renovation
Re: Engine Removal
Postby chillin_illin » May 16th 2013, 1:53am
Hello there. I know this is an old post. But by any chance did you ever get to changing the engine? If so, did you have any problems when starting the new engine?
chillin_illin
Years of Membership: chillin_illin has been a member for 3 full yearschillin_illin has been a member for 3 full yearschillin_illin has been a member for 3 full years
Year: 1998
Extra Info: LS 4.3 V6 RWD 4L60E
It is currently March 30th 2017, 3:35pm
cybrvanr
Date: Mar 21 '17
Time: 4:55pm
MmusicmanMmusicman is online!
Comments: 23
Date: Mar 17 '17
Time: 1:28pm
Comments: 23
Date: Mar 16 '17
Time: 4:38pm
dweseen
Date: Mar 16 '17
Time: 2:08am
Jawon
Date: Mar 09 '17
Time: 8:43pm
Users browsing this forum: Dotbot [Bot] and 8 guests
