Freeze Plug?
Freeze Plug?
Postby Leeann_93 [OP] » November 7th 2011, 11:29pm
The water pump on the Safari was leaking, but it's leaking worse behind the power steering pump. It's leaking pretty badly, too.
1) Would it be a freeze plug or the head or a sensor I don't know about? Is there any way to tell?
2) Can he take off the bracket without first unbolting the power steering pump and AC compressor?
When filling the rad after swapping the water pump, he heard a szzzzzzzzzzzzzzz noise, then water poured out from behind the power steering pump down onto the lower part of the bracket. I'm guessing it's a rusted freeze plug, but he can't see back behind it, even with his remote camera thingy.
I can't help him and the manuals are upstairs (though he can go get those) since I'm still laid up with my dang ankle.
'00 Astro LS AWD vin W - WIP
Image Image
Topics: 26
Year: 2002
Extra Info: LS 4.3L AWD
Re: Freeze Plug?
Postby Jasen » November 7th 2011, 11:47pm
Bump for the gimp ;)
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Images: 101
Year: 1997
Re: Freeze Plug?
Postby Phantom » November 7th 2011, 11:55pm
Maybe this can be a help with the visual , not sure which power steering type you have , so here is both
It could be a freeze plug giving out
a temp sensor is item 217 in pic png3
if leak is lower than the head it would be a freeze plug I believe
Put the brightest lighting possible under van , maybe that will help see it location
Phantom
Firing on 7 Cylinders (L4)
Re: Freeze Plug?
Postby chevymaher » November 8th 2011, 12:13am
LeAnn when I stripped my 90 van.And looking at Phantoms diagram,they look the same.In Phantoms pic I re-posted the red arrow is the freeze plug in the block.The air compressor will have to come loose,it will prevent the bracket from moving toward the drivers side enough to get at the plug.Disconnecting the rear mounts of the compressor only, may be enough.The power steering pump can stay with bracket.Hoses have enough play to move it out of the way.I pulled the engine out the front with it just like that.Hope this help save you some work.
Topics: 79
Year: 1994
Re: Freeze Plug?
Postby Leeann_93 [OP] » November 8th 2011, 12:36am
Thanks - that all helps a lot!
Image Image
Topics: 26
Year: 2002
Re: Freeze Plug?
Postby chevymaher » November 8th 2011, 12:42am
Welcome
Topics: 79
Year: 1994
Re: Freeze Plug?
Postby RECox286 » November 8th 2011, 1:57am
Hey, Leeann,
What happened the the gam ? Out trick or treating and hit a crack in the sidewalk ???
Hope you heal quickly, I heard thru the grapevine that there is a leak to plug on your ride.
Get well soon
Bob
RECox286
Topics: 37
Alias (AKA): Uncle Bob
Year: 1993
Extra Info: RWD V6 [325K mi]
Re: Freeze Plug?
Postby Leeann_93 [OP] » November 8th 2011, 2:27am
Out walking. Was going down a soft hill/berm, didn't realize how steep it was, rolled the ankle under me, dislocating and breaking it in several places (and pulling the ligament off the bone). Had surgery to pin the ligament back on and pin the bone back together.
Did it 4 weeks ago now. Surgery 3 weeks ago.
Image Image
Topics: 26
Year: 2002
Re: Freeze Plug?
Postby RECox286 » November 8th 2011, 2:43am
Ouch, that don't sound like no fun.
Hope you got some good meds...
Bob
RECox286
Topics: 37
Year: 1993
Re: Freeze Plug?
Postby Leeann_93 [OP] » November 8th 2011, 2:49am
Just Vicodin....
Image Image
Topics: 26
Year: 2002
Re: Freeze Plug?
Postby rev_les » November 8th 2011, 6:12am
gettin' old sucks. I did all kinds of crazy stuff in my younger years, trouble free. In the last 3, I've fractured an ankle, broken ribs, fractured a knee, and had 3 hernias fixed...... WTH?????
edit** and my Dr. for some damned reason, keeps feeling the need to remind me that I'm not 16 years old anymore...the quack!
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 7 full yearsrev_les has been a member for 7 full yearsrev_les has been a member for 7 full yearsrev_les has been a member for 7 full yearsrev_les has been a member for 7 full yearsrev_les has been a member for 7 full yearsrev_les has been a member for 7 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Re: Freeze Plug?
Postby RECox286 » November 8th 2011, 2:45pm
It ain't nice to fool mother nature. But this getting old is, er, getting old !
Bob
RECox286
Topics: 37
Year: 1993
Re: Freeze Plug?
Postby Leeann_93 [OP] » November 8th 2011, 10:45pm
rev_les wrote:gettin' old sucks. I did all kinds of crazy stuff in my younger years, trouble free. In the last 3, I've fractured an ankle, broken ribs, fractured a knee, and had 3 hernias fixed...... WTH?????
Dang! :shock:
I just dislocated/broke my left ankle, as y'all know. Broke my left knee 31 years ago and had surgery to remove the massive chip. No hernias. Tore ligaments in my other knee that resulted in a subluxing patella (the kneecap dislocates at will). Sprained both ankles 8 times. Broke my left big toe, through and through. Broke 2 fingers, jammed/sprained the rest. Broke a bone or two in my hand. Broke my nose (hairline fracture).
This ankle thing is the first nastiness in over 11 years and I was hoping to lengthen the streak. Instead, I did the worst damage I've ever done at one time.
Image Image
Topics: 26
Year: 2002
Re: Freeze Plug?
Postby RECox286 » November 8th 2011, 11:22pm
I guess we can forget about giving you a nickname for the moment. I was going to suggest "Lucky", but somehow it seems not to fit...
Bob
RECox286
Topics: 37
Year: 1993
Re: Freeze Plug?
Postby Jasen » November 8th 2011, 11:27pm
RECox286 wrote:I guess we can forget about giving you a nickname for the moment. I was going to suggest "Lucky", but somehow it seems not to fit...
Bob
Crash? :shrug:
200k
Ultra gauge
Images: 101
Year: 1997
Re: Freeze Plug?
Postby Leeann_93 [OP] » November 8th 2011, 11:47pm
^ and ^^ Brats!
Image Image
Topics: 26
Year: 2002
Re: Freeze Plug?
Postby Jasen » November 9th 2011, 1:17am
Leeann, I'm not far behind you. Ripped the ligaments loose in both ankles (different times) twisted them countless times. Fractured shin bone, broken knuckle, dislocated finger, nose broke 4 times, once it split into the eye socket, broken toe, cracked collar bone, 3 separated ribs, water on the knee, blew back out a few times. Got some rotator cup issue going on in the shoulder. Lets not get into lacerations, gouges and punctures, and then there's all these odd lumps and dent's on my skull :shrug:
200k
Ultra gauge
Images: 101
Year: 1997
Re: Freeze Plug?
Postby Leeann_93 [OP] » November 9th 2011, 1:28am
Were we supposed to mention stitches? My left hand...3 layers of stitches. Over 300 total. Other than incisions, that's all the stitches I have.
Image Image
Topics: 26
Year: 2002
Re: Freeze Plug?
Postby RECox286 » November 9th 2011, 1:40am
whoa, what do we have here, a peeing contest ? Ha. (as delicately as I could think of making it)
Bob
RECox286
Topics: 37
Year: 1993
Re: Freeze Plug?
Postby Leeann_93 [OP] » November 9th 2011, 1:46am
:P
Image Image
Topics: 26
Year: 2002
It is currently January 23rd 2017, 3:42pm
Attached by: shredzorv2
shredzorv2
Comments: 36
Time: 11:09pm
Ingmire
Date: Jan 18 '17
Time: 1:09am
Driftedone
Comments: 13
Date: Jan 10 '17
Time: 7:12am
Echo
Comments: 17
Date: Jan 09 '17
Time: 6:50pm
shredzorv2
Comments: 36
Date: Jan 01 '17
Time: 2:12am
Users browsing this forum: Dotbot [Bot] and 4 guests
