Yet another post about stumbling engine at low RPM's
Postby trapper20 [OP] » November 30th 2011, 11:22pm
Seems like there are 100's of posts on here about vans with this problem, and yet I can't figure out what it is. My van stumbles at low rpms, but when you punch it, it takes off without problems. I replaced the fuel filter, no change. A week ago I had a "Evap control slight leak" code or something like that. Plugs are newer, one wire has a bare spot where it contacted the manifold, but that doesn't seem to be the issue. THe problem has gotten progressively worse over the past couple of weeks. Any ideas?
trapper20
Years of Membership: trapper20 has been a member for 5 full yearstrapper20 has been a member for 5 full yearstrapper20 has been a member for 5 full yearstrapper20 has been a member for 5 full yearstrapper20 has been a member for 5 full years
Topics: 25
Images: 3
Extra Info: Lifted 4x4 V8
  • Low idle 550 rpm
    by ezbeinsteezy » January 10th 2017, 5:36pm in Engines
    January 14th 2017, 2:41pm
  • Low oil pressure
    by dantheman » November 27th 2016, 11:43pm in Engines
    Last post by dantheman View the latest post
    November 28th 2016, 12:22am
    25
    February 24th 2017, 10:58pm
Re: Yet another post about stumbling engine at low RPM's
Postby Phantom » November 30th 2011, 11:31pm
Bad distributor cap ,,maybe cracked vacuum lines , dirty MAF sensor
be sure that plug wire has been moved away from any metal areas and away from other plug wires too close together
Phantom
Firing on 7 Cylinders (L4)
Postby trapper20 [OP] » November 30th 2011, 11:51pm
Maf sensor, cap and rotor all replaced recently, but dirty Maf sensor is a possibility...what is the best way to clean them?
trapper20
Topics: 25
Images: 3
Postby Phantom » December 1st 2011, 12:01am
Hope you used a high quality cap , the cheap ones don't last
To give official MAF cleaning method I'd have to look it up , but i have used a clean rag dampened with carb cleaner , just don't get any on the electrical part , I have even just removed air filter and wiped the screen off and that helps sometimes
Also could be a leaking injector ir nut kit putting raw gas into manifold , just enough to be momentarily over rich fuel mixture
if you haven't removed the screens in the distributor that can also cause it ,
Phantom
Postby Corsemoto » December 1st 2011, 3:10am
If going to clean, buy a can of the mass air flow sensor spray cleaner at the auto parts store and use that, it's safe and won't risk damaging sensitive sensors. After intermittent P0101 code on medium/full acceleration and so I just removed and spray cleaned mine, let it dry out for a few hours while I did other some other maintenance and reinstalled - no more intermittent code on accel.
Corsemoto
Firing on 4 Cylinders (L3)
Years of Membership: Corsemoto has been a member for 8 full yearsCorsemoto has been a member for 8 full yearsCorsemoto has been a member for 8 full yearsCorsemoto has been a member for 8 full yearsCorsemoto has been a member for 8 full yearsCorsemoto has been a member for 8 full yearsCorsemoto has been a member for 8 full yearsCorsemoto has been a member for 8 full years
Topics: 36
Images: 13
Year: 2004
Extra Info: LT AWD
Postby Sloth Patrol » December 3rd 2011, 3:57pm
when i had my glasspack installed my 99 Astro would do the same thing too. i have the following:
Accel Cap/Rotor
Bosch Platinum Plus
Bosch Wire set
Spectre Air Filter
Cherry Bomb glasspack
before i had the stuff put on my van would hesitate, hard shift, shutter. now i can step on it and roast the tires. whenever it rains my van would continue to shutter but when its all warmed up it is fine.
1999 Chevy Astro Custom Craft 153K. 21mpg.
Sloth Patrol
Years of Membership: Sloth Patrol has been a member for 5 full yearsSloth Patrol has been a member for 5 full yearsSloth Patrol has been a member for 5 full yearsSloth Patrol has been a member for 5 full yearsSloth Patrol has been a member for 5 full years
Alias (AKA): Dakota Skidds
Extra Info: Custom Craft
Postby trapper20 [OP] » December 12th 2011, 11:02pm
Took the cap off, all the electrodes had white deposits on them. Cap was only a few months old. That'll teach me to get the economy cap.
trapper20
Topics: 25
Images: 3
Postby Jasen » December 12th 2011, 11:15pm
:whack: ;)
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Year: 1997
Postby alexalexanders » December 13th 2011, 2:12am
Ok mine does this to, but i just put new plugs wires cap rotor, all acdelco and wix fuel filter and cleaned the maf. I havent checked vacuum lines but i thought when you had a leaking vacuum line it caused poor mpg? Mines at 20mpg. I do have the common broken vacuum line that causes air from vents only, but i wouldnt think that would cause any running issues correct? Oh ive also run fuel injector cleaner last tank. How do i check for vacuum leaks?
2000 GMC Safari SLE
alexalexanders
Firing on 8 Cylinders (L1)
Years of Membership: alexalexanders has been a member for 7 full yearsalexalexanders has been a member for 7 full yearsalexalexanders has been a member for 7 full yearsalexalexanders has been a member for 7 full yearsalexalexanders has been a member for 7 full yearsalexalexanders has been a member for 7 full yearsalexalexanders has been a member for 7 full years
Topics: 80
Extra Info: SLE 4.3 Vortec
Postby chevymaher » December 13th 2011, 2:16am
alexalexanders wrote:Ok mine does this to, but i just put new plugs wires cap rotor, all acdelco and wix fuel filter and cleaned the maf. I havent checked vacuum lines but i thought when you had a leaking vacuum line it caused poor mpg? Mines at 20mpg. I do have the common broken vacuum line that causes air from vents only, but i wouldnt think that would cause any running issues correct? Oh ive also run fuel injector cleaner last tank. How do i check for vacuum leaks?
A vacuum leak would definitely make it run like that.
Topics: 81
Year: 1994
Postby alexalexanders » December 13th 2011, 2:31am
Thank you, whats the best way to check for leaks? Can they be checked from under the hood or do i gotta take the dog house off?
Also, does anyone know if the astro/safari takes the same size vacuum lines or various sizes? Reason i ask is, if they take the same size i may just buy a good amount of whatever size it is and a universal pack of fittings from the help aisle and replace it all. Thanks in advance!
2000 GMC Safari SLE
alexalexanders
Topics: 80
Postby chevymaher » December 13th 2011, 2:41am
I am not sure on your year.But I am almost positive the dog house has to come off.Mine does.Just check the rubber hoses for cracking.The boots where they plug in for tightness and cracking also.There are hard lines just bend them if they are cracked they will snap.I had replaced most of the lines a couple years ago.Was messing with the engine and one of the boots just fell off a while back.Replaced it and the idle was alot smoother.You just got to follow them all and check them.I did not have a diagram for it, I just winged it.I have not seen vacuum diagrams on internet or on site either.One of the vans big trade secrets I am afraid.Service manual only place I have not been able to look,don't have one.
Topics: 81
Year: 1994
Postby Jamie » December 15th 2011, 8:45pm
There is a vacuum schematic somewhere here on this forum, don't remember exactly where, I believe it's in the heater-A/C section, I'll look when I get home.
Jamie
Years of Membership: Jamie has been a member for 5 full yearsJamie has been a member for 5 full yearsJamie has been a member for 5 full yearsJamie has been a member for 5 full yearsJamie has been a member for 5 full years
Topics: 22
Postby Jamie » December 17th 2011, 10:24pm
viewtopic.php?f=43&t=9572
Try this, a good view of the vacuum system
Jamie
Topics: 22
Postby Lumpy » December 18th 2011, 4:31am
I've seen several vacuum diagrams for my year. None of them agree.
Vacuum routing varied with where the vehicle was meant to be used.
ie Calif emissions probably demanded one thing, vans in the cold north
another, vans in the Southwest another.
I've replaced my lines. Just took a one inch piece of line to the LAP and
asked for something like 20 ft. Be sure you tell them it's vacuum line.
That's a lot cheaper than something like fuel line.
Then just start replacing ONE hose at a time by disconnecting ONE end,
plugging on the new hose and following to the OTHER end of the old hose.
Pack of those connector thingies from HELP and a bunch of hose only costs
about a burrito's worth of pesos.
Topics: 258
Year: 1989
Postby Wagon Master » December 18th 2011, 10:46pm
The "Check Engine" light was on when I bought my truck, and the prior owner said that the dealer told him it was the EGR valve. I pulled the valve and found it wedged part open because of deposits. Made it run REALLY rough at idle, and would die if I didn't keep the gas on. Replaced it, but I still get that issue on occasion, but WITHOUT the "Check Engine" light. I find that revving the motor generally blows the gunk off the valve and it returns to normal.
Something to consider when running rough at idle, before buying tons of parts.
Wagon Master
Years of Membership: Wagon Master has been a member for 5 full yearsWagon Master has been a member for 5 full yearsWagon Master has been a member for 5 full yearsWagon Master has been a member for 5 full yearsWagon Master has been a member for 5 full years
Topics: 10
Extra Info: SLT AWD Loaded
It is currently February 24th 2017, 10:58pm
AstroNuts
Comments: 68
Date: Today
Time: 4:56am
AstroNuts
Comments: 68
Time: 5:19am
Comments: 22
Date: Feb 22 '17
Time: 4:37am
Attached by: 97cargocrawler
97cargocrawler
Comments: 68
Date: Feb 21 '17
Time: 6:29pm
Attached by: Coaster
CoasterCoaster is online!
Comments: 109
Date: Feb 20 '17
Time: 5:25pm
