Oil in coolant overflow tank
Postby ahiggin [OP] » December 2nd 2011, 5:37pm
My '98 just rolled over to 200,000 miles. But now I'm seeing oil in the coolant overflow tank. Possible causes?
ahiggin
Years of Membership: ahiggin has been a member for 5 full yearsahiggin has been a member for 5 full yearsahiggin has been a member for 5 full yearsahiggin has been a member for 5 full yearsahiggin has been a member for 5 full years
Topics: 5
Extra Info: 4.3L RWD SLT
Re: Oil in coolant overflow tank
Postby Phantom » December 2nd 2011, 5:50pm
Depends on if that oil is engine oil or transmission oil
If trans fluid the trans cooler tube in the radiator tank is leaking , you would need to replace radiator and flush trans fluid out of trans cause coolant will be in the transmission an will damage it if not removed
If engine oil you may have blown head gasket , cracked head , cracked engine block or other way that the oil can enter the cooling system
remove radiator cap and check coolant and check oil dipstick for a milkshake looking oil
Phantom
Firing on 7 Cylinders (L4)
Postby ahiggin [OP] » December 2nd 2011, 6:34pm
More data: I discovered the oil in the coolant tank on Sunday. At that time, I removed, emptied and cleaned the tank and filled it with fresh coolant. I then drove to Dallas and back, approx. 500 miles round trip. Now there is no more oil in the tank. Still a tiny bit of oil under the radiator cap, but no more than when I checked it Sunday. I checked the oil dipstick, and the oil is clear and has no unusual odor. I checked the trans dipstick and the fluid is clear with no unusual odor. Results: inconclusive.
I suppose the next steps are to pull the oil pan and trans pan, but I don't think that will help diagnose it either. Clearly oil is coming from one of the two sources. My bet is on the radiator.
Any other diagnostic suggestions? And thanks for your help!
ahiggin
Topics: 5
Postby Phantom » December 2nd 2011, 6:45pm
When you discovered the oil in the coolant tank , how did you determine it to be oil , what did iy look like ? what color was the coolant in tank? did it look foamy or have bubbles in it?
If there is a pinhole leak in the trans cooler tube it could be a slow leak of fluid into the radiator
Phantom
Postby ahiggin [OP] » December 2nd 2011, 7:06pm
It looked like a black oil slick floating on top of the coolant. I don't remember it looking foamy or bubbly. When I rubbed it between my fingers, it was much slicker than antifreeze.
ahiggin
Topics: 5
Postby Phantom » December 2nd 2011, 7:37pm
Certainly something to watch closely , if you have the engine oil cooler , it may have a pinhole slow leak just like the trans cooler tube . ....ever used a radiator stop leak product like Bars leak ?
it has some type of black slippery liquid in it.
sometimes I have seen black residue inside of coolant overflow bottles that is just old crudded coolant from age as many people do not clean the bottle when they change coolant , you can get a cooling system pressure test to make sure it is holding good pressure
Phantom
Postby ahiggin [OP] » December 2nd 2011, 8:16pm
Ah, good thought about the engine oil cooler. Yes, it has one - not called out as a separate RPO code, so must be part of the Z82 HD trailering package.
I used a Bars leak product years ago, but the system has been flushed several times since then.
As far as pressure-testing the cooling system, wouldn't that risk forcing coolant into either the engine or trans if there's a small leak? I could pull the oil lines and coolant hoses off the radiator, and cap the radiator hose connections to pressure-test the radiator in isolation.
I think I'll just flush the cooling system and keep an eye on it for now. It's overdue anyway.
Phantom, you've been very helpful. Thanks!!
ahiggin
Topics: 5
Postby ahiggin [OP] » December 12th 2011, 7:48pm
For those who might stumble onto this thread with oil in their coolant tank, the problem turned out to be a bad radiator. There was a crack in the engine oil cooling coil in the radiator tank causing a small leak. New radiator: $170, new cap: $7, Dexcool: $25, Coolant flush additive: $4, engine oil: $15, oil filter: $5, total parts and materials: $226, Labor: $253. Repair total: $479.
ahiggin
Topics: 5
Postby Jasen » December 12th 2011, 7:53pm
Fortunately it was small and in the rad and you discovered it in short order.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Images: 101
Year: 1997
Postby Phantom » December 12th 2011, 7:55pm
Good to hear you got it fixed :dance:
Sad that the labor charge was more than all the parts combined :(
Phantom
Postby ahiggin [OP] » December 12th 2011, 10:46pm
Phantom, thanks again for your help in hitting the problem dead on. I asked the shop to pull the trans and engine oil lines off the radiator before pressure testing the radiator, which they did. Yeah, I'm not used to labor charges at all, as I usually do all the work myself. But with a bathroom remodel and Christmas stuff going on, I didn't have time. Also doesn't hurt to have one of these repair statements occassionally to remind my wife that even though I'm retired, I'm still worth a little as a general fixit man. :D
ahiggin
Topics: 5
Postby RECox286 » December 13th 2011, 2:28am
Thank You !
We appreciate your follow-ups just as much as y'all appreciate the information that we provide.
Glad you got your truck back on the right side of the road.
Bob
RECox286
Topics: 37
Alias (AKA): Uncle Bob
Year: 1993
Extra Info: RWD V6 [325K mi]
It is currently January 18th 2017, 11:11pm
Ingmire
Date: Today
Time: 1:09am
Driftedone
Comments: 13
Date: Jan 10 '17
Time: 7:12am
Echo
Comments: 17
Date: Jan 09 '17
Time: 6:50pm
Attached by: shredzorv2
shredzorv2
Date: Jan 01 '17
Time: 2:12am
Voltsmith
Comments: 40
Date: Dec 28 '16
Time: 10:24pm
