Power steering leak
Power steering leak
Postby trapper20 [OP] » February 11th 2012, 6:41am
I have a power steering leak, apparently somewhere on or near the pump as evidenced by fluid everywhere in the vicinity and low fluid. Is there a standard place these usually leak?
trapper20
Years of Membership: trapper20 has been a member for 5 full yearstrapper20 has been a member for 5 full yearstrapper20 has been a member for 5 full yearstrapper20 has been a member for 5 full yearstrapper20 has been a member for 5 full years
Topics: 25
Images: 3
Extra Info: Lifted 4x4 V8
  • Astro Van Power Steering Fluid Leak
    by dweseen » March 16th 2017, 2:09am in Engines
    Last post by dweseen View the latest post
    March 19th 2017, 3:51pm
  • Yet another of my power steering questions.
    by Echo » February 13th 2017, 11:31pm in Engines
    February 14th 2017, 1:01am
    68
    March 28th 2017, 8:42pm
Re: Power steering leak
Postby Lumpy » February 11th 2012, 1:10pm
My old and leaky pump leaked at the fittings. The gear box leaked at the top of the box, where the steering (wheel) shaft enters. Replaced the pump, fluid still leaked from the box and telegraphed down the lines to the pump. So then replaced the box too.
Getting to the hoses on the back of the pump is not simple. It's challenging to get the high pressure hose threaded on there straight. If it gets crooked and the threads get boogered up it'll never seal. If you can get to the connections and check for tightness, AND if it reveals itself as stripped, might as well get ready to replace the pump. You'll like the feel of things if you do. And it's not terribly expensive.
Year: 1989
It is currently March 28th 2017, 8:42pm
cybrvanr
Date: Mar 21 '17
Time: 4:55pm
Comments: 23
Date: Mar 17 '17
Time: 1:28pm
Comments: 23
Date: Mar 16 '17
Time: 4:38pm
dweseen
Date: Mar 16 '17
Time: 2:08am
Jawon
Date: Mar 09 '17
Time: 8:43pm
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 6 guests
