Location of coolant temp sensor
Postby ccookie66 [OP] » February 29th 2012, 5:25am
Hello, I need to replace the coolant temp sensor on my 1993 chevy astro. anybody know where the sensor is located? I think I might have an idea, if I follow the radiator hose, is the sensor behind the air intake box/tube? I'm not really sure, any help would be appreciated.
The Astro is always a turn key away from adventure.
ccookie66
Firing on 5 Cylinders (L2)
Years of Membership: ccookie66 has been a member for 4 full yearsccookie66 has been a member for 4 full yearsccookie66 has been a member for 4 full yearsccookie66 has been a member for 4 full years
Topics: 131
Images: 38
Re: Location of coolant temp sensor
Postby satrunsc2 » February 29th 2012, 5:50am
hey same as my van i have a 93 tbi fallow the top hose to engine and it is beside it i think yellow and black wire on top be sure to drain syste first or you will have coolent all over engine :screaming: . hope this helps
satrunsc2
Years of Membership: satrunsc2 has been a member for 5 full yearssatrunsc2 has been a member for 5 full yearssatrunsc2 has been a member for 5 full yearssatrunsc2 has been a member for 5 full yearssatrunsc2 has been a member for 5 full years
Topics: 5
Images: 13
Alias (AKA): chris
Year: 1993
Extra Info: 4.3L v6 rwd beater
Postby RECox286 » February 29th 2012, 3:04pm
There are two coolant temp sensors on the 4.3. The one for the computor is on the passenger side of the water outlet housing (T-stat).
The one for the gage is inbetween spark plugs number 3 and 5 on the driver side cylinder head. Make sure you procure and change the
proper part.
Uncle Bob
RECox286
Topics: 37
Alias (AKA): Uncle Bob
Year: 1993
Extra Info: RWD V6 [325K mi]
Postby redfury » March 1st 2012, 6:23am
The one on the side of the motor is a single wire that is attached to the sensor, don't try to pull it off, you have to disconnect it from the harness, not the sensor...not sure why it was designed that way.
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Year: 1998
Extra Info: LT 5.7L 4wd
Postby Lumpy » March 2nd 2012, 3:29am
redfury wrote:The one on the side of the motor is a single wire that is attached to the sensor, don't try to pull it off, you have to disconnect it from the harness, not the sensor...not sure why it was designed that way.
On my 89 that sensor connection is a regular push on, pull off spade thingie, not a pigtail.
Topics: 257
Year: 1989
It is currently January 23rd 2017, 9:32am
Attached by: shredzorv2
shredzorv2
Comments: 36
Time: 11:09pm
Ingmire
Date: Jan 18 '17
Time: 1:09am
Driftedone
Comments: 13
Date: Jan 10 '17
Time: 7:12am
Echo
Comments: 17
Date: Jan 09 '17
Time: 6:50pm
shredzorv2
Comments: 36
Date: Jan 01 '17
Time: 2:12am
Users browsing this forum: Bing [Bot], Google [Bot], Yandex [Bot] and 4 guests
