4 MPG increase from elec fan replacement...
by Lumpy [OP] » April 29th 2012, 5:59pm
by redfury » April 30th 2012, 3:11am
by Lumpy [OP] » April 30th 2012, 8:24am
by Swong » May 9th 2012, 4:48am
by Corsemoto » May 9th 2012, 5:04am
by TDMobile » May 9th 2012, 5:52am
Swong wrote:sounds great !!! mind posting your steps of diy + pets needed ?
kidding kidding.
by Swong » May 9th 2012, 3:10pm
by Lumpy [OP] » May 9th 2012, 3:48pm
by redfury » May 9th 2012, 4:51pm
by Lumpy [OP] » May 9th 2012, 5:17pm
by sadglad » May 9th 2012, 5:51pm
by Corsemoto » May 9th 2012, 7:54pm
by Lumpy [OP] » May 9th 2012, 10:07pm
sadglad wrote:Can you tell us more about the fan controller you used?
Even a 1 mpg improvement would pay for itself in no time.
by redfury » May 10th 2012, 1:14am
by Shad0wXCalibur » May 10th 2012, 1:57am
by sadglad » May 10th 2012, 2:50am
Lumpy wrote:It's a CompressorWorks TorqueFlo 733647, about 35 bucks from AutoZone......
by Wagon Master » May 10th 2012, 3:54am
redfury wrote:that install kit is the bees knees compared to what I did to connect mine electrically. I went after high amp relays, bought a seperate fan thermostatic controller and did all the wiring into the relays ( building the connectors into the relays with the proper terminals )
I have 2 relays, with the high speed set up on a switch on the dash for when I'm towing. It doesn't turn on until the engine is up to temp because the front end of the circuit is designed to not run the fan continuously under Key On power, nor is it designed to keep running as long as the thermostatic switch calls for it. The wiring is pretty straight forward though, no matter which way you go about doing it.
Of course, now that you posted that link to the fan, I'm trying desperately to find a replacement fan for the one I pulled, and I can't seem to find the year/model that fits the fan I pulled from the JY for $15!
by redfury » May 10th 2012, 6:00am
by Swong » May 10th 2012, 5:04pm
by decypher » May 14th 2012, 4:11am
It is currently May 24th 2013, 2:42pm
| Engines Forum |
| Engine Repairs, Modifications, Diagnostics, Tuning, Upgrading, Questions. |
| Moderator: chevy57bert |
| Previous topic Next topic |
| Recent Image Attachments | |||
| Sponsors |
